Old 07-09-2019, 06:54 PM #1
judoant's Avatar
judoant judoant is offline
judoant is on a distinguished road
judoant's Avatar
Need to change my rear lift??
I currently run the Toytec Ultimate lift. It consists of OME 890's in the rear with OME shocks. I have a full plate bumper, a 12" subwoofer and a plastic box with tools, recovery gear, ect. I would say about 300 lbs total. I also load down with camping gear and people occasionally.
The rear sits 22.5 from fender to center cap. I love the ride but my issue is that there is only 2" from axle to bump stop and when I go over mild bumps on the road I bottom out. I talked to Toytec and they recommended OME 906's.
I purchased the 906's and 10mm trim packs, but I am having doubts this is going to give me what I want. I don't love the idea of bags, but if that's what I need so be it.
I want 22.5 - 23.5 lift in the rear, good off road flex and no more bottoming out with load. Sooner than later I might want to run 33's.
Stay with 906? Ditch the 906 and go 891? LC coils? I have not done my research but I know its an option. Air Bags?
Please provide thoughts. Thanks
99 4 Runner Limited. 3" Toytec Ultimate lift with SuperFlex rear coils. 231mm Tundra calipers. Rear diff breather extension. 285/75-16 Nitto Trail Grapplers. Savage full skids & sliders w/ kickout. ISR mod. LED gauges. Shrockworks front plate bumper w/ loop. 4xInnovations rear plate bumper.
judoant is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 08:20 PM #2
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
I have no idea why Toytec would recommend 906’s if you’re trying to be at or above 22.5” with a load like that. Even though their spring rate is higher, they’re a much shorter coil. The 891 probably won’t be enough to keep you above 22.5” either with the load you run plus extra camping gear and people unless perhaps the trim packers help get you there. I would think the Superflex are what you want since they are 23.5” hub to fender unloaded (on my rig with no added weight and stock inner cone bump stops) and are designed to keep you at 23” with a 400 lb load.
Here’s a couple links for good reading while I’m at it.
Cruiser Outfitters
024RCB ToyTec Superflex Rear Coils (96-02 4Runner)
ToyTec SuperFlex Rear Spring INFO Thread
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 10:35 PM #3
judoant's Avatar
judoant's Avatar
I have been second guessing the recommendations also and have held off installing the 906. I am continuing research of the super flex. I also see they have a 3” spring.
Old 07-09-2019, 10:46 PM #4
JohnOfTheJungle JohnOfTheJungle is offline
JohnOfTheJungle will become famous soon enough
Definitely don’t do the 906 - i had them, with stock bumper + about 100lbs In back and I was only at 21” hub to fender.
I have 891 now and carry about 100 lbs in the back at all times. I am now 22.75” hub to fender.
I’m pretty sure once I do put a bumper on the back + sliders I will most likely go up to OME 861.
It also does seem like I get 1/2” less lift than most people on the back with each setup. My body bushings in the back may be compressed so I will probably get the poly ones too.
1997 Limited 4x4 3.4l 199k E-locker Blue Wire Mod | 255/85 r16 Maxxis Bighorn MT - LX450 9 wrap + Tokico black rear | Front: 2.5" King Coilover set @ 2" lift | True North Fab Front Bumper + Warn m8000 + Baja Designs Squadron Sport | Custom Sliders | NguyenWorks Rear Bumper + Tire Swingout
JohnOfTheJungle is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 10:50 PM #5
judoant's Avatar
judoant's Avatar
That reminds me. I have full savage plate skids and sliders.
Thanks for the feedback.
Old 07-10-2019, 01:02 PM #6
I'm a bit confused here. You have a ~2.5" lift over stock, and you only have 2" from axle to bump stop? Are you talking about the inner cone bump stops (they act more like helper springs) or the hard bump stops on the frame?
Have you put bump stop extensions on or something? At a 20" ride height with stock bumps, the cones are about 1.5" from the axle and the frame bump stops are closer to 3.5"
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-10-2019, 01:08 PM #7
judoant's Avatar
judoant's Avatar
Yes. I have toytec bump stop extenders in place on the frame.
I ordered the Toytec Superflex this morning. Sucks UPS wants $50 to return them.
Old 07-10-2019, 01:19 PM #8
Unless the OME shocks you have on there require the bump stop extensions, why not remove the bump stop spacers? That will get you the bump travel you are looking for. You can also put 10mm trim packers on both sides to just get a touch more lift.
Old 07-10-2019, 01:25 PM #9
judoant's Avatar
judoant's Avatar
I put them on there because they came with the lift kit. The rear shocks are OME 60028. I do not know if they need these extenders or not.
The OME 890's on there now have settled to give me 22.5 between hub and fender and I would like to be closer to 23.5. I also tend to carry a lot of gear when wheeling.
Old 07-10-2019, 02:40 PM #10
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Or 1996-2002 4-Runner 2WD/4WD Steel Rear 1.5" Lift Kit | eBay
Luck and enjoy the Runner.
Old 07-15-2019, 11:04 PM #11
judoant's Avatar
judoant's Avatar
So I got the Superflex springs in there
Before with 4 year old 890’s I was at 22.5
Now with superflex I’m at 23.25 driver. 23.5 passenger. Yesterday when I installed them I was at 24. Both sides before a fill up.
That’s quite a bit of settling in 24 hours?? I hope they don’t settle any more. I was hoping both sides would end up at 23.5 or more.
Oh. And these were a pain to get in. The 890 came right out. I had to get a compressor to get these in.
Old 07-16-2019, 12:34 PM #12
Did you loosen the pivot bolts on both ends of all 5 links? Every time you change ride height, you should loosen all the pivot bolts and re-tighten at the new ride height... Also significantly helps installation of springs, shocks, etc.
Old 07-16-2019, 12:41 PM #13
Fishwerks's Avatar
Fishwerks Fishwerks is offline
Real Name: Chris
Fishwerks will become famous soon enough Fishwerks will become famous soon enough
Fishwerks's Avatar
Real Name: Chris
If the superflexes settle too much you could go with OME 861s. They may give a bit more lift than you want but they will handle the weight. I'm not sure what my hub to fender is in the rear but I can measure if you want a comparison point.
Fishwerks' Photo/Build Thread 2000 SR5 l White on White l 35s l Supercharged
2010 Trail Edition l Salsa Red Pearl l Stock
Instagram
Fishwerks is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 04:21 PM #14
judoant's Avatar
judoant's Avatar
I did not. Never did that with the OME 890's. Good call tho.
Old 07-16-2019, 05:32 PM #15
judoant's Avatar
judoant's Avatar
post install / settling pic. 23.5 RR / 22.5 FR.
I think i want 285's now. lol
Need to change my rear lift??-img_4261-jpg
lift , load , love , ome , rear
Can I change the color of my ECT, A/C, rear defrost, and rear window switches? starclassic 3rd gen T4Rs 3 03-23-2017 10:53 PM
Change lift or Modify? Asugm13 5th gen T4Rs 5 01-16-2017 01:25 PM
Toytec Ultimate lift kit with superflex rear coils - not enough rear lift.... aleks77 3rd gen T4Rs 8 04-22-2015 08:23 AM
Rear Hatch change from lift to swinging skydondive 4th Gen T4Rs 8 06-30-2014 03:05 PM
