Old 07-02-2019, 10:53 PM #1
MarkR85 MarkR85 is offline
MarkR85 is on a distinguished road
3rd Gen Weird Electric Motor Noise?
Searched all the forums and couldn't find anything that described what's going on with my 3rd Gen. Doesn't happen all the time, but there's a weird noise coming from the under the dashboard somewhere. It sounds like a small motor that whirls, stops, and changes direction. I thought it was the power antenna motor, but it's not. I also played with the AC controls and it didn't seem to make a difference. Any advise at all would be greatly appreciated, thanks!
MarkR85 is offline   Reply With QuoteReply With Quote
Old 07-02-2019, 11:38 PM #2
Makitso Makitso is offline
Makitso is on a distinguished road
Is it a Limited? If so it's probably the recirc door for the climate control.
Turn the key on with the engine off and push the recirc button and see
it it's the noise you hear.
Makitso is offline   Reply With QuoteReply With Quote
Old 07-02-2019, 11:44 PM #3
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
What year is the 4Runner? If it's an 01-02 and it makes the noise when starting the truck or after pressing the brake pedal 5-6 times, it's probably the brake booster pump motor which is mounted to the underside of the brake master cylinder and replaces the vacuum system used in earlier models.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 01:18 PM #4
Myjar89 Myjar89 is offline
Real Name: Cass
Myjar89 is on a distinguished road
Real Name: Cass
Recirc
I have a limited. There was click and grinding sounds coming from underneath my glove box. Had to replace the recirc door. It was easy but the part was around $250!
Myjar89 is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 01:24 PM #5
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
sounds a lot like my ABS but mine is older
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 07-04-2019, 04:07 PM #6
Sorry, it's a 2001 SR5 2WD (I know, but I'm not going off-roading)
@Makitso - It's not a Limited, so the climate control isn't digital, but it is electronic. And the sounds definitely mimics a lot of those noises. Could be the problem, but it's difficult to diagnose since pushing the button on and off doesn't necessarily cause the sound. It kind of just does it on it's own.
@rightyouareken - Thank you. It is a 2001, so I pumped the brake a few times and heard the brake booster pump you're referring to. Very distinctive sound, but not my issue.
@Myjar89 - I think it might be the problem, but did your recirc work? Because mine seems to. I have a different airflow when I press it. And it doesn't seem to affect the sounds immediately. I can absolutely imagine a recirc door getting stuck when I hear the sound, but I also feel like I would be able to recreate it on command when pushing the button. Thoughts? Also, I live fairly close to a junkyard, so I can probably pull another door if it's the problem. The real question is how do you get to it?
Old 07-05-2019, 02:42 PM #7
Real Name: Cass
Real Name: Cass
Everything worked on mine, except for the heat. It was sometimes hard to recreate the noise for me, seemed to have a mind of its own. It is located under the glovebox, left side, about where the center console and glovebox meet. 3 screws and a wire harness keep it in place.
Old 08-17-2020, 11:33 PM #8
Doubleab Doubleab is offline
Doubleab is on a distinguished road
I have a similar problem, the heat doesn’t work and there’s a clicking and buzzing noise coming from under the dash near the center console. When I turn the AC to cool all the weird noises stop. Is this a recirc door issue?
Doubleab is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 11:00 AM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
If your heat isn't working then it is likely the blend door (temp door) actuator
3rd , gen , motor , noise , weird
Electric motor-like noise from engine m85476585 4th Gen T4Rs 7 06-04-2019 04:02 AM
Electric motor noise under dash when stopping utmba95 4th Gen T4Rs 4 05-27-2015 06:32 PM
electric motor noise at idle rebelbayou 3rd gen T4Rs 5 09-02-2013 06:09 PM
Electric motor noise under dash/drivers side undercarriage WarEagleDoc 4th Gen T4Rs 8 09-15-2010 12:03 AM
Electric motor noise when coming to a stop?? tamiyatim 4th Gen T4Rs 6 02-20-2009 09:26 PM
