Old 06-26-2019, 10:48 PM #1
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
Center console lids: 96-98 SR5 longer than 99+ SR5?!
I just picked up an ‘98 SR5 center console lid to replace the cracked one in my ‘00 SR5, and to my surprise the 96-98 lid is physically longer than the 99-02 lids! Well this is news to me, as I thought all console lids were the same minus the Limited trim’s having leather stitched covers instead of a vinyl one like the SR5, and I had assumed the insert on the under side were also interchangeable. I had no idea there were length differences of the lids and the inserts, making them not easily interchangeable.
I knew the 96-98 never came with the upper storage tray, which was a mid gen upgrade, so I assumed that I could swap out the plastic inserts on the underside to make the older lid fit in my runner. The inserts have screws that don’t line up with one another, so the older lid won’t fit on my ‘00 unless I remove the upper tray permanently. The photos I attached show the physical length difference of the lids, as well as the latches on each. The older one has the hook style latch that locks the lid down to the console, and the 99+ lid has a plastic snap that clips into the upper storage tray.
Anyone with a 99+ shopping for a used replacement console lid, let this be a PSA that they are not interchangeable if you want to keep the upper storage tray in the newer consoles.
Just for the sake of cross posting for anyone searching this subject, I also found this post about someone with a 96-98 console wanting to replace his console lid with a 99+ lid, but I tried doing the opposite by swapping the older lid with the newer console that has the upper storage tray. The 99+ lid is missing the hook piece that locks onto the console, so it appears he took that hooked piece from the old one and used a spacer to get it to function properly on the newer lid.
Sorry for the photo sizes, the T4R.org image uploader isn’t user friendly, and my old faithful used to be Photobucket but we all know how that ended - you Photobucket!
Center console lids: 96-98 SR5 longer than 99+ SR5?!-e79ba6b9-e0d8-4522-8758-95b21096a8c7-jpg  Center console lids: 96-98 SR5 longer than 99+ SR5?!-2890426c-e0cd-4650-af45-5c72ce9ed4cd-jpg  Center console lids: 96-98 SR5 longer than 99+ SR5?!-db26335e-d16d-41ba-bb23-87d3a6451b3b-jpg  Center console lids: 96-98 SR5 longer than 99+ SR5?!-3c996551-ad7f-4cc2-9f80-4e8d9aad2471-jpg
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 09:10 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I never knew those lids were different. Add it to the list of the later Gen changes. Is there a thread for those??
Old 08-23-2019, 09:42 AM #3
Real Name: Evan
Real Name: Evan
Mid gen upgrades
Old 08-23-2019, 09:51 AM #4
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
The two lids are indeed completely different and non-interchangeable. You can however swap the leather from the early model onto the later model, if you have the time and dedication - https://www.toyota-4runner.org/2866630-post2.html
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 08-23-2019, 01:46 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
thanks.. :-) I noticed the gas tank lid is different, the trailer module wire harness as well. as I have some early and others later.
99+ , console , lid , sr5 , tray
NV: 2010-2018 4runner Console Vault Like New. Locking Center Console, great for CCW fur_pig For Sale: T4R Items 2 11-11-2018 05:33 PM
99 center console non-heater trade for Hester console. Jaysen4runner Want to Buy/Trade 0 07-24-2016 03:15 PM
Center display no longer lights up TexasA&M 4th Gen T4Rs 19 10-16-2015 08:41 AM
Longer rear center brake lne. Rendell 3rd gen T4Rs 11 06-13-2013 08:25 PM
Wtb center console lid 98t4rga For Sale: T4R Items 4 09-20-2011 06:32 PM
