Old 07-10-2019, 11:03 PM #1
madbomber08's Avatar
madbomber08 madbomber08 is offline
madbomber08 is on a distinguished road
SPC UCA and tire clearance concerns (pics inside)
Specs:
Sonoran Steel 1.2
2014 4runner Trail edition wheels
NO wheel spacer
285/70/17 BFG Ko2
The photos show how much clearance there is between the tire and and knuckle. I cannot fit my finger past the first knuckle as shown. I would say no more than 0.5" clearance, possibly less. I plan to take a 1000ish mile trip next week and don't want any surprises. The people I've showed didn't think it was a problem unless I hit a major bump going fast it could deform the tire enough to rub for a split second. The only real issue I see is if offroading it and compressing the front suspension, the tire very possibly to start to rub. However I don't plan to do any serious offroading on this trip, a gravel/dirt road would be the most offroading I'd do.
Should I be concerned?
1707E2E2-14BB-4F1A-8E63-684B9D500CC5
01BAE8CD-63AF-4A9D-A632-7B97944FAE95
1997 4runner. Sr5. 5speed. 191k.
madbomber08 is offline   Reply With QuoteReply With Quote
Old 07-11-2019, 12:08 AM #2
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
Well, if the tire is deflecting that much at the top where it might contact, you probably have bigger problems. I had much less clearance than that with the stock UCAs and never contacted. You should be good but it never hurts to keep a watch and see if there ends up being any contact
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 07-11-2019, 05:02 AM #3
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
When I first lifted mine and installed SPCs, the tire shop I went to for new tires and an alignment refused to mount 285s because of the small clearance there, so I ordered a set of spacers.
...then again, they also claimed they couldn't align it because it was too tall with a 3" lift
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 07-11-2019, 09:47 AM #4
deves2 deves2 is offline
deves2 is on a distinguished road
you will be fine. your tire will NOT deform at the top. If it does you are in a serious crash or rolling sideways off a cliff.
that is actually a lot of clearance.
deves2 is offline   Reply With QuoteReply With Quote
Old 07-11-2019, 11:50 AM #5
Funny you mention that. The tire shop I went to advised not putting the tires on it because they'd rub. Almost had me convinced. Then later on that same day I realized, why not try it? It'd be worth the mount and dismount fee to see for my own eyes that it wouldn't work. So I drove back to the dealership and told them to try it. Lo and behold it works, and I shouldn't need to run spacers.
The same shop aligned it also, and it was my mistake for not telling them only to adjust the upper control arms since I dialed in the lower by myself. So I go out to see the lower cams all in different positions after they aligned it. I'm going back friday to get it realigned to have some more positive caster.
Old 07-11-2019, 01:24 PM #6
1/2" of tire clearance there is huge! The knuckle and tire fixed in location to each other. Lift the front and check at full droop - that will be worst case. The upper arm will get closer to the tire, but it looks like you will still have room.
I've run street car tires with 3mm or less clearance with no rubbing... I'd leave a bit more for a truck tire, but you are fine there.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-15-2019, 01:16 PM #7
Thanks for the advice! I did end up buying a couple of 1/4" wheel spacers in case I do need to run my steel spare which won't work up front with the tundra calipers.
Old 09-19-2021, 02:43 PM #8
BirdDog2025 BirdDog2025 is offline
Real Name: Jake
BirdDog2025 is on a distinguished road
Real Name: Jake
Smile Similar Concern
Newbie to the forum.....
I just installed Fuel Vector 20x9, +19 wheels with 275/55/20 Michelin LTX M/S on a 2015 4 Runner LTD. Put a Rough Country 2" level kit on the front.
I have about a finger width between the tire and the UCA knuckle....
I assume it will be safe with no issues also. Thinking about aftermarket Old Man Emu UCAs. They seem a bit smaller, tubular and the knuckle isn't as large. Could provide a bit more clearance???
Appreciate any thoughts!
Thanks!
BirdDog2025 is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 05:40 PM #9
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Thanks!
I think you are looking for the 5th Gen forum: https://www.toyota-4runner.org/5th-gen-t4rs/
clearance , knuckle , offroading , rub , tire
Tire clearance and tire pressure wfo9 5th gen T4Rs 8 02-12-2018 01:28 AM
Trimming an ARB for better clearance w/pics J-money$$$ 3rd gen T4Rs 21 06-23-2014 10:42 PM
Tire Clearance jhowell 3rd gen T4Rs 4 04-18-2013 01:27 PM
tire clearance buckin 3rd gen T4Rs 4 01-20-2013 04:04 PM
Tire clearance ? Gstick 5th gen T4Rs 6 12-17-2010 08:45 PM
