Old 07-13-2019, 03:03 PM #1
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Awe man... frame rot
Just when I finally decided to make my truck a full time dune toy and keep it enclosed for the winter I start to do extensive rust control on my frame. Complete wire wheel followed by Extremely strong laquer thinner then phosphoric acid. My POR-15 comes in the mail tomorrow and I finally decide to take a look at my frame next to the muffler. Notorious rot spot. I knew I had a little hole but thought "I'll get to it" well I got to it. Sadly not before it got to me.
The design flaw in these frames is insanely horrible. Severe lack of drainage in the center of the frame which is strange because it's a low spot as the front and rear are higher and then dip down as they converge into the middle of the frame. Then theres the fact that the muffler is located literally an inch or less from the frame itself emitting a constant heat. I know for a fact without a doubt the muffler is what caused my rot because the drivers side is also flooded with sand and debris but hardly any rust! I can still feel factory smooth finish paint on the inside on the drivers side!
I'm lucky I caught this in time. Even though I'd rather do a full frame swap I'm a few years out from that and by that time good luck with finding one. My rear control arm mount is entirely rotted on the weld on the inside and almost mint on the outside. Yet again the only difference being the Inside is constantly receiving heat from a hot muffler.
I fell in love with my truck and even though it's coming up on 20 years of age with 251,000 miles I'm never going to get rid of the thing. I will fix and repair as needed. New engines or transmissions etc. I'm only 23 years old. This thing has a long life ahead of it.
I'm personally going to be getting rid of the factory muffler and replacing it with something far more slim. Maybe catback maybe nothing but a straight pipe. I will also drill a few half inch holes in key locations underneath the frame to allow for proper drainage as currently theres no way in hell the little pin holes are doing their jobs.
Anyways rant over. Just a heads up to all you owners out there. Go ahead, do yourself a favor and look at your frame right next to your muffler. Especially if you live in the midwest like I do. I plan on tackling the rest of the frames interior with various methods and then completely overdoing it with the Eastwood internal frame coating after various other soak methods.
I refuse to lose my truck to rot. The only way I'll lose this bad boy is if someone steals it or it gets totaled in an accident. Otherwise bury me in it.
Awe man... frame rot-screenshot_20190713-145920_gallery-jpg  Awe man... frame rot-screenshot_20190713-145927_gallery-jpg  Awe man... frame rot-screenshot_20190713-145940_gallery-jpg  Awe man... frame rot-screenshot_20190713-145948_gallery-jpg
VernySanders is offline   Reply With QuoteReply With Quote
Old 07-13-2019, 03:27 PM #2
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Yikes, taking a salty beating. The muffler has nothing to do with it. Prevention is of utmost importance. I don't get rust.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 07-13-2019, 05:33 PM #3
hamsandwiches hamsandwiches is offline
hamsandwiches is on a distinguished road
Agreed, muffler has no effect. Heat is not what causes rust, its typically moisture inducing a higher oxygen concentration making it more likely to bond with the iron.
Unless you have an exhaust leak at/around the muffler, and oxygen remaining in the exhaust as water vapor was constantly blowing on the frame.
All rust is fixable IMO. My 98 was way worse than those pics. Over 20 lbs of rust. After spending two days with a grinder and welder and lots of plate steel after removing the gas tank I had it safe and solid again.
The reason people think these rigs rust more than other comparable vehicles is because they last so long.
zoinks! there's scoob
hamsandwiches is offline   Reply With QuoteReply With Quote
Old 07-13-2019, 05:50 PM #4
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Muffler absolutely DOES have a lot to do with it. Mine did the same thing, and when I had it estimated to be fixed, the highly-reputable frame shop had 4 or 5 third gens owned by employees. They explained that exhaust heat in the winter, along with exhaust gases that escape as the muffler ages, cause the frame to fail there first. Mine had a 2.5-foot hole in the frame next to the muffler but none on the other side. Dealer told me essentially the same thing.
thennen is offline   Reply With QuoteReply With Quote
Old 07-13-2019, 05:53 PM #5
thennen's Avatar
thennen's Avatar
Heat from the muffler in winter causes that part of the frame to stay moist longer in snowy, icy weather. In Ohio, at least, this is a thing.
Old 07-13-2019, 06:01 PM #6
thennen's Avatar
thennen's Avatar
Sadly had to abandon my 2001 due to rust a couple months ago. When I drove it the final 40 miles to the dealership to trade on a RAV4 for my wife, it was squirrelly and weaving on the highway due to at least one failed weld. I’m glad you have the energy and means to repair yours. Mine had NO mechanical problems at 265k when I got rid of it. That made it even more frustrating. Ohio road salt and flawed frame manufacture (Dana Corp?) combined to kill it. I’m happy for those in arid climates, where this isn’t a problem.
Old 07-13-2019, 06:51 PM #7
Not going to argue about the muffler stuff, but I had the same rust but more. It was on the other side, with little rust near the muffler.
Old 07-13-2019, 07:22 PM #8
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
All gen 3 4runners are built in Japan so it's a Japanese frame. It's not so much a flawed frame as it's just old. If this was a 70's Bronco, Scout, CJ, Toyota pickup or any boxed frame vehicle it would be rusted out in 4 years in the rust belt. The fact that these have held up so well is a testament to how awesome they are! VernySanders your frame is totally fixable. Take a holesaw and drill a few drain holes in the bottom of your frame after you get it fixed.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 02:40 PM #9
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
You can blame it on the muffler heat, road surface at shoulder side holding more slush run off, or whatever. Even if Toyota designed these with straight pipes out the front fenders, they would still rot out. Its not just the frame that's taking a beating either. Rust damage is not exclusive to 3rd gen 4runners.
You can listen to the frame repair shops or dealers telling you theories on rust.....or you can do what people that keep their rigs from rusting out do.
Here's a pic of my muffler next to my frame with 363K that lived in the rust belt its whole life, original paint. The only thing I do is 1 hour per year of rustproofing, that's it.
Seriously its so super simple to prevent, its too bad more people don't know.
Awe man... frame rot-img_7711-jpg
Old 07-14-2019, 10:45 PM #10
thennen's Avatar
thennen's Avatar
Keep in mind that I bought my 2001 in 2005 and NEVER did anything to address frame rust. This is because I never knew frame rust was a thing until it was too late. So if you've been treating your frame on a regular basis, then you won't see what I've encountered. My previous 4Runner was a 1988. Never had to address rust with that vehicle.
So I get it - if I had done what you do, I would never have a problem. Since I didn't, my problem started next to the muffler. Physics explains why the muffler side goes first, and many others have experienced the same thing.
Old 07-15-2019, 12:11 AM #11
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Please share with us the product you use and your application process.
I live in lower Hudson Valley where the roads are salted and would love to feel more comfortable driving my older Toyota trucks in the winter.
I’m all for a solid regiment of rustproofing.
Just need to know what to use and how to apply it.
Sarki is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 09:18 AM #12
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
Yeah I know what you're saying. You have to lose one to rust to know what happens, and that's what happened to me on another one. I also got a Taco buyback on frame damage. So I said no more, and just prevented it from happening. No matter the kind of vehicle you drive in the rust belt, salt will give it a beating over time. Some fair better than others, but all get some rust eventually. But but if coated with a barrier, you're protected. It has to be done properly and diligently. Its actually very easy I found.
Old 07-15-2019, 09:23 AM #13
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
Here's my write up. I've shared it many times on this forum. Follow these easy steps, don't deviate, and you are hard core protected.
SEASONAL RUST PROOFING using WD-40 only
Old 07-15-2019, 09:49 AM #14
samc5mith samc5mith is offline
samc5mith is on a distinguished road
That frame is done for
samc5mith is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 09:39 PM #15
That’s a great write up, thanks big time. Will definitely use this as a guide.
Planning on looking into Fluid Film as have heard good things about it and supposed to be a bit easier on the planet then WD.
frame , inside , muffler , rot , time
Need Advice: Frame Damage From Accident and Frame Rust Whammy 4th Gen T4Rs 11 08-29-2018 07:46 PM
Rusty Frame from IL now in the desert. Still spray the frame? New Frame? Rancho5 3rd gen T4Rs 9 03-02-2018 04:40 AM
Frame Restoration on my 97 (frame removal, repair, and upgrades) blain_gatterdam 3rd gen T4Rs 2 05-21-2015 12:17 PM
WTB - 3rd Gen frame northernT4R Want to Buy/Trade 2 08-18-2014 08:22 PM
4th Gen frame ? Camprunner 4th Gen T4Rs 20 04-12-2007 08:05 PM
