Old 06-27-2019, 12:34 AM #1
Mikeyt Mikeyt is offline
Mikeyt is on a distinguished road
Wheel spacer question
Going to put on a set of 17x9 Ultra Hunter 203 wheels after I do a 3" suspension lift. It has a positive 12 offset with around a 5" back spacing-I can't remember exactly. My question is that I want to have the rims sit out a little for a more aggressive stance but nothing crazy. Would a 1.5" spacer be okay? Im going to use one that's lug centric also. If 1" is better im okay with that. I know it will possibly effect my wheel bearings so that's why I'm not doing anything drastic. My goal is to have it stick out about 1/2-1" outside the fender flares.
Mikeyt is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 05:49 AM #2
Mudeprived Mudeprived is offline
Mudeprived is on a distinguished road
Tire size?
1999 Limited
265/75/16 AT51's
Bilstein 4600
Mudeprived is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 11:45 AM #3
Reno - 3rd gen's Avatar
Reno - 3rd gen Reno - 3rd gen is offline
Real Name: Jordan
Reno - 3rd gen is on a distinguished road
Real Name: Jordan
I run 1.5" spacers with moderately offset wheels and I have never had any issues. I've heard horror stories about spacers, but have yet to have any bad experiences and I wheel mine pretty hard. My 2 cents is if you do much offroading, only use the spacers if you need them to avoid any tire rubbing while turning, if you are just doing it for looks and primarily stay on pavement, you should be just fine. Make sure to hit the lugs on the spacers with some locktight so you don't have any surprise loose lugs.
Obviously the spacers with an offset wheel will add to the stress on wheel bearings and other components. But I think if you check things out regularly and ok with some added wear and tear then chances are you'll be ok.
Reno - 3rd gen is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 01:45 PM #4
ThySenteth's Avatar
ThySenteth ThySenteth is offline
ThySenteth is on a distinguished road
ThySenteth's Avatar
These are -12mm offset wheels with 1.5" spacers up front and 1" spacers in the rear. If your +12mm then yours would essentially be 24mm further in than these pictured.. Tire size will play a small role but not much.
**NOT MY PICS
*EDIT: If you haven't bought wheels yet I would consider starting with a negative offset wheel to eliminate the amount of spacer you have to use. Just my two cents.
ThySenteth is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 03:58 PM #5
Sorry for not giving the tire size. However changing gears to get the negative offset. I'm going to go with Ultra Hunter 203's black with machines accents which are a -12 offset and wrap them in 275/60/20 Nitto Ridge Grapplers. Still makes 33" tall and 11" wide after inflation...at least that's what's on Nitto's website. That should bring them out about 1.5" from what both vendors tell me. Anyone else run a similar combo, love to see what they look like?
Old 06-27-2019, 05:21 PM #6
ThySenteth's Avatar
ThySenteth's Avatar
Wheel width comes into play here too. -12mm on a 17x9 (pictured above) will be slightly different than 17x8 for example. At any rate, I just bought 17x9's -12 like the pictures above, but I don't plan on running spacers as I'm not looking for poke, but flush with the flare instead. To get like the above picture you're going to need to run spacers regardless.
centric , lug , question , spacer , wheel
Wheel Spacer Question KurtL 3rd gen T4Rs 10 10-16-2014 11:56 PM
Wheel spacer question MtnDewd 4th Gen T4Rs 6 10-02-2014 07:23 PM
Another Wheel Spacer Question... TXBoy 5th gen T4Rs 0 11-15-2012 06:25 PM
Wheel Spacer Question Bryan1 3rd gen T4Rs 3 10-28-2012 05:51 PM
wheel spacer question wtf6316 4th Gen T4Rs 20 01-12-2010 07:20 PM
