Old 07-07-2019, 01:25 AM #16
eddielasvegas eddielasvegas is offline
Real Name: Eddie
eddielasvegas has a spectacular aura about eddielasvegas has a spectacular aura about
Real Name: Eddie
Good point and I agree for the most part, but a couple things to think about for all that read this.
1) Why in the world would Toyota spend millions of dollars on R&D, etc. to allow an OEM to make the same part with the only different being a part # listed somewhere? Not exactly protecting their investment with that approach.
2) While the price difference annoys me (as well as the OP), I had little problem justifying the extra money for OE parts when I had the TB done on my LS 400. I recall it being about $400-$500 more, but was a fairly easy decision based on that extra money being amortized over 10 years and 100k miles.
Eddie
Originally Posted by NissanTechJake View Post
Let’s stick to what we actually know.
We could speculate all day long, but would love to see some actual evidence of this. It’s a little odd to think the same manufacturer creates 2 of the same seals to different standards in the manufacturing process.
Granted speculation probably has the poor guy who posted even more paranoid so he will spend 3 times the money lol.
2001 T4R SR5 - 180k miles and counting.
eddielasvegas is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 09:23 AM #17
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Ok, Manufacturing 101, no this isn't speculation, this is how things Actually work.
A part is designed, machines are setup to make the individual pieces of those parts, more to assemble into the "final". Despite the best efforts of all parties, raw materials have a slight variance, machines wear and start offering up parts that have slight variance in tolerances. Toyota (and other top tier buyers) will order exacting tolerances, the best that can be produced with the best of raw materials and all manufacturing tools in perfect/new condition. Parts are tested against those exacting standards, anything that doesn't meet them is discarded (though, it's more like 1 in 1,000 are tested, that range can vary depending on how much the buyer wants to spend).
It's worth understanding that Toyota may be buying 2nd tier bearing behind the military/aerospace industry... or 3rd tier. Just as Kia may be buying/installing that same bearing that Toyota passed on (with their 10 year/100k mile warranty). A lot of the additional cost comes from the additional testing done, some from being given priority to have first (or second, or third) pick. More for having to cover the different packaging/labeling costs and yet more to cover transportation and storage on Toyota's end.
The bottom line is that all of those manufactures have reject parts that are on the bleeding edge of being rejected and opt to recoup some cost by selling them rather than scrapping them. These same companies stand to lose their big contracts if their name is sullied in the selling off of extras (and there May be a clause in the contract that states the parts must meet XYZ standards). You really have no reason to fear buying fro the OEM manufacture, and the costs are lower simply because there are fewer costs associated. Sure, you're likely getting a part that's only 99% as good as a Toyota OEM, but when those same parts have an engineering margin of ~10% you're well within the realm of safety.
I've used various ebay timing belt sellers for years, running them to 90% of their rated life (so 90k miles on 100k mile recommended intervals ~ just my own personal margin of error).
Brian. is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 09:53 AM #18
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
I used an Aisin kit from Amazon on my T4R and was very happy with it. I have found that even OEM parts bought right from the dealer are not necessarily the same as what was installed on the assembly line, but they're as close as you can get. Mitsuboshi, Bando, NOK, Koyo and Aisin are definitely names you want to see on your components. That being said, I have installed hundreds, if not over a thousand timing belts over the last 30 years and have used Gates, Dayco, Continetal, Aisin, US Motor Works and a couple more I don't remember and with the exception of a few water pumps and several hydraulic tensioners (Dayco kit on Honda 3.5L V6) I've had very few problems, comebacks, or warranty work as a result of component failures.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 03:12 PM #19
2ndhandyotaman's Avatar
2ndhandyotaman 2ndhandyotaman is offline
2ndhandyotaman will become famous soon enough
Originally Posted by eddielasvegas View Post
Just because it's the same OEM does not mean it was made to the exact specs as Toyota's parts.
And I'd bet (but not much), that there is very small differences between Toyota parts and Asin parts for the exact same parts that look identical on the naked eye.
Eddie
Yup, and that's basically what I'm trying to verify. The eBay seller claims OEM parts, which to me would mean that they come through Toyota's distribution system. If the eBay seller is misleading folks with the 'OEM ' term and is selling good quality, but aftermarket parts, I'd just want to know exactly what I'd be getting. I know that the OE Vendors make very high quality aftermarket parts for our vehicles.
I'll apologize for veering this thread of track a bit, that wasn't my intention. I do thank NissianTechJake for posting pics of what he got in the kit, it's the 1st pics I recall anyone posting of the aircabinman kit.
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
2ndhandyotaman is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 06:34 PM #20
NissanTechJake NissanTechJake is offline
Real Name: Jake
NissanTechJake is on a distinguished road
Real Name: Jake
My kit is one of 2 different ones aircabinman sells for the same engine with slightly different prices and parts. I think one has the Toyota drive belts which are supposedly more identifiable but I can’t verify that from experience. He also in his listing lists the exact brands of the parts he is sending in a list down in the description.
NissanTechJake is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 06:49 PM #21
Real Name: Jake
Real Name: Jake
Thanks for your explanation, but I’m not sure how that translates to my original point.
Do you have any data to support that different materials or tolerances are required by toyota then NOK? Or another party? If anyone understands dealer mark up it’s ME. Price does not always signify better quality with all OEM parts. I almost always use OEM parts but I am NOT against buying off labeled products from the SAME manufacturers that produce our parts. I haven’t had any issues recommending them in the past. Hitachi, denso, Bosch are all good examples from a electronic standpoint.
Hope that makes more sense as to my original point I was trying to get across.
Old 07-07-2019, 09:14 PM #22
nissanh nissanh is offline
OP:
If you can afford OEM parts from the dealer (all parts in toyota boxes) then you can drive easy 150K miles without any issues. If you buy Aisin kit or Kabinairmen's kit, stick to 100K miles. The oil seals in cabin airmen's kit is surely not oem or NOK.
Like someone said ealier in this thread Toyota spends millions of $$ for R$D and they specify their suppliers (Mainly DENSO and AISIN) to get things into their specifications.
Honda also uses DENSO alternators (My cousin had to replace the OEM alternator on his 2011 pilot at 100K miles: complete failure), while my 4Runner has 214K, 2000 LC has 237K miles, 92 Corolla 278K miles and 1990 hilux 250K miles and all got OEM alternators with new brush kits (except 4R): This tells R&D of Toyota and their quality.
Old 07-08-2019, 11:04 AM #23
JohnMc JohnMc is online now
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
When I did my TB/WP on my 4Runner, I initially had the *bright* idea of saving a few bucks over Airbcabinman's prices on eBay by getting a kit that said it had 'genuine OEM parts'. It repeated that several times. Got it, Jenn-you-wine Oh Ee Em parts! So I ordered them, and when I got it... all the parts were in plain white boxes with 'OEM' printed on them. As in the brand name was 'OEM'. LOL, real good one. Got me. Lol. I immediately requested a return, they refunded 100% of my money, I was just out ~12$ return shipping.
Yeah, ordered an Aircabinman kit after that, all the parts seem to be genuine, as described, top notch quality. I think I've used his kits 3 times so far (some non-4Runner V6 Toyota's in the extended family fleet), my wife's put 2 of his kits on her '96.
JohnMc is online now   Reply With QuoteReply With Quote
Old 07-09-2019, 02:15 AM #24
Alpine95 Alpine95 is offline
Alpine95 is on a distinguished road
Back to the original question...aircabinman on ebay sells a kit that includes OEM parts. He also sells a kit that's not all OEM - if you're unsure, just message him and he'll point you in the right direction. The full OEM kit doesn't cost much more.
Just purchased and installed for my 02 and it's legit.
Alpine95 is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 10:28 AM #25
RumHam26 RumHam26 is offline
RumHam26 is on a distinguished road
Thanks everyone - I found the discussion helpful. I think I'm going to go with aircabinman's OEM kit. Only other thing I'll need is the crank pully bolt right?
RumHam26 is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 10:57 AM #26
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Yes, you'll want a new crank pulley bolt. I also replaced all the felt gasket material on the timing covers. I've been accused of having OCD too, so there's that.
weekendclimber is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 11:01 PM #27
I've been accused of the same - so I'd love more info. I've never done this job - where can I get the felt gasket material you speak of?
Old 07-09-2019, 11:35 PM #28
Real Name: Scott
Real Name: Scott
Timing Cover #1: 11328-20020
Timing Cover #2: 11329-20010
Timing Cover #3: 11319-20010
TOYOTA 4RUNNERVZN185L-GKPGKA - TOOL-ENGINE-FUEL - TIMING GEAR COVER REAR END PLATE | Japan Parts EU
Old 07-10-2019, 07:51 AM #29
19963.4lsr5 19963.4lsr5 is online now
I’ve bought three kits from “The Timing Belt Kit company” over the last 5 years and have been happy.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 07-10-2019, 08:50 AM #30
eanema eanema is offline
eanema is on a distinguished road
To the OP, I just did my timing belt this past weekend and dispite being pretty careful I somehow managed to break a tooth off the crank timing pulley that is picked up by the crankshaft position sensor. The engine would start and then die a second later. I found this thread:
engine starts, immediate stall after timing belt job
Just wanted to give you a heads up, don't do what I did .. now I'm stuck waiting for parts to arrive haha
Sent from my Pixel 2 using Tapatalk
eanema is offline   Reply With QuoteReply With Quote
belt , oem , parts , sellers , timing
eBay timing chain kits...anybody used them? lbhsbz 4th Gen T4Rs 9 06-20-2017 10:01 PM
Timing belt kits powrguy 3rd gen T4Rs 11 01-27-2015 06:42 PM
timing belt kits sal6430 4th Gen T4Rs 15 12-18-2014 06:32 PM
Timing Belt Kits on amazon & ebay, are they any good? ryankmasuda 3rd gen T4Rs 8 02-12-2011 08:20 AM
Aisin timing belt kits vs. Dayco Timing Belt Kits drz Maintenance/Detailing 1 10-11-2010 06:42 PM
