Old 06-29-2019, 04:12 PM #1
Capnemo Capnemo is offline
Capnemo will become famous soon enough
Where or if, to grease slotted caliper shims?
I have Tundra slotted shim kit for a Gen 3 bake upgrade but I am guessing all Toyota slotted style caliper shims instal in a similar fashion (could well be wrong).
If it matters these are 04945-0C030 for 2005 V8 Tundra calipers/pads.
Does one grease both sides a dollop, pad side only, no grease? I cannot find anything on the 'net except a video where the guy applies to the outside of the slotted shim so it will stick to the outermost thin metal shim.
One side is cross-hatched black finish the other side bare metal, I think the installation will become apparent when I get there because of the bent over tabs/ears...
Capnemo is offline   Reply With QuoteReply With Quote
Old 06-29-2019, 05:45 PM #2
OK I was able to finally find some information, a little grease on both sides of the slotted inner shim, hope this helps someone else:
NOTE When replacing worn pads the antisqueal shims must be replaced together with the pads - Toyota Sequoia 2004 Repair
grease , metal , shim , side , slotted
brake rotor/caliper/pad replacement - caliper piston, too? amheck 4th Gen T4Rs 16 11-08-2017 09:29 AM
Steering rack polyurethane bushings: grease or no grease? fourfive 3rd gen T4Rs 14 05-07-2017 02:59 PM
Brake caliper question - which caliper mfg doesn't lock up? bergs 4th Gen T4Rs 6 03-14-2015 09:18 PM
Caliper rebuild...torque settings for caliper halves squabeggz 3rd gen T4Rs 0 07-24-2014 11:08 PM
