Old 07-05-2019, 04:19 PM #1
FelixFJ40 FelixFJ40 is offline
FelixFJ40 is on a distinguished road
Tweaked Rear Sway Bar Links - SS1.2
My rear suspension clanks when I go over any bumps, especially at an angle. I narrowed down to worn bushings in the rear sway bar links.
A closer look revealed that the links are actually being pushed at an angle. Almost as if the sway bar was pushing too far forward.
I have a Sonoran Steel 1.2 kit, installed by a previous owner. Is this an issue caused by the PO not having put on longer links when installing the kit? If I replace with longer links (2nd gen, etc.) will that likely get them to line up, again?
Or maybe something else is wrong? Or nothing at all?
Thanks for the help. I'm still learning the 4Runner suspension stuff.
'16 4Runner TE - KDDS - stock
'95 FZJ80 - Locked, 850J/863 w Ls, Nitto TrG 315s, IPOR sliders/rear/skid, Slee front
'02 4Runner - SS 1.2, BudBuilt and Savage skids, ARB, White Knuckle sliders
'75 FJ40 - kinda stock-ish, Aussie rear - Sold
FelixFJ40 is offline   Reply With QuoteReply With Quote
Old 07-05-2019, 04:20 PM #2
Here are photos.
Tweaked Rear Sway Bar Links - SS1.2-img-0527-jpg  Tweaked Rear Sway Bar Links - SS1.2-img-0528-jpg
Old 07-07-2019, 02:46 AM #3
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
Remove that middle washer - then no more metal on metal.
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
rideexileex is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 10:34 AM #4
ThySenteth's Avatar
ThySenteth ThySenteth is offline
ThySenteth is on a distinguished road
ThySenteth's Avatar
Is it tweaked like that on the other side? Going in towards the frame like that?
ThySenteth is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 11:16 AM #5
Yep. Both sides.
Old 07-10-2019, 02:38 PM #6
Can anyone confirm the length of the stock 3rd gen rear link?
Measured from the upper bracket to the center of the bolt on the bottom?
Old 07-10-2019, 03:52 PM #7
MStudt's Avatar
MStudt MStudt is online now
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
I can't confirm the length, but I can confirm where you can get better links. BY better I mean strong, and longer than OEM. I'm betting the clanking is coming from the washer in between bushings that's directly under the frame mount.
Mike
MStudt is online now   Reply With QuoteReply With Quote
Old 07-11-2019, 08:53 AM #8
Mike
Thanks, Mike, I've seen your products. They look great. The only thing holding me back is that the guy I spoke to at Sonoran Steel was adamant that with the sway bar extension brackets that come in their 1.2 kit (which I have), you need to use stock length links.
Old 07-11-2019, 09:05 AM #9
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
Looking at your pictures, while the links do look short, I still think there is a problem with the sway bar itself, it sure looks like it's bent inwards.
The SS1.2 "extensions" just raise the attachment point on the axle up by ~1 - 1.5". Considering the LC springs lift the rear by about 3" (or more when fresh), the links would end up being a little shorter than ideal. I "think" (not knowledgeable about suspension geometry) ideally, the sway bar should be horizontal at normal ride height.
When I put on my SS1.2 kit, I had also gotten new front sway bar links, but they ended up too short. I then got some Gen 2 rear links and put them in the front, and everything works great. My plan is to use the original front links in the back as they are a little longer and will flatten out the sway bar position. Just haven't gotten around to it yet.
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 07-11-2019, 09:08 AM #10
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
From the SS website regarding the rear sway bar brackets:
"You MUST use stock length rear 3rd gen 4Runner end links. Those are actually a bit too long already so your longer than stock links are not going to work."
Linky: Rear Sway Bar Brackets from our 1.2 Lift Kit - $47.20 : Sonoran Steel Fabrication LLC, Toyota Truck Parts
Old 07-11-2019, 10:41 AM #11
Understood. Looking at mine, they are at a sharper angle upward than I would think is good. Maybe as the springs settle overtime that will change the orientation.
Old 07-11-2019, 11:08 AM #12
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
I can provide stock length links for the rear, and extended for the front. Or, stock length all around.
I don't think your links are tweaked. I looks like they rotated, and are most likely frozen in that position due to age and wear. If you remove the metal the washer you'll get rid of the noise since you won't have metal on metal contact anymore.
Mike
bar , kit , links , rear , sway
Rear sway bar end links WHT003RZM 5th gen T4Rs 1 12-08-2016 04:17 AM
Front sway bar removal and extended rear sway bar links. morphious 4th Gen T4Rs 25 11-29-2015 01:36 PM
Rear sway bar links Thorgan112 3rd gen T4Rs 2 10-21-2013 07:48 PM
New rear sway bar links? seanshreds 3rd gen T4Rs 0 04-21-2013 03:07 AM
Rear sway bar end links? Crashnrondo 3rd gen T4Rs 18 02-01-2013 08:13 PM
