Old 06-23-2019, 11:58 AM #1
Jhiggs33's Avatar
Jhiggs33 Jhiggs33 is offline
Jhiggs33 is on a distinguished road
Jhiggs33's Avatar
Unending Soft Brake/Long Pedal Travel Issue
Hey guys I have been doing hours of research on the forums on this issue and have found a lot of good information, I am really looking for guidance on what priorities I should tackle first on this issue because I really am not that inclined to just throw money at it and hope it goes away.
I have a 96' SR5 with ~186k on the clock and I have already replaced/done the following...
Rear cylinders
Rear drums and shoes
Front rotors and pads (several times due to warping)
Passenger side caliper (Was frozen and the pistons were in terrible condition when I bought the vehicle)
Fluid flush/bleed (Done myself with 2 man method and at a local dealer and again at a trusted shop)
Bell cranks and adjustment (were both rusted frozen when I originally purchased)
Despite all of this I still have an extremely soft pedal with very long travel. There is almost a dead zone for the first half of the pedal which I thought would be remedied with an adjustment, but to no avail. There is a little feedback in the pedal towards the later part of the pedal travel and the brakes eventually somewhat catch, but even then I never feel like I am getting the stopping power that the car was designed to deliver. I originally chalked it up to just being the brakes are underpowered as many people decide to make the TBU, but last year my brother purchased a '02 Limited and the difference is night and day and his operates as I imagine it should with a consistent feeling in the pedal throughout the travel that doesn't require you to stomp on your brakes anytime you're traveling more than 35 mph.
Anyways, I am just looking for some advice on what you guys think I should tackle first and hopefully I'll be able to sort this out before I make another long trip back to school.
Cheers
'96 T4R SR5 Bilstein 5100/OME
Jhiggs33 is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 12:09 PM #2
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Rear cylinders
Cheers
If there are no leaks, the pads are not worn out & the calipers are both good, the rear shoes are not worn out & are properly adjusted and the whole system is properly bled then you most likely need a master cylinder. Toyota master cylinders sometimes just die and you end up with way excessive pedal travel and poorly functioning brakes. As for you brother's 02 it has a completely different master cylinder/ABS/power booster set up than your 96. You don't really need the TBU unless you run oversized tires or tow something heavy.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 02:16 PM #3
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Sounds like the master has failed. Did you check which calipers you have on the front? When i converted my 99 to the tundra brakes, the pedal travel increased but the stopping power was better, just delayed a bit.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 04:46 PM #4
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Hey guys I have been doing hours of research on ...
Cheers
I would agree with Mr. Coffee
I have a 2000 and I messed around with the brakes alot when I first purchased it. I finally ended up flushing and replacing the piston seal kit in the main. Those rubber seals will start to degrade and if it's still original your master seals had a hell of good run.
scroll way down last pic
https://www.toyota-4runner.org/2885174-post29.html
it's a different story but I undid my tundra brake upgrade because I don't like how much extra travel the pedal had running the front tundra calipers. I swapped back to stock sized calipers in the front and I will never go back to the tundra calipers. way better with stock size calipers. just a personal choice for me because I like a nice firm pedal to engage when I press the pedal.
Old 06-23-2019, 05:52 PM #5
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
Is it soft or spongy?
if when you first apply the pedal and it sinks to the floor, and then you get some brake action after you pump it a bit, it's likely an internal leak in the Master Cylinder.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 07:54 PM #6
turbodudey2's Avatar
turbodudey2 turbodudey2 is offline
turbodudey2 will become famous soon enough
I have a spare (used) OEM master cylinder that was working just fine before it was removed.
I’ll send it to you if you just pay shipping.
'96 Toyota 4Runner Limited 4x4, Supercharged
turbodudey2 is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 10:03 PM #7
Jhiggs33's Avatar
Jhiggs33's Avatar
Thank you for being the first to point this out and I really do not tow often just the occasional jet ski and U-Haul Trailer.
I have the stock calipers, but they are the factory upgraded ones which I believe were designed to fit the larger wheels that also came as an option on my Runner. Please correct me if I am wrong. My vehicle's sticker indicates it came with 265/75/R16s.
Interesting you say that I don't think I've ever heard of someone saying anything negative about the TBU, but I will definitely take that into consideration if I ever decide to go ahead with it.
The best way I can describe the feeling my brakes give is that the first half to two-thirds of the pedal travel provides no stopping power whatsoever and then after that the actual portion of travel that causes the car to reduce speed is extremely soft and the pedal must essentially go to the floor in order to come to a complete stop. Thank you for that insight it seems that the MC is likely the culprit.
Thank you for offering! I will PM you to see if we can work that out.
Again thank you everyone for getting back to me on this so quickly. Unfortunately work has swamped me these past couple of weeks, but I greatly appreciate all of your recommendations. I am going to do another once-over of the whole braking system and double check I'm not missing something obvious here, but I imagine I will ultimately end up replacing the MC and hopefully that will put an end to all of this.
Old 07-13-2019, 04:52 PM #8
AgeOfOctane AgeOfOctane is offline
AgeOfOctane is on a distinguished road
Not to argue with anyone here, but my experience is that a failing master cylinder will usually stop fine, but the pedal will sink to the floor while sitting at a stop light. If your pedal stays put once fully engaged, I wouldn't jump on replacing the MC.
My 96 had excessive pedal travel. The only thing that helped was replacing the rear drums with junkyard Toyota parts and the pads with Toyota pads. I found the parts store pads I bought did not have the same geometry as the Toyota ones. Then bleed and bleed again. I've also read on here that a curating the abs on a dirt road then bleeding can improve pedal travel, but I haven't tried that one yet.
Also, make sure the rear pads are self adjusting properly, and that you bleed following the proper sequence of wheel order.
'96 SR5 - TBU, FJ Cruiser 8-hole wheels, OME 906 Rear Coils, Stock Struts, External Transmission Cooler, Center Console upgrade, 99+ Headlight upgrade, Rola Roof Rack with extension. Cargo storage/ sleeping platform.
AgeOfOctane is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 09:00 PM #9
Ruedger556 Ruedger556 is offline
Ruedger556 is on a distinguished road
OP I'm having these same issues with my 96 I just bought. My pedal goes all the way to the floor before the brakes engage. And even then there is no resistance to the pedal. And I dont believe it's the master cylinder because when the trucks off and I pump the brakes they get tighter with every press. Let me know if you fix yours.
Ruedger556 is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 09:44 PM #10
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Really need to make sure the rear brakes are adjusted properly. They should just start to rub the drum a little when adjusted right. Obviously should not drag but there needs to be contact. I've had 2 experiences with mud in my drums causing the shoes to self adjust inwards and it scared the hell out of me once I got on the road. They would also seemingly pump up but the only cure was to remove the drums and clean things up and adjust the brakes.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 10:19 PM #11
I literally bought my 4runner last night and it's my first. So I'm just learning as much as I can.
Old 08-22-2019, 09:36 PM #12
Real Name: John
Real Name: John
You've come to the right place. Many helpful people here and great information. Give a read to all the stickies. Oh and congrats on your purchase.
Old 08-22-2019, 10:27 PM #13
So I tested my parking brake and no bueno. Any good reading material on here for adjusting the rear brakes and parking brake?
Old 08-23-2019, 07:19 AM #14
Real Name: John
Real Name: John
No bueno? I assume you mean you pull it back and it doesn't lock in. That's a sign your rear brakes need to be adjusted. Just do it as I described in my previous post. When you remove the drum, there's a star wheel that you adjust outwards, expanding the shoes. Do a little at a time until the shoes rub the drum. After you do that your parking brake should hit in 7-9 clicks. If you need in depth description and pictures just search "rear brake adjustment"
Old 08-23-2019, 07:54 AM #15
19963.4lsr5 19963.4lsr5 is online now
After you adjust your star wheels there is a specific procedure for adjusting the bell cranks. AKA that bolt on each one.
If you have a ridge on your brake drums it will make it difficult to adjust removing the drums. You can adjust the starwheel from the back of the brake plate through the slot with the rubber plug in it.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
adjustment , brakes , issue , pedal , travel
Brake Issue Help? YOTALUVR General Discussions 6 11-27-2016 08:59 AM
brake issue 01thunder 3rd gen T4Rs 18 01-27-2016 12:42 AM
Brake issue? FSRbikr98 5th gen T4Rs 7 02-21-2011 02:13 PM
Installed a "Brake Force" brake controller...one issue 2003Can4runner 4th Gen T4Rs 2 10-29-2010 08:52 PM
'03 SE Brake Issue - What would you do? pdoel Problems & Warranty Issues 9 11-15-2006 07:00 PM
