Old 07-16-2019, 10:43 AM #16
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Originally Posted by MaineRunna View Post
All gen 3 4runners are built in Japan so it's a Japanese frame. It's not so much a flawed frame as it's just old. If this was a 70's Bronco, Scout, CJ, Toyota pickup or any boxed frame vehicle it would be rusted out in 4 years in the rust belt. The fact that these have held up so well is a testament to how awesome they are! VernySanders your frame is totally fixable. Take a holesaw and drill a few drain holes in the bottom of your frame after you get it fixed.
I'm going to for sure!! I never realized the questionable drainage these have and always being up at the sand dunes creates the need for some bigger holes. Thanks!
VernySanders is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 10:46 AM #17
Real Name: Werner
Real Name: Werner
Originally Posted by dogtail View Post
You can blame it on the muffler heat, road surface at shoulder side holding more slush run off, or whatever. Even if Toyota designed these with straight pipes out the front fenders, they would still rot out. Its not just the frame that's taking a beating either. Rust damage is not exclusive to 3rd gen 4runners.
You can listen to the frame repair shops or dealers telling you theories on rust.....or you can do what people that keep their rigs from rusting out do.
Here's a pic of my muffler next to my frame with 363K that lived in the rust belt its whole life, original paint. The only thing I do is 1 hour per year of rustproofing, that's it.
Seriously its so super simple to prevent, its too bad more people don't know.
sadly I've only owned my truck a year or it would also look like that. I'm in the middle of doing a full undercarriage resto. It's honestly not even bad mostly just the back. Wire wheel then xylene then phosphoric acid then POR-15 and Eastwood coating on the inside which I'm going to clean out with a chain attached to the end of a steel wire ran through PVC. Put it on a high powered drill and get as much of the shit out as possible then a good washing and spray it.
Old 08-02-2019, 08:21 PM #18
Real Name: Werner
Real Name: Werner
Got the frame rot completely cut out and patched. Also added a Borla XR1 muffler as well. Cant recommend this enough!! The Gibson catback honestly sounded like a ricer on the videos I saw and the flowmaster 40 series seems like it would be extremely loud and drone which this Borla does NOT do. Fortunately the only rot I had was this area and now it's taken care of so I will now continue restoring the rest of the undercarriage! I also dumped my exhaust in front of the rear axel instead of pointlessly running it back past the rear bumper. Turned out great! Deleted one of my cats already in the past and nodded the rear o2 sensor. Had 3 inch pipe from that so I continued with the 3inch into the muffler and out of it as well.
Awe man... frame rot-screenshot_20190802-191209_gallery-jpg  Awe man... frame rot-screenshot_20190802-191205_gallery-jpg  Awe man... frame rot-screenshot_20190802-191203_gallery-jpg
Old 08-02-2019, 09:04 PM #19
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
that is going to sound so cool when you go thru a couple feet of water, blub blub blub...
so you like that Borla, I will be looking here for my exhaust setup in a little bit. any chance you can post a video of it running? I will give you my free internet points.
Old 08-02-2019, 09:54 PM #20
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Hopefully where the exhaust blows out like that doesn't heat up your rear end and dif. I had my tail pipe break off and left it a couple weeks, it was blowing right at the rear end. It heated up the lube and took out my new pinion seal.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 11:08 PM #21
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
This is probably a dumb question but I know they had anti-rust undercoating available 1996-2002 so why wasn't it applied to all T4R's sold; especially in the rust belt as part of the dealer prep? At minimum one would think this would have been option that was heavily recommended. A couple hundred bucks spent then would have made a huge difference in these rigs now.
Hindsight is always 2020 I guess... (or in about 5 months).
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 08-03-2019, 10:12 AM #22
Real Name: Werner
Real Name: Werner
I've been trying to get a good video of it! Obviously the video is great quality but the sound isn't it's hard to capture the sound of the exhaust.
This Is the clip that made me go with the XR1
YouTube
And let me say it for sure sounds exactly like that in person but better. Idle sounds amazing too
Old 08-03-2019, 10:13 AM #23
Real Name: Werner
Real Name: Werner
That is a very good point! However the exhaust is level with the bottom of the axel so especially while driving there should be no heat or at least not enough to hurt anything. The size difference of this muffler is amazing too. Far smaller dimensions and it doesnt even heat up the frame so maybe if I do end up driving it this winter the inside of the rail wont be soaked 24/7 lol
Old 08-03-2019, 10:17 AM #24
Real Name: Werner
Real Name: Werner
Well in all fairness these trucks did come with a decent rust proofing from the factory. If you think about it it's extremely rare to see Rot on inner fender wheel wells or body rust around the fenders because of the way they're sealed up. More commonly I see rust forming around windows from drainage from the rubber seals. My dads runner is like the rust eze guys on the first cars movie however. But that vehicle has never left the state of Michigan and people out here really dont take care of the vehicles they call their "winter beaters" as I'm sure his was for many people here. I honestly thing better drainage would have been more effective than further rustproofing. The guy that welded my frame sprayed rubber on it without asking me and it kinda pissed me off because now I've got to strip all of that off and paint with POR-15. He better have done a good job on it and not just tried to cover up shotty work. It does look good though so well see.
Old 08-03-2019, 02:53 PM #25
Colorado buff Colorado buff is offline
Colorado buff will become famous soon enough
I hear you the front left and right of my frame has rust. Had to get a shop to cut out the rust. They did a great job. Did the same thing 5 years ago with the middle right and left side interior of the frame and it’s still solid. Rust doesn’t have to end the life of a vehicle. Especially if you are thinking of how much money a different car would cost.
Awe man... frame rot-10164961-9820-4ae6-bc5c-1481cb96c6b3-jpg  Awe man... frame rot-b1627687-2dea-4997-88f3-82d95455577b-jpg  Awe man... frame rot-03cd222b-a360-4372-b6ec-7d76355554f1-jpeg  Awe man... frame rot-bce3dceb-982b-45d6-878f-97e6535f83bd-jpg  Awe man... frame rot-6ad18d62-efa2-4abd-8ce0-fa24b78e2ffe-jpg  Awe man... frame rot-0654f1e9-6cb7-4f75-84ac-dbe381b15bb9-jpg
Colorado buff is offline   Reply With QuoteReply With Quote
Old 08-04-2019, 10:06 PM #26
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I have 5 3rd Gens and live in the rust belt. I have been experimenting for years on how to not only strengthen these frames, but seal them while fixing the rot in the frames.
The best way I have found so far (though very time consuming) is to cut the bottom of the frame out (as you can then easily see what the inside frame clean it out) and plate the inside of the frame by grinding slits where your plates meet and welding it all back together. I even paint the plates. Then before resealing the bottom back up using 1/8 plate as well I give it a major heavy coat of fluid film inside the frame. This way you hide almost all of your work, and can grind the outside welds smooth. Repaint the frame and fluid film it again.. By removing all the frame holes, this seals the frame from dirt. I use 1/8 in plate. This basically gives a u frame within the frame to weld new body mounts on etc.
Old 08-05-2019, 10:35 AM #27
apohl17's Avatar
apohl17 apohl17 is offline
Real Name: The Native Explorer
apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light
apohl17's Avatar
OP, the repair job looks great! Its always nice to see people spending the time and money to patch versus letting it get so bad that a frame finds a new home in the yard. Enjoy the next who-knows-how-many hundred thousand miles on this frame
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 12:02 PM #28
4v power 4v power is offline
4v power is on a distinguished road
That was some really bad rust. I am surprised you fixed it.
4v power is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 12:49 PM #29
det107 det107 is offline
det107 is on a distinguished road
Originally Posted by brillo_76 View Post
...I have 5 3rd Gens and live in the rust belt. I have been experimenting for years on how to not only strengthen these frames........the best way I have found so far (though very time consuming) is to cut the bottom of the frame out.......This basically gives a u frame within the frame to weld new body mounts on etc....
What time zone do you live in where you have 25 hrs a day & eight days a week?
det107 is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 06:28 PM #30
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You got me... Reside in Western PA (GMT -5:00). Where in the winter time if Penn Dot sees a snow flake they Dump Tons of Salt on the roads not to mention mix it with calcium chloride. It really eats the metal on your winter rides. :{
frame , inside , muffler , rot , time
Need Advice: Frame Damage From Accident and Frame Rust Whammy 4th Gen T4Rs 11 08-29-2018 07:46 PM
Rusty Frame from IL now in the desert. Still spray the frame? New Frame? Rancho5 3rd gen T4Rs 9 03-02-2018 04:40 AM
Frame Restoration on my 97 (frame removal, repair, and upgrades) blain_gatterdam 3rd gen T4Rs 2 05-21-2015 12:17 PM
WTB - 3rd Gen frame northernT4R Want to Buy/Trade 2 08-18-2014 08:22 PM
4th Gen frame ? Camprunner 4th Gen T4Rs 20 04-12-2007 08:05 PM
