Old 06-25-2019, 08:00 PM #16
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Originally Posted by Ryance39 View Post
It's funny to me that people pick out the little things that have zero bearings on the value of the thread.
For my part, I see it as having a LOT of bearing on the value of the thread. Mostly because I inherently can't stop wanting people to not suffer loss or injury (sorry, double neg there). Put another way, dude, I don't want your rig to catch fire or you to suffer injury should your lights (granted fog, not mains) cut out at an important time. A *LOT* of people blindly follow things posted on the internet without ever considering that it might be unsafe, so I post for Their benefit too.
Wire-nuts are designed for solid-wire, not stranded. From experience (couple decades as a motorcycle mechanic), wire nuts on stranded wire tends to be a fire hazard. If I come across as an ass, but manage to save someone from loss ~ I'm okay with that equation.
BTW, look at all the free bumps to your thread you're getting. WAY more visibility than a huge number of posts on here.
Brian. is offline   Reply With QuoteReply With Quote
Old 07-05-2019, 08:44 PM #17
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about
Real Name: Ryan
Wire nuts have been removed, wires have been soldered and shrink wrapped. No pics but everyone can rest easy now.
I've been very happy with the lights, and they don't seem to bounce too much for only being mounted on one side.
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
1999 BMW Z3M Roadster
2020 Super White ORP
Ryance39 is offline   Reply With QuoteReply With Quote
Old 07-06-2019, 10:39 AM #18
Red October Red October is offline
Red October will become famous soon enough
Any night shots of the light output from these lights? I like the idea of them as an alternative for trying to find stock fogs, since both of mine are currently broken on one of my trucks.
If ya always do what ya always done, Ya always gonna get what ya always got.
Red October is offline   Reply With QuoteReply With Quote
Old 07-06-2019, 02:06 PM #19
Real Name: Ryan
Real Name: Ryan
Not quite "night" but it was getting dark.
[IMG]Lights[/IMG]
[IMG]Lights[/IMG]
2001 BMW M5
Old 07-06-2019, 02:35 PM #20
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Originally Posted by weekendclimber View Post
The thing I ran into when using a set of Hella Micro DE's to replace the factory fogs is that the bulbs would burn out because of where the fogs are located up front. Since they are right in front of the front wheels, they would get constantly sprayed with water when it rained and that would make its way into the housing and then burn the bulbs out and pop fuses.
I ruined a pair of Micro DEs the same way. For the next pair I'm going to extend the breather fittings and plumb them towards the engine bay, like the extended diff breather mod. I'll also use hose clamps so the rubber boots have a more water-tight seal.
Old 07-08-2019, 11:51 AM #21
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
I never ruined a pair, but was super frustrated with them burning out all the time. Here's the saga of how they were fixed if you want some tips.
weekendclimber is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 02:10 AM #22
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Actually that's where I got the ideas to extend the "breather" and clamp the boots LOL
Old 07-09-2019, 11:54 PM #23
giguchan's Avatar
giguchan giguchan is offline
giguchan will become famous soon enough
giguchan's Avatar
It's good that you can hook the new Lamps to the old wires... I would've used the Harness that came with the replacement kit.
But that's me.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
giguchan is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 10:17 AM #24
Real Name: Ryan
Real Name: Ryan
But that's me.
The new lights did not come with a harness. Each light had ~6inches of wire coming off of it. I liked the idea of not adding another switch and using what's already there. To each their own.
2001 BMW M5
factory , fog , light , lights , step
Factory fog light issue / replacement? halflife78 5th gen T4Rs 30 10-24-2018 07:57 PM
Check Engine Light VSC Light Manifold replacement daviddep 4th Gen T4Rs 0 09-29-2017 07:19 PM
JBL factory nav replacement jay22 4th Gen T4Rs 3 12-03-2016 12:01 AM
Factory Fog Light Replacement Hepar 3rd gen T4Rs 7 04-19-2012 12:17 PM
04 Factory Amp replacement 04RunnerSport Engines / Suspension / Wheels / Tires / Audio / Accessories 6 07-13-2011 12:13 PM
