Old 07-10-2019, 11:35 AM #1
adder70 adder70 is offline
adder70 is an unknown quantity at this point
Intake Air hose leak: Temp fix?
My intake air hose is cracking and leaking, causing lean bank codes. (Shop said it, and attached pic shows apparent cracking (close to throttle body).)
I'm probably going to go with a K&N intake since I'd already be spending on replacing that piece. Is there a temporary fix for a trip I'm leaving on tomorrow? It just needs to last for about 700 miles over a week or so. I'm even passing the Summit racing south of Atlanta, so might even be able to pick up the intake in person and avoid shipping and/or local parts store costs.
Edit: I'm fine with tape or some sort of glue/gel as long as it won't harm anything (other than the hose; it's obviously already trash).
Thanks,
Corey
Intake Air hose leak: Temp fix?-4runnerairhose-jpg
adder70 is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 11:51 AM #2
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
Silicone fusion tape.
Amazon - Silicone Fusion Tape
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 11:52 AM #3
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
For a temporary fix I would go with some Gorilla tape or duct tape. Shouldn’t cause any harm and only for a week or so no issues.
Sarki is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 11:54 AM #4
ThySenteth's Avatar
ThySenteth ThySenteth is offline
ThySenteth is on a distinguished road
ThySenteth's Avatar
If only there was a tape of some sort that could be used for air ducts.
lol you could probably drive as is without doing anything and it'd be fine. Mine was cracked once for god knows how long before I noticed it..
ThySenteth is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 12:02 PM #5
Yeah, and of course AC ducts have the same pressure difference as the intake hose! (Actually, I don't know the intake pressure differential, but I do know that AC manufacturers say that "duct tape" is actually NOT to be used on ducts. The tape they use now is apparently much better at lasting for years/decades and maintaining an airtight seal.)
I just wanted to be sure that something that seemed safe wasn't actually going to cause major damage (i.e. tape fragment (or sticky residue) gets sucked in and destroys major engine components))
Old 07-10-2019, 12:05 PM #6
Haven't measured fuel economy (been bad about that the last couple of years) but pretty sure it's using more fuel, probably using a "protect the engine" mode with a rich fuel mixture, so a temp fix should help with fuel costs on the trip.
Old 07-10-2019, 02:29 PM #7
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
I used RTV silicon in the same spot a while back when I noticed it was cracking. It flexes with the hose and holds up great right there. Just make sure to let it cure completely as a precaution before running the engine at all.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 02:34 PM #8
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Why not fix it right with a $12.55 part off amazon, takes 5 mins to put on. No more lean codes and Reliable fix! 700 miles is a long time to risk it.....
https://www.amazon.com/MOSTPLUS-Inta...Toyota+4Runner
Luck and enjoy that Runner.
Old 07-11-2019, 01:22 AM #9
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
^^This is the easiest and least likely to fail in high underhood temps. Most auto parts chain stores have this. Duct and vinyl electrical tape won't like the hot, roasty atmosphere in the engine compartment.
Alternative: Get a huge diameter piece of electrical shrink wrap, heat gun it in place. RTV is OK also if you can wait for it to cure.
pluton is offline   Reply With QuoteReply With Quote
air , cracking , fix , hose , intake
Coolant hose under the intake manifold leak - 2004 4RUNNER V6 PTPT2002 4th Gen T4Rs 2 04-10-2021 08:16 AM
Air intake hose? Link12 3rd gen T4Rs 3 02-04-2018 09:41 PM
HPS High Temp Reinforced Silicone Radiator Hose Kits for FJ Cruiser! TotalAutomotiveLV FJ Cruiser 5 08-17-2016 03:29 PM
Radiator hose temp difference issue kingin 3rd gen T4Rs 13 10-16-2014 10:55 PM
