Old 06-30-2019, 09:36 PM #1
grokglock grokglock is offline
grokglock is on a distinguished road
255 85 r16 q&a
255 85 R16 is an awesome size but it's somewhat boutique. There isn't a whole lot of selection in this size so I am looking for others who are interested or have run this tire size.
I believe the tire has weight savings benefits when compared to 285s it also performs better in certain scenarios. I live in FL and I've seen big lifts with pizza cutters do very well in mud for example.
What do you guys have? What is available as of 2019? What's the best tire in this size? What is popular and what's the best deal?
It would be nice to try and get tread wright to make this size maybe a group buy if there is enough interest.
grokglock is offline   Reply With QuoteReply With Quote
Old 06-30-2019, 10:36 PM #2
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
https://www.toyota-4runner.org/3267654-post126.html
BFGoodrich Mud-Terrain T/A KM2 LT255/85R16 123Q E-ply
I like them a lot, they are little squirmy on the road but most mud terrain tend to want to wander a bit on the road.
I have only had them on the trail 2x times now and nothing super muddy but they hook up just fine. I'm not a mud bogger these days. it just get 's into everything and wreks all the seals/bearings.
I agree as long as you have traction(not bottomed out) with a thinner tire you should get a little better push in the slop. if your in very lose sand or bottomless mud I think wider is better. just kind of depends on what kind of stuff you want to slog?
Old 07-01-2019, 10:52 AM #3
Nice! I love those steelies on your rig. I wish more companies would make this size, I am seeing most are MT tires - would be nice to have more AT selection.
Old 07-01-2019, 11:29 AM #4
Roc Doc's Avatar
Roc Doc Roc Doc is offline
Roc Doc is on a distinguished road
Roc Doc's Avatar
I wish Nitto would make a Terra Grappler in this size.
1998 4Runner Limited, King coilovers, Trick Toys Fab front bumperette/lightbar, TTF rock rails, Toyo 265's, locker mod.
Roc Doc is offline   Reply With QuoteReply With Quote
Old 07-01-2019, 04:56 PM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
@grokglock Here you go: 255/85R16 Tires
Old 07-02-2019, 11:37 AM #6
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
I have BFG KM2 255/85/16
I love the look. They are 3ply load range E tires, so stiff and bouncier than a something like a Ko2. They will swim around on the road a little bit, keeping you from falling asleep behind the wheel! They aren't quiet either.
That said, I love these tires and will buy them again when this set wears out.
I am already used to any Noise/Harshness.
When people say they're harsh, it's not like driving a tractor-harsh. It's just a little harsher than an all-terrain. Not bad overall
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 07-02-2019, 02:30 PM #7
I don't really need a MT tire all the time. I may try out the maxxis bighorns if I commit.
Old 07-09-2019, 03:52 AM #8
ShannanC's Avatar
ShannanC ShannanC is offline
Real Name: Shannan
ShannanC is on a distinguished road
ShannanC's Avatar
Real Name: Shannan
I run Maxxis Bighorns and love them. Not too loud for the aggressive tread and don't hydroplane like wide tires do. They don't weigh as much as the 285s and are load range D so they ride better also. Great tire. I highly recommend them.
99 4runner Limited 2wd - K & N air filter, deck plate mod, ISR mod, 2" Fat Pat's body lift, Bilstein Tundra 5100s and Toytec 620lbs coils in front, LX450 coils and Bilstein Tundra 5100s in rear, extended end-links and panhard drop bracket, Maxxis MT-762 Bighorn 255/85/R16, JDM engine swap, sport hood, ARB front bumper, 199mm Tundra brake upgrade
ShannanC is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 12:10 PM #9
ahdmullins ahdmullins is offline
ahdmullins is on a distinguished road
I have searched around on the forums, but haven't found a solid answer. Will 255/85R16 work on a 9" wide rim? Previous owner installed the current wheels on my truck, I love them, but I want to go with a narrower tire. 9" too wide for pizza cutters?
98 4Runner SR5 Evergreen Pearl, tan interior/sport seats
Toytec Ultimate 3" lift, 4Crawler 2" body lift (removed)
OME rear shocks/springs, Toytec diff drop, Energy poly body mounts
231 Tundra brake upgrade with Brembo rotors, All Pro 1.5" spacers (removed)
Method Race 105 wheels (16 x 8), Definity Dakota 285/75R16
ahdmullins is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 12:43 PM #10
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
You need to check the tire spec, they will give you a wheel width range.
I’m going to guess it would be fine section width wise but your still going have rubbing if you don’t move the lower ball joint forward or get SPC upper arms to move the tire forward. Or beat the crap out of the rear fender well.
Old 03-01-2020, 09:18 PM #11
deves2 deves2 is offline
deves2 is on a distinguished road
max rim width for 255 85 16 is an 8" rim.
i have run Deck Cepek extreme country in this size and love them. NO rubbing at all (2.5in lift) no spacers needed. performance was great and it should be noted here that my 4runner is not a mall crawler. It is on trails weekly all year long!!
deves2 is offline   Reply With QuoteReply With Quote
Old 03-01-2020, 11:24 PM #12
Lefty JD's Avatar
Lefty JD Lefty JD is offline
Lefty JD is on a distinguished road
Lefty JD's Avatar
I love this size. Great ground clearance without all the rub problems. I’ve had DC extreme country’s on for several years now. They do really well in general-hook up great, no flats (E load range). They do get kinda loud after some mileage, and tend to follow the ruts in the road etc, but not bad for a 33” tire. I’ll probably slap another set of them on again when I kill these ones.
I did have to run a wheel spacer to keep the sidewalk out of the control arm, till I eventually got some aftermarket uca’s. The truck handles better with the spacers on so I still run them, but that’s a whole other discussion.
99 Limited
4.30 E-locker, 861’s/Bilstein ext travel
4xInno rear bumper w/swing out
Lefty JD is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 02:01 PM #13
hounddogman's Avatar
hounddogman hounddogman is offline
Real Name: Levi
hounddogman is on a distinguished road
Real Name: Levi
I wouldn't try 255s on 9" wheels. I have the maxxs 255s on 8" wheels and I think that's about the max . 255/85R16s look better on a 7 " wheel.
96 SR5 5 speed, 4:88s with rear ARB , 255/85/R16s , some armor and lights
hounddogman is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 03:50 PM #14
I've written to BFGoodrich twice now over the past couple of years begging them to make a 255/85/16 Ko2 (not KM2)
The world needs this tire
Load range E is just crazy for our lightweight rigs
If you guys get a spare 5min, DM BFG on Instagram or reach out on their website to ask for a K02 in 255/85/16. With enough demand, you never know what could happen
I had a lot of luck with DMing them on Instagram (marketing person said they were going to get this to a specific product development guy, and they've heard this request often)
They may need data to build a case
Old 06-16-2020, 10:17 PM #15
zcostilla zcostilla is offline
zcostilla is on a distinguished road
Sorry to drag up an old thread, but I felt it was better than creating another one. Is anyone run 255/85R16s on the factory rims? If so, how much lift is needed? Can I get by with 2” using the narrower tires?
zcostilla is offline   Reply With QuoteReply With Quote
guys , mud , r16 , size , tire
