Old 07-03-2019, 03:06 PM #16
Ripper238's Avatar
Ripper238's Avatar
Sounds like its clipping, you have no aftermarket amp to power the speakers? Whats the head units power output for the speakers? It may not be enough to run the speakers efficiently and you are getting clipping.
Always check your ground first, then check it again.
Old 07-03-2019, 04:53 PM #17
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
alot of info from others let me throw in a idea you can try to roll the balance and fade to isolate the speakers and see if that help determine if it is a speaker or which one it is.
plcfcng is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 11:21 PM #18
ThySenteth's Avatar
ThySenteth ThySenteth is offline
ThySenteth is on a distinguished road
ThySenteth's Avatar
That second, smaller, antenna wire that you taped off is for AM radio and does NOT need to be hooked up. Mine is taped off behind the dash as well so rest easy on that detail.
I installed a double din too and have zero problems. I also took out the stock amp as you did. My speakers are all oem. Are yours?
The 45 second interval is interesting.. I know on CANBUS vehicles a ping runs throughout the vehicle for diagnostics (like to let you know a brake light is suddenly out) but our vehicles aren’t equipped like that to my knowledge.
Are there any settings on the head unit that can be messed with for shits and giggles?
*EDIT: when the speakers cut out, is the track still playing or does it pause? Meaning if you were playing a song from your phone and singing along, do the words pick right back up to your singing or does the track pause and resume making you “off” from where you were in the song?
ThySenteth is offline   Reply With QuoteReply With Quote
Old 07-04-2019, 12:52 PM #19
hamsandwiches hamsandwiches is offline
hamsandwiches is on a distinguished road
The track is still playing when it happens - like parts of the song are cut out not paused.
Yes stock speaker. No idea what the output on the head unit is
Just added a new ground wire to a known good ground and got no difference.
What kind of setting could I mess with on the radio to possibly change it?
zoinks! there's scoob
hamsandwiches is offline   Reply With QuoteReply With Quote
Old 07-05-2019, 08:19 PM #20
BostonJon BostonJon is offline
BostonJon will become famous soon enough
I have a kenwood double din HU that I just installed. Removed the stock amp. Used the cheap metra wiring harness from amazon. Soldered all connections. Absolutely no issues. Maybe you have a bad HU? I was replacing an older kenwood that had an internal short.
BostonJon is offline   Reply With QuoteReply With Quote
Old 07-11-2019, 10:24 PM #21
If anyone was still wondering, it was the head unit. Ordered a cheap eBay double din and its working fine. Thanks folks!
Old 07-11-2019, 10:34 PM #22
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Originally Posted by TheDurk View Post
No, the red power wire should be on in either Accessory or Ignition On positions. The yellow is the constant feed to maintain settings and time. If either interrupts, the unit lights will flicker and that is not happening. So I don't think that is the problem. If it is not the speaker wiring, which may be triggering a safe mode shutdown, which leaves the light on, then I'd say the unit itself may be defective. Sure would be nice to swap in another one to see.
I'll call that on point.
My Backyard Frame Swap
antenna , radio , radios , stock , truck
CB radios Tooltime19 4th Gen T4Rs 23 02-12-2015 09:27 AM
Two way radios bofa Off Topic 6 04-11-2013 10:02 PM
anybody using CB Radios? 8ac1v1c Engines / Suspension / Wheels / Tires / Audio / Accessories 2 05-23-2006 06:47 PM
CB Radios AlexJet Engines / Suspension / Wheels / Tires / Audio / Accessories 19 11-04-2005 04:54 PM
CB radios flownosaj Engines / Suspension / Wheels / Tires / Audio / Accessories 4 10-11-2004 04:38 PM
