Transmission Fluid Smell after drain/fill?
Anyone ever had a reoccurring transmission fluid smell they can’t find?
Recently did a drain/fill on transmission (drain pan, disconnected cooler line and flushed fluid 1 qt at a time). I have done this numerous times over the years, never with issue.
However I have a problem lately with a transmission fluid smell when I come to a stop. At first I thought it was because I spilled some, so I powerwashed the motor real well, and that didn’t fix it. Checked fluid level numerous times to make sure I am not over filled, it’s sitting right where it needs to. Even replaced the dipstick o-ring without an success. Over the holiday weekend drove over 2k miles down to texas and back without any issues. Only smelling the fluid upon stopping, none while driving. Connections to the external cooler are tight and dry (rad is bypassed). Checked the power steering and there is not any leaks there.
I have crawled underneath it and do not observe any wet areas, let alone any puddles of fluid. Brake cleaned pan and it's dry still.
Does anyone have any suggestions?
