Old 07-07-2019, 11:35 PM #1
sam.basye's Avatar
sam.basye sam.basye is offline
sam.basye is on a distinguished road
sam.basye's Avatar
A/C not blowing cold. Charged w/ All New Parts
Recently had the compressor take a dump so I replaced just about everything. All new oem Denso parts: Compressor, Condenser, Drier, Evaporator, Expansion valve, and Resistor.
Brought it to the dealer to have it leak tested and recharged. No leaks and it blew cool when I picked it up, but I didn’t think it was as cold as it should be.
I drove around for a week or so to make sure it wasn’t just me being weird and I’m now sure it’s not right.
I measured the temp on two difference days.
Full COLD Setting with Fan on HIGH and A/C button ON after 5 min of starting the car in the shade.
Outside 81°, center vent 65°
Outside 90°, center vent 74°
Blower motor works fine, fan is clean and clear, and the recirculation/outside air actuator/door works properly
The air blows strong and fan speed accordingly with the auto climate control, but it’s just not cold enough.
I can see bubbles in the drier sight glass while it’s running.
Any suggestions as to what’s causing the lack of cooling?
sam.basye is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 12:48 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Those numbers are way, way off. Vent temps s/b closer to 40-45, you s/b 'freezing' and want to turn down blower - mine numbs me with 'crotch' vent even on low after 20 mins when near 100 degrees here in Texas. There shouldn't be 'too' many bubbles when operating in hot temps after 5 mins, just a small stream, almost countable. Is that about the volume you see?
No a/c expert here but based on your info I would find someone who knows has /knows how to use a/c gauges. It's the only true way (not to mention safe) to know the condition the system is operating at. Then you'll know whether there is blockage, insufficient freon or whatever. Or if you have some confidence try one of those freon refill cans that come with a gauge, it will at least tell you if under/filled/over filled.
Guessing the space between the a/c condensor and radiator has been cleared of any debris? A/C depend on excellent air flow, this is one of the places is has ot be really good, the other being the evaporator.
Luck and enjoy the Runner.
Old 07-08-2019, 01:17 AM #3
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
No chance the dealer installed the wrong type of refrigerant?
pluton is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 08:40 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Your ac system is not fully charged. According to the FSM "A fully charged system is indicated by the sight glass being free of any bubbles." This is checked at around 1500 RPM's though not at idle.
Old 07-08-2019, 08:41 AM #5
Real Name: Patrick
Real Name: Patrick
Different refrigerant systems have different fittings. There's no way to charge an r134a system with anything but r134a refrigerant.
Old 07-08-2019, 09:39 AM #6
sam.basye's Avatar
sam.basye's Avatar
Thanks guys!
The whole reason I brought it to the Dealer to recharge was so I didn’t screw it up. Lol
Here is what it looks like running, and with the compressor off (system on).
Looks frothy, like lots of fine bubbles whizzing by. Looks the same at 1500rpm, bubbles just whizz by a little faster.
Looks like clear water when off.
Old 07-08-2019, 10:00 AM #7
absalom's Avatar
absalom absalom is offline
Real Name: Jordan
absalom has a spectacular aura about absalom has a spectacular aura about
absalom's Avatar
Real Name: Jordan
Charging your own AC with a vacuum pump and manifold gauge set is pretty simple and highly effective, just in case you’ve lost faith in outsourcing this job.
absalom is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 10:01 AM #8
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Check out page AC-3 of FSM, your low on Freon if seeing bubbles. You should see no bubbles, just flow of liquid in site-glass.
Does your paperwork say how much Freon they put in ? 23-24 oz is what a empty system should have had put in.
I would take it back to place and say get it right, you should be seeing 38-42* air from duct.
What I get with replacing condensor and drier 24oz of freon.
Old 07-08-2019, 11:50 AM #9
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
I agree with all the other sentiments that there's an incorrect amount of refrigerant.... I use the term "incorrect" because too MUCH will result in the same situation, where it just doesn't cool right. Not saying that's what you have right now, but something to be aware of (don't just dump in more, in other words ~ moar doesn't equal better).
This should all be tested and checked with a manifold gauge that gives high and low side pressures. While the sight-glass is good for spot checks, it's not enough to get the best result from your system.
Brian. is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 01:11 PM #10
sam.basye's Avatar
sam.basye's Avatar
Here’s the receipt receipt I got.
No specific amount of refrigerant listed.
I’ll be taking it back tomorrow or the next day to have them hopefully fix it. Lol
Old 07-08-2019, 02:00 PM #11
vipergrhd's Avatar
vipergrhd vipergrhd is offline
vipergrhd is on a distinguished road
vipergrhd's Avatar
Did you put oil in each individual parts or you just left it in the compressor? The dealer may have not put it in a vacuum long enough and also not enough refrigerant. In most cases you need to put the system under vacuum for a min of 30 min. but in your case since you did the install I would do it for at least 2-3 hours.
I just noticed that your receipt have extra charges, what exactly is a $32 expandable and $5 disposal fee? There was nothing to dispose off, all they did was recharge your system.
vipergrhd is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 02:16 PM #12
samarinta3 samarinta3 is offline
samarinta3 is on a distinguished road
I have the same problem. I changed condenser and dryer receiver but still wasn't cold enough then changed my compressor and still the same. Now I'm changing my evaporator and expansion valve.
samarinta3 is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 02:18 PM #13
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
That is why they call it the Stealership. Rags and soap get very costly there, to the tune of $32 for Snap On soap it looks like.
Looks to be undercharged.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 02:32 PM #14
vipergrhd's Avatar
vipergrhd's Avatar
Stealership
Yeah I know, I was a dealership mechanic for 22 years before I went to fleet.If you let them get away with it they just keep robbing you.
Old 07-08-2019, 02:44 PM #15
Brian.'s Avatar
Brian.'s Avatar
Ouch, for anyone reading this in the future, you can buy your own AC vacuum and gauges for ~$130 (looks like Most of them on Amazon are around there, some cheaper, some more expensive ~ more like $160 from Harbor Freight). Anytime I can buy tools for less than the cost of hiring someone, it's a win.
Anyway, no where did they list anything that indicates volume (weight) of charge. Good point about the oil above too, as too much there will also lower the cooling efficiency, but not THAT much.
air , cold , fan , it’s , works
Heater only blowing cold air!!!! Dog5911 4th Gen T4Rs 9 08-27-2018 11:37 AM
2014 - A/C isn't blowing cold jthoms1 5th gen T4Rs 7 07-11-2017 09:08 PM
AC fully charged blowing 80% cool. No more, no less. runnyrunnerton 3rd gen T4Rs 5 08-19-2013 08:17 AM
Heater Blowing COLD 95Blue4Runner 4th Gen T4Rs 1 12-07-2005 09:31 PM
Keeping your battery charged in cold weather Thai Maintenance/Detailing 0 02-10-2003 08:09 PM
