Old 06-30-2019, 12:24 AM #1
xcmtb83 xcmtb83 is offline
xcmtb83 is on a distinguished road
Please Help With Heater Line Part Numbers
Well my trusty '96 (with rear heat) has recently developed a couple of coolant leaks from the rear heater and heater core lines/fittings under the hood. The first leak was the hose I have labeled "NEW", I have since replaced it. Now I have noticed the circled steel T-fittings are corroding and there is coolant leaking out of the hose cross sections. The photo was downloaded off of T4R just for reference, my stuff isn't this new looking.
I would like to replace all of the pictured lines, T-fittings and hose clamps at once and be done with it but I am having a hard time finding part numbers, especially part numbers for the T-fittings. The ONLY part number that it might be is in the first link below but I have a really hard time thinking that they cost that much, in addition to the cost, there should be two different part numbers because the T-fittings are not identical. Perhaps the part number below is actually for the entire assembly?...doubtful I know but I don't know what else to think. Thoughts?
The second link below is for new silicone hoses that I might just go with instead of trying to determine OEM part numbers for all of the hoses in the picture. Even if I go this route I will still need the new steel fittings. They look somewhat special and am not sure if regular auto parts stores will carry them. Thoughts or suggestions?
87265-89110 - Toyota Parts Deal
Toyota 96-02 4Runner 3.4L V6 HPS red High Temp Reinforced Silicone rear heater Hose Kit Coolant OEM Replacement 57-1798-RED
Please Help With Heater Line Part Numbers-20131022_211401_li-jpg
xcmtb83 is offline   Reply With QuoteReply With Quote
Old 06-30-2019, 02:53 AM #2
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
not sure about the parts your looking for but it looks like your missing a ground strap from the passenger side head to the fire wall. There is a screw you can see that is just left of the heater valve with no ground wire attached to it.That ground being missing could cause electrolysis problems in the cooling system or other electrical ground issues
plcfcng is offline   Reply With QuoteReply With Quote
Old 06-30-2019, 08:27 AM #3
DreadPirateJon's Avatar
DreadPirateJon DreadPirateJon is offline
DreadPirateJon is on a distinguished road
Go to the Toyota owners page and then find the parts section. They have very useful parts diagrams that you can look through to find your part numbers.
Sent from my moto g(6) using Tapatalk
97 5spd with elocker
Build Thread https://www.toyota-4runner.org/3rd-g...st-bucket.html
2 inch Lift (Bilstein 5100 F&R, 99 Talls F, OME R), 33 Inch Tires
Rebuilt Engine, Doug Thorley Headers, Gibson Catback
DreadPirateJon is offline   Reply With QuoteReply With Quote
Old 06-30-2019, 09:40 AM #4
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
Here is the parts diagram:
TOYOTA 4RUNNERVZN185L-GKPZKA - ELECTRICAL - HEATING AIR CONDITIONING WATER PIPING | Japan Parts EU
You have the correct part number for the first Tee, here is the second one (if you thought the first one was expensive, don't look at this one!):
87265-35340 CONNECTOR, HEATER WATER HOSE, NO.2
Here are a couple of lower prices, I always like dealing with these guys:
8726589110 Toyota CONNECTOR, HEATER WATER HOSE Price: 31.59$, Weight: 0.042kg - PartSouq - Auto Parts Around the World
8726535340 Toyota CONNECTOR, HEATER WATER HOSE, NO.2 Price: 50.96$, Weight: 0.043kg - PartSouq - Auto Parts Around the World
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 06-30-2019, 11:54 PM #5
Originally Posted by 4Runner4Leon View Post
Thank you!
Old 08-22-2019, 09:24 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The older 3rd gens pipes to back heater are steel lines, while the later models are (Stainless "xctbtbm83). I used part number #87248-35061 on my 98 and 97 4 runners as they were steel originally but now are Stainless ( thanks to xcmtb83 pointing that out). I also believe they discontinued those steel lines anyhow.
Old 08-22-2019, 10:07 PM #7
Originally Posted by brillo_76 View Post
The older 3rd gens pipes to back heater are steel lines, while the later models are aluminum. I used part number #87248-35061 on my 98 and 97 4 runners as they were steel originally but now are aluminum. I also believe they discontinued those steel lines anyhow.
The new lines are stainless steel not aluminum. I first noticed this revision on an '01 at a self-serve yard. The lines went home with me.
Old 08-23-2019, 10:14 AM #8
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Same here. Oooh, look at that shiny rear heater line. *snag*
When I took off the steel lines on my '99, there were a couple of *very* thin spots under bubbled paint that popped open when I bent them slightly. I figure I beat a coolant leak by a matter of a few months.
JohnMc is offline   Reply With QuoteReply With Quote
Old 08-23-2019, 01:37 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh. my bad I didn't think they use stainless... I have another set for my 97 5 speed. :-)
Old 08-23-2019, 01:41 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If you can't find them in a salvage yard they were around $100 new. My 98 Silver ones someone made new lines for it out of steel in its past.
heater , hose , numbers , part , t-fittings
OEM Part numbers GHARP57 3rd gen T4Rs 4 04-11-2017 07:54 PM
LBJ's etc. Part Numbers!! RockyrT4R 3rd gen T4Rs 2 04-09-2017 09:50 PM
Part numbers for fuel line and what is this thing? LookAtThatDog 3rd gen T4Rs 4 10-26-2015 04:43 PM
Need Some Help With Part Numbers PopsSmith 5th gen T4Rs 4 04-19-2015 02:39 PM
Need some part numbers Mr Castulucci 4th Gen T4Rs 11 07-07-2005 03:34 PM
