Old 06-27-2019, 10:21 PM #16
Cvett95 Cvett95 is offline
Cvett95 is on a distinguished road
Are your brake components greased? (Adjuster threads, backs of shoes where they meet the backing plate, etc)
Make sure there isn’t oil on the face of the shoes or in the drum.
Maybe there is an issue with one of the brake cylinders/lines.
Just my .02
Cvett95 is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 11:10 PM #17
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Originally Posted by Scramble View Post
OEM shoes & drums should take care of it.
I need to figure out the OEM parts numbers, do you happen to know them?
Originally Posted by Bad Luck View Post
The theory behind the temp gauge is the side that locked will be hotter than the other side. Drive around and get it to lock up/stick and then temp each rotor/drum and compare each side
Okay I kind of had an idea that's what you needed to do. So I guess my next question is what does it tell you? And also, what if they are both equally hot? Haha
Old 06-28-2019, 08:33 AM #18
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
The hotter side is the one that's sticking. If they're the same temp left to right then it's not sticking as bad as I think or there's no problem with it. You can only compare the front left to front right or rear left to rear right. Different braking setups and bias heat up differently.
Old 06-28-2019, 10:07 AM #19
St Runner's Avatar
St Runner St Runner is online now
St Runner will become famous soon enough
St Runner's Avatar
You have two temp gauges already. They are attached to your forearms on both sides of your body. Just put your hand on your wheels after you drive around for a while, if one is sticking it will be hotter than the others. If they are all the same than you have a temporary sticking issue in that it sticks and unlocks quick enough not to build up a temperature difference. If you know it is the rear brakes than just replace the shoes, caliper and check all the emergency brake functions carefully. Just an FYI never expect mechanics to solve all your problems, they are only concentrating on what they are being paid to fix. Even the most talented mechanic is only as good as the time he has available
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is online now   Reply With QuoteReply With Quote
Old 06-28-2019, 05:09 PM #20
jross20's Avatar
jross20's Avatar
Okay understood. Though I feel like it is both sides, when it locks the truck doesn't want to turn or veer. Unless one drum locking up could still hold her back?
I will try to do this test this weekend and will report back.
Haha okay yeah I will try to figure that out this weekend and will also look at ordering new shoes and drums. You said caliper... did you mean drums or the piston?
Old 06-28-2019, 05:38 PM #21
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
find a gravel lot, stop hard so the tires slide. then verify what tires are locking up.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 06-28-2019, 08:05 PM #22
St Runner's Avatar
St Runner's Avatar
Piston is probably correct for the rear. They are inexpensive and not difficult to replace
1997 SR5 4x4
2001 SR5 4x4
Old 04-12-2021, 11:17 PM #23
2wdguy 2wdguy is offline
Real Name: Ray
2wdguy is on a distinguished road
Real Name: Ray
Did you ever get this fixed? Please report the solution.
2wdguy is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 06:36 PM #24
jross20's Avatar
jross20's Avatar
Hey man, yeah she just needed OEM parts. The shoes that were on her weren't even for a Toyota.
adjusted , brakes , cleaned , fine , rear
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Front Brakes are locking up!!!! Please Help! carterb30 Classic T4Rs 23 04-02-2014 10:29 PM
'98 front brakes locking up 318 3rd gen T4Rs 6 12-11-2013 11:31 AM
Brakes are locking up in the rear end....WHY???? HELP!!! T4Rex. 3rd gen T4Rs 6 09-23-2012 10:20 AM
Rear Brakes locking up ja7369 3rd gen T4Rs 3 05-21-2007 02:05 PM
