Old 10-17-2010, 06:18 PM #1
4Runner93 4Runner93 is offline
4Runner93 is on a distinguished road
Engine surges when idling
Hey guys, so went to look at a 99 today and mr an my dad test drove it. When checking the outside for cosmetic stuff, the engine would idle at ~800-900 but would surge and sound like it was almost going to die. When I watched it, it would bottom at 500 before recovering to 900. Any idea of what it could be? The seller said it could either be the throttle body needs cleaning or an air idle sensor...anything else it could be?
4Runner93 is offline   Reply With QuoteReply With Quote
Old 10-17-2010, 06:24 PM #2
animal animal is offline
animal is on a distinguished road
MAF might be dirty as well.
'99 4Runner Limted 3.4l v6 4x4
animal is offline   Reply With QuoteReply With Quote
Old 10-18-2010, 04:33 PM #3
Headly Headly is offline
Headly is on a distinguished road
where is the air idle sensor?
Headly is offline   Reply With QuoteReply With Quote
Old 10-18-2010, 05:39 PM #4
Jordan Petry's Avatar
Jordan Petry Jordan Petry is offline
Jordan Petry is on a distinguished road
Could also be your Idle Control Valve. The valve you are referring to is the EACV, electronic air control valve. That could be bad. I would also load test the alternator. It could be revving up to try and get more power to run the car, and then idling down because of lack of power.
1999 Toyota 4runner Limited 4x4 V6
Jordan Petry is offline   Reply With QuoteReply With Quote
Old 10-18-2010, 06:53 PM #5
bak3rme's Avatar
bak3rme bak3rme is offline
bak3rme is on a distinguished road
bak3rme's Avatar
been having this problem for a while. i wish i could fix it!
i've cleaned the IAC valve
cleaned TB plenty of times
cleaned MAF
replaced sparkplugs/ wire set
replaced fuel filter
been running injection cleaner from cheveron every 5 fillups or so
been filling up with only chevron and shell gasoline
still i get these surges when at idle...and it still shuts off every now and then...
what else to do???
'99 SR5 3.4L 2WD
SOLD
Build Thread
2003 Nissan 350z Track/Autocross
2014 4runner SR5
bak3rme is offline   Reply With QuoteReply With Quote
Old 10-18-2010, 06:58 PM #6
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
Surging is usually associated with a bad TPS (throttle position sensor). Dirty IAC is usually stumbly and rough idle and dirty MAF usually causes hesitiations as well as bad idle. The TPS can be tested for resistance, but they aren't too expensive to replace.
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 10-18-2010, 07:11 PM #7
bak3rme's Avatar
bak3rme's Avatar
TPS replacement. talk more plz!
edit* not that i want to go replacing stuff..but just some more info i can store
'99 SR5 3.4L 2WD
SOLD
Build Thread
2014 4runner SR5
Old 10-18-2010, 07:57 PM #8
brian2sun's Avatar
brian2sun's Avatar
I was getting surging and after research and cleaning everthing else I could, I tried out an Autozone TPS for ~$15 IIRC. I didn't plan on actually using their crap parts, but I figured for $15 it was worth that to see if it made a difference. It did so I took it off, cleaned it up, brought it back, got my $$ back and bought an OEM one off ebay for ~$60. Problem solved and it's been about a year since.
Old 06-25-2012, 07:07 PM #9
xcmountain80 xcmountain80 is offline
xcmountain80 will become famous soon enough
Pricing a TPS
xcmountain80 is offline   Reply With QuoteReply With Quote
Old 06-25-2012, 07:15 PM #10
4R99JB's Avatar
4R99JB 4R99JB is offline
Real Name: Jerrie (He).
4R99JB is on a distinguished road
4R99JB's Avatar
Thanks for sharing your experience. It's posts like these that make this a great forum for sharing AND learning.
4R99JB is offline   Reply With QuoteReply With Quote
Old 06-26-2012, 11:26 AM #11
Still pricing
Old 06-27-2012, 02:18 PM #12
Anyone have a part number, Toyota is telling me this is a complete kit and come with the throttle body..... (sensor not sold separately).
A
Old 06-27-2012, 02:46 PM #13
thebrandon's Avatar
thebrandon thebrandon is offline
thebrandon is on a distinguished road
thebrandon's Avatar
Everyone beat me to it. I was going to suggest the TPS as well.
Check rock auto. They have them for my 2000 3.4L from $30-46. However it is not an OEM one I think.
thebrandon is offline   Reply With QuoteReply With Quote
Old 06-27-2012, 03:03 PM #14
I replaced the alternator and can watch the amperage it is producing and that’s not the culprit. I have a 2002 4RUnner and the TPS is not sold separately, whole throttle body only.
Helpful to fully understand what is happening
http://www.ttora.com/forum/showthread.php?t=13283
Thread I started trying to address the TPS specifically and gather more data
Throttle Position Sensor.....?
Aaron
Old 07-24-2012, 12:41 PM #15
I'm wondering if this may be indicative of a failing battery? I'll stop by autozone and have them give it a look.
Synthetic Engine Oil Thai Maintenance/Detailing 114 02-18-2023 01:39 PM
interference vs. non-interference engine peter78 Maintenance/Detailing 6 10-26-2011 08:32 PM
Engine was running horrible, but not any more... hopefully. brian2sun 3rd gen T4Rs 52 01-18-2011 05:48 PM
Oil Real vs. Synthetic CVsGX470 Maintenance/Detailing 175 12-27-2010 07:15 PM
22-R Toyota Racing Engine etsola Classifieds - buy & sell (no commercial ads please) 0 08-26-2010 06:08 PM
