07-19-2019, 08:11 PM
#31
The aircabinman OEM kit just came in. It looks pretty much as described for the most part. The camshaft seals come in an unmarked bag as noted in the item description - water pump gasket and thermo gasket were unmarked as well (Aisin). The A/C belt came marked bando/denso/made in USA, the PS belt was marked mitsuboshi, and the alternator belt was marked Toyota. The rest of it was just as described. Thanks for all the tips. Now to attempt an install.
07-07-2021, 01:26 PM
#32
Real Name: Howard J. Turkstra
Don’t click on the spammer’s link - malware!
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
07-07-2021, 02:23 PM
#33
Real Name: Blair
Real Name: Blair
Originally Posted by MsIbuki
Yeah, I realized that the best thing to make such purchases is by eBay or Amazon. You can find there almost everything you want, and the best part is that you will pay less than others if you use these platforms. Moreover, if you're going to spend less, you can try different coupons and tickets found on Don'tPayFull. On their website, you can find discount coupons almost for each website available on the internet. Check it out by yourself.
You suck.
07-08-2021, 08:20 PM
#34
Originally Posted by RumHam26
I'm looking to buy an OEM timing belt kit from one of the sellers on eBay. It seems there are a few sellers with a decent amount of reviews that claim to use all OEM parts.
A guy recently told me to watch out for sellers that put cheap aftermarket parts in OEM boxes. So my question is - is there any way to confirm the authenticity of the parts in these timing belt kits. Are there any sellers you recommend?
Thanks!
just to add to the others,
When I did mine like 4-5 years ago, I got it on ebay and just searched for a very highly reviewed seller, with top credentials, and that toyota OEM kit was for sure not the cheapest but a good price. I obviously don't even remember who it was.
When the kit arrived, it was as on the seller'S description, all toyota OEM parts, and that kit is installed and now near the end of it's recommended maintenance of 100K miles end of life, no problem. Will do the same this winter/spring when I replace it again.
1998 4runner SR5
07-09-2021, 01:59 AM
#35
I'm all about saving money... but there HAS to be a reason the same parts from Toyota are $700 and the kit from Ebay is $300.
Question.. if you don't have the Know how, room, proper tools to do this job and you go to a dealer( or an indie shop) with your box of Ebay Goodies will they do the Job? or send you packing? Obviously there wont be a warrantee on the parts.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
07-09-2021, 02:10 AM
#36
where's that?
Currently 194K
Cheers
07-09-2021, 09:55 AM
#37
Originally Posted by giguchan
where's that?
The spam post was deleted. Someone quoted it right below the post you quoted (MsIbuki).
07-10-2021, 12:33 PM
#38
Ok fine...
Knowing me I'd be the one to click on it. My AV is pretty good so i think it would warn me when i do something stupid.
Currently 194K
Cheers
09-25-2021, 05:59 AM
#39
I purchased a timing belt kit for my V8 on eBay from jdmpartsman714. You get, for $446.20 including shipping:
AISIN WATER PUMP w/GASKET WPT800
KP WATER OUTLET GASKET 16341-50020
AISIN/ FOR TOYOTA SILICONE GLUE SEALANT
MITSUBOSHI TIMING BELT TB298
KOYO TENSIONER 13505-50030
KOYO IDLER TENSIONER 13503-50011
NTN HYDRAULIC TENSIONER 13540-50030
THO 2 CAMSHAFT SEALS 90311-38065
THO CRANKSHAFT SEAL 90311 - 43006/ 90311-A0001
BANDO/MITSUBOSHI SERPENTINE/DRIVE BELT 6PK2240
TAMA NTCL THERMOSTAT 90916-03100/ WV64TA-82A
THO THERMOSTAT GASKET 16346-50010
TOYOTA GENUINE COOLANT
GATES UPPER HOSE 22831
GATES LOWER HOSE 22832
I received this stuff and delivered it to my mechanic and he was pretty stunned at the quality of the parts in the kit. It even includes bolts. He charged me $403.73 to install all this stuff. Seems to work perfectly so far. The car has 109k miles and as such was clearly overdue for its first belt change.
Thanks!
09-25-2021, 11:22 AM
#41
Originally Posted by brillo_76
I have used 3 of aircabinman oem kits with no issue. They are actual oem parts or oem mfg parts depending in the kit you get. As far as I know they are the best kits out three.
Yep I have the aircabinman kit and no issues, runs smooth, and it's been like 7 years lol. Bout to get another one so I can have my mechanic replace em all for maintenance.
15 Piece 3.4L engine TIMING BELT KIT WATER PUMP Genuine & OE Manufacture Parts! | eBay
2001 Toyota 4Runner Limited. 231k miles.
07-21-2022, 04:20 PM
#42
looked at his kits. Very good price for pretty much all OEM stuff. I've put it in my favorites as I'll have to do the job this autumn or winter. Good suggestion
1998 4runner SR5
07-23-2022, 01:37 AM
#43
Real Name: John
Real Name: John
Y'all should already know that, All the Japanese car makers DO NOT make their own parts! They get it made from manufacturing company and Superseed it with their own Brand Name!
John
2002 TCM Grey Sport Edition
07-23-2022, 02:16 AM
#44
Real Name: 3 Bears
Real Name: 3 Bears
i hope they are as good as reviews etc as I just did this about 2 weeks ago with the kit ...the lower one without cam or crank seals or drive belts. I had no cam or crank leaks and the drive belts i had new on the shelf already.
oh and previous job ( before my ownership) had jiggle valve at 12.
07-23-2022, 08:15 AM
#45
Real Name: Patrick
Real Name: Patrick
That’s every mass producing auto maker not just Japanese auto manufacturers.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
