Old 07-01-2019, 07:52 PM #1
hamsandwiches hamsandwiches is offline
hamsandwiches is on a distinguished road
Question for those who know radios
Hey guys, you all helped me with my cluster issue so here I am with another electrical thing.
Thanks a lot for the help.
Installed a JVC KW-R910BT doubin din because my stock radio's lights were out and I wanted bluetooth.
Bought this wiring harness adapter:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Soldered/shrink tubed it to the radio's plug. Removed stock amp and plugged unit into two plugs.
Radio works perfectly across all inputs when truck is in accessory. Plays songs fine all the way through.
Once you start the truck, the speakers all cut in and out together (no sound) for really brief moments during a track. It happens in spells too about 45 seconds apart. Little 0.5-1 second cut outs but plenty long to make it really annoying. The radio remains powered during the cutting in and out episode as the screen and lights are still on - just choppy sound.
I put ferrite cores over all the radio connections to prevent EMI from the ignition system - no change
Could it be the antenna plugs? The new head unit had only one antenna port which I plugged the larger one into. The other I taped off and left unused. Could that be causing interference?
I can't imagine it would be an alternator issue - my truck makes 13.9-14.2v consistently.
Running out of ideas.
Thanks again!
zoinks! there's scoob
hamsandwiches is offline   Reply With QuoteReply With Quote
Old 07-01-2019, 07:58 PM #2
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Sounds like there's a short somewhere along one of the speaker wires. Is it happening on all speakers? To answer that, try panning/balancing it to one speaker at a time and see if it's all speakers that it's happening to, or just one particular speaker.
Do you have a seperate amplifier running the speakers? I ran all new speaker wires to the doors from the aftermarket amplifier I've got under the driver's seat. It could be the power to the amplifier that's shorting momentarily or a bad amp.
weekendclimber is offline   Reply With QuoteReply With Quote
Old 07-01-2019, 08:16 PM #3
Yes it happens with all the speakers together like there is no sound at all for the 0.5-1 second cut outs which happen in spurts.
The amp is in the head unit I would imagine since I removed the stock amp. All original speaker wires.
Everything works perfect with truck not running
Thanks
Old 07-02-2019, 10:43 AM #4
Real Name: Scott
Real Name: Scott
Thanks
I would start with checking that all the plugs are secured in the radio. After verifying that, then put a meter on the speakers and see if it's dropping voltage all together to them or not.
Old 07-02-2019, 11:07 AM #5
I will do that, just unsure why it would work perfect when key is in accessory (on, but not running)
No one has had this issue when adding an aftermarket radio to a third gen?
There were 2 antenna plugs going to stock HU, and only one slot for the larger one on the JVC, do they need to be combined or something?
Old 07-02-2019, 11:14 AM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
no antenna wires do NOT need to be combined. that's not your problem
Old 07-02-2019, 11:16 AM #7
Real Name: Scott
Real Name: Scott
To me, it sounds like something is jiggling loose and it's a matter of finding out where that's at. Worse case, it's in the radio, best case it's some of the speaker wiring.
As for the 2 antenna plugs, there are actually 2 antennas on these rigs. One up front, which is obvious, and one in the rear passenger window. If you look along the edges of that window, you can see what looks like heater wires similar to the rear window. This is actually a radio antenna.
Old 07-02-2019, 11:34 AM #8
I Understand
I don't see how it could be a loose connection because I did not mess with any speaker wiring and it was all working fine.
I soldered the connections - not crimp so not sure how they could be loose/jiggling?
So having the other antenna plug just sitting back there taped off is harmless?
There are 2 power wires that go the radio - the red and the yellow. Are they for power with engine running and power without engine running? Could the one for engine power (not just battery) not be beefy enough?
Thanks!
Old 07-02-2019, 11:48 AM #9
Real Name: Scott
Real Name: Scott
I Understand
It very well could be in the head unit. Do you happen to have another that you could test this with? It sounds like it was fine before swapping the new one it, so I'm leaning on something loose in the head unit (don't take the word of some dude on the internet thought, take it to a pro to have it looked at).
That's how I've got the head unit I use setup. Works just fine.
Thanks!
That's correct. One for constant power to keep the memory and clock going, and one with key on. Should not be a size issue (don't tell my wife).
Old 07-02-2019, 11:57 AM #10
I just matched up the colors to the harness in the link above - could switching the yellow and red be beneficial? Maybe they were miscolored?
Old 07-02-2019, 11:59 AM #11
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I Understand
Thanks!
No, the red power wire should be on in either Accessory or Ignition On positions. The yellow is the constant feed to maintain settings and time. If either interrupts, the unit lights will flicker and that is not happening. So I don't think that is the problem. If it is not the speaker wiring, which may be triggering a safe mode shutdown, which leaves the light on, then I'd say the unit itself may be defective. Sure would be nice to swap in another one to see.
I would try different inputs: cd, radio, aux., USB, whatever you have available, to rule out an issue there. What have you tried?
That said, when I install aftermarket units, I prefer to install my constant power direct to battery (with an inline fuse). I don't think it will help, but it is still better practice.
Another thing to try is an additional ground wire from the HU to the chassis. Bad grounding is often the source of electrical weirdness.
My Backyard Frame Swap
Old 07-02-2019, 12:16 PM #12
I thought it could be a bad ground - which might not be able to ground the slightly variable ignition voltage compared to the nearly constant battery voltage.
Zero change across all inputs, I tried AM, FM, bluetooth, AUX, etc
Guess bad ground is the most likely culprit?
Old 07-02-2019, 12:21 PM #13
Real Name: Scott
Real Name: Scott
^^^ This guy electricians!
Old 07-03-2019, 02:52 PM #14
Alright I'll buy a cheap 40 dollar ebay double din and see if that works.
I can't help but think it wouldn't be a bad ground because that ground wire connected to the old amp and worked perfect.
Old 07-03-2019, 02:57 PM #15
TheDurk's Avatar
TheDurk's Avatar
The electrical grounding gods laugh at simple human logic.
antenna , radio , radios , stock , truck
CB radios Tooltime19 4th Gen T4Rs 23 02-12-2015 09:27 AM
Two way radios bofa Off Topic 6 04-11-2013 10:02 PM
anybody using CB Radios? 8ac1v1c Engines / Suspension / Wheels / Tires / Audio / Accessories 2 05-23-2006 06:47 PM
CB Radios AlexJet Engines / Suspension / Wheels / Tires / Audio / Accessories 19 11-04-2005 04:54 PM
CB radios flownosaj Engines / Suspension / Wheels / Tires / Audio / Accessories 4 10-11-2004 04:38 PM
