Old 06-16-2020, 10:53 PM #16
blairracd's Avatar
blairracd blairracd is offline
blairracd is on a distinguished road
blairracd's Avatar
I wanted this size so, so, so, so badly.
The time came to get new tires (just last month), and I just couldn’t justify getting a MT. Ended up going with 285/75/16, sadly. They’re okay...
255 85 r16 q&a-abeb1c46-82e3-42e7-bca2-161398c610c2-jpg
Living and breathing and bleeding Toyota
https://imgur.com/a/KvwQdyO
RIP my ‘96.
blairracd is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 12:38 AM #17
ShannanC's Avatar
ShannanC ShannanC is offline
Real Name: Shannan
ShannanC is on a distinguished road
ShannanC's Avatar
Real Name: Shannan
I mounted mine on stock 99 rims. I have a 2” body lift also. I’m also running 1.5” wheel spacers, but that is to partially counter body roll from the lift.
99 4runner Limited 2wd - K & N air filter, deck plate mod, ISR mod, 2" Fat Pat's body lift, Bilstein Tundra 5100s and Toytec 620lbs coils in front, LX450 coils and Bilstein Tundra 5100s in rear, extended end-links and panhard drop bracket, Maxxis MT-762 Bighorn 255/85/R16, JDM engine swap, sport hood, ARB front bumper, 199mm Tundra brake upgrade
ShannanC is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 11:32 AM #18
zcostilla zcostilla is offline
zcostilla is on a distinguished road
Did you do the lift first, get tires first, or do them at the same time?
zcostilla is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 02:27 PM #19
Lefty JD's Avatar
Lefty JD Lefty JD is offline
Lefty JD is on a distinguished road
Lefty JD's Avatar
255/85r16 DC extreme country’s.
~3” lift all around, maybe more like 3.75” in back. All in the suspension, no body lift. Did some firewall smacks for the front wheel wells, but nothing crazy. Had spacers initially to clear the stock upper control arms. Eventually put SPC uppers on and removed the spacers.
Rubs frame lightly at full lock and if wheels are turned and compressed 75% or more they rub the firewall.
Awesome clearance and road manners, I love this tire size and combo, been running it for 4 or 5 years.
As the fronts wear out I replace with new.
99 Limited
4.30 E-locker, 861’s/Bilstein ext travel
4xInno rear bumper w/swing out
Lefty JD is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 02:28 PM #20
Lefty JD's Avatar
Lefty JD's Avatar
99 Limited
Old 06-17-2020, 03:53 PM #21
Toy2play Toy2play is offline
Toy2play will become famous soon enough
Does anyone make a 255/85/16 AT in load C or D? Everything I find is in a load E.
97 Charged, lifted, armored, geared, locked SR5.
Toy2play is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 04:55 PM #22
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Nope, not that I'm aware of at least. It's a huge gap in the market. I want a C or D 255/86/16 AT tire, like a K02, SO badly that I've written BFG in the past, begging and linking 20+ offroad forum threads. LOL
The reason they're all load range E is because they're common tires for Dually trucks.
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 12:11 AM #23
I'm right there with you, would love KO2 in a 255. Cant even get a KO2 in load C or D in a 285/75/16. I'm currently running the KM2 in the 255/85/16 and love the size, but I dont need muds and want to switch to AT tire.
Old 06-18-2020, 12:17 PM #24
ArmArak's Avatar
ArmArak ArmArak is offline
ArmArak will become famous soon enough ArmArak will become famous soon enough
ArmArak's Avatar
Originally Posted by zcostilla View Post
Sorry to drag up an old thread, but I felt it was better than creating another one. Is anyone run 255/85R16s on the factory rims? If so, how much lift is needed? Can I get by with 2” using the narrower tires?
IMO 255/85R16 is the best size! I'm running the Toyo M/T 255/85R16 (which is a 33.5 inch tire) on the factory wheels. I have a 3.25 inch lift up front and almost 5 inches in the rear. The tires clear fine but the fronts do rub when flexed and turned on the trail. Which is why I would say 2 inch lift is not enough. A 2 inch lift + a 1.5 inch body lift would likely solve your issue, but best to just get a 3 inch lift imo.
Here's my lift thread that shows how the toyos look:Tundra/LC Lift + First Time Off Roading
ArmArak is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 10:36 AM #25
Lefty JD's Avatar
Lefty JD's Avatar
Yea, load range D is all there is. I wonder if treadwright would make a run of 255’s from our used ones. At least the sidewalks would be broken in and softer. Still would be heavy though.
99 Limited
Old 07-01-2020, 10:57 AM #26
For those of us who wish BFG would make an All Terrain Ko2 in the 255/85/16 size, please write them an email:
Sites-bfgoodrich-us-Site
The marketing team is the catch-all for this, which could be a dead end. However, I recieved acknowledgement on my email, and the person stated that it was a logical ask, and he would be getting it over to R&D for me. I linked about 30 threads from various offroad forums.
Let's make some noise! Lets overwhelm them-- it could move the needle
Old 07-03-2020, 09:27 AM #27
deves2 deves2 is offline
deves2 is on a distinguished road
I ran the factory 5 spoke with 255's and a 2.5" lift with no issues.
deves2 is offline   Reply With QuoteReply With Quote
guys , mud , r16 , size , tire
