Old 06-24-2019, 04:11 PM #1
psea17 psea17 is offline
psea17 will become famous soon enough
Shifter Boot Replacement
Has anyone replaced this boot at the base of the shifter?
The boot clearly won't fit over the shifter, so I'm guessing I need to remove the 4 bolts at the base of the shifter. Anyone done this? Anything tricky I need to be aware of? never done anything with a transmission and can't afford to screw this up. It's my daily driver.
thx!
Shifter Boot Replacement-shifter-png
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 10:03 PM #2
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
What are you doing? Did you replace the factory boot with another? These are pretty simple. Cant really see your pic, its so small. Here's one I have kicking in the garage, the boot slips over the bevel lip.
Shifter Boot Replacement-img_6468-jpg
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 10:23 PM #3
Did you drag yours down over the shifter?
...and thanks for responding. Was starting to think everyone took off for the summer ;-)
Manual Transmission
Old 06-25-2019, 06:45 AM #4
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I did this same job a while back yes you just drag it down. I put just a bit of grease on the inside of the rubber boot and that helps it slide down.
Old 06-27-2019, 12:02 AM #5
thanks for the guidance.
was super easy to drag it down the shifter w/ a little grease on it. just for shits/giggles, I took the shifter out just to see how it connected. simple. push the top "shield" down and twist to the left, it pops right out.
Manual Transmission
base , boot , screw , shifter , transmission
Gear oil smell from shifter boot Zelos 3rd gen T4Rs 20 03-03-2022 05:39 PM
WTB: 5spd 4x4 Shifter Boot - 2nd Gen - TX 94stick For Sale: T4R Items 1 04-23-2014 12:29 PM
3rd gen multi-mode shifter w/button and boot grey Citrus Heights,Ca nor_cal51501 For Sale: T4R Items 1 02-25-2014 01:40 PM
WTB- 2nd gen 4x4 mud flaps and black 5 speed shifter boot 94Runner4 For Sale: T4R Items 1 04-04-2012 03:15 AM
1st Gen (84-89)4runner SHIFTER BEZEL W/LEATHER BOOT JDs89Runner Classifieds - buy & sell (no commercial ads please) 2 05-17-2011 01:53 AM
