Old 07-13-2019, 11:33 PM #1
rm3sweet rm3sweet is offline
rm3sweet is on a distinguished road
2k Limited struggling to let go
2000 Limited w/264,000miles ~approx
I wanted to get some input from a group that understands the attachment to the 3rd gen before making a final decision.
My motor started producing a low knock and appears to have spun a bearing. (all my fault and not the engine or durability of the 3.4l). This a long story I'd rather not vent at the moment.
Last fall I had just completed a 3.5'' OME lift w/Bilstein coil overs and 1'' diff drop. And essentially an entire front suspension rebuild.
I haven't the place, time or means to pull/swap an engine and looking at the cost seems too much to bare.
So I'm thinking of cutting my loses and selling. Looking for honest opinions and pro/cons.
Short list of recent upgrades:
Lower and upper control arms
Rack and pinion unit
285/75/16 BFG K2 (40-50%) tread life
Rear axle seals bearings
HVAC electronic control unit repaired by one of T4R member(awesome job by the way)
Larger Front Caliper MOD with drilled rotors
New rear drums and shoes
Radiator replaced (4 years old approx~)
LED interior bulbs and select exterior lights (added a LED flood backup light flush mounted for better visibility)
Will need to post pictures if requested/needed.
rm3sweet is offline   Reply With QuoteReply With Quote
Old 07-13-2019, 11:44 PM #2
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
You might get up to $2k for it since it needs an engine swap or rebuild. I'm not sure what a rebuild on the bottom end would cost but two rebuilt and ready to go heads are about $800.
Can you tell us the short version on how the rod bearing got spun. Were you over revving the engine in sand or mud? Something like that. No need to go into detail; just an idea of how it happened if for no other reason than for me to avoid doing the same thing.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 07-13-2019, 11:55 PM #3
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I wanted to get some input from a group that understands the attachment to the 3rd gen before making a final.
I would ask myself this question?
I need something to drive, what is that going to be? My current ride needs an engine and that will probably on the low end run me $2000 for somebody else to do it. High end you can spend 5-6k with quality reman.
Your going to spend money to get a new ride so... why not keep this one going.
Sure you might have done some good maintenance but the truck needs a new engine so that is going to seriously affect the value.
Old 07-13-2019, 11:56 PM #4
I ran into financial drought and neglected to change the oil thinking since I was running full synthetic I could go longer. No over revving, just pulled out the driveway and heard the knock which got louder by the time I turned around and went back home feeling sick over it. Add to the leaking valve cover gaskets I kept putting off replacing and I got what I deserved. It still starts but I've only done that once to have a mechanic friend confirm what I thought was the failure.
Old 07-14-2019, 01:55 AM #5
JohnOfTheJungle JohnOfTheJungle is offline
JohnOfTheJungle will become famous soon enough
How many miles on that oil change?
1997 Limited 4x4 3.4l 199k E-locker Blue Wire Mod | 255/85 r16 Maxxis Bighorn MT - LX450 9 wrap + Tokico black rear | Front: 2.5" King Coilover set @ 2" lift | True North Fab Front Bumper + Warn m8000 + Baja Designs Squadron Sport | Custom Sliders | NguyenWorks Rear Bumper + Tire Swingout
JohnOfTheJungle is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 02:20 AM #6
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
So...the oil ran down through the leaking valve covers? Dag...
It's substantially cheaper to rebuild/replace the engine than to acquire another desirable vehicle, unless your definition of *desirable* is a ten-year-old hatchback.
You've done some of the major repairs (like the axle seals) that mean that once it's up and running, you'll have a quality vehicle. And, as a bonus, one that won't be leaking through the valve covers.
pluton is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 09:03 AM #7
drei4runner29's Avatar
drei4runner29 drei4runner29 is offline
drei4runner29 is on a distinguished road
If you don't mind me asking, how much would it run you to swap out your old engine w/ an OEM from Japan? The reason I'm asking is because I just recently swapped out my engine for a used one from Japan w/ around 60K miles on it. I've been driving it for almost a year w/ no problems. With everything I paid for, parts and labor included it came out to around less than $3k and that's a mechanic here in Southern California.
Prior to me swapping out the engine, I was seriously debating just purchasing a used 4th gen. But after thinking it over, I had sunk a lot of money into my vehicle already so I just decided to go w/ the engine swap instead. Couldn't be happier. Plus I still prefer this body style over the 4th gen, I just wish it had more power from the get go. Now if I could afford a used 5th gen, I'd be like sayonara my beloved 3rd gen.
2002 4runner SR5
2005 Sequoia SR5
drei4runner29 is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 09:46 AM #8
Hepar's Avatar
Hepar Hepar is offline
Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough
Hepar's Avatar
What is the condition of the rest of the vehicle? Mainly rust. If rust is an issue, I'm not sure I'd invest much time and/or money in fixing it back up. But that's me.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
Hepar is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 11:47 PM #9
I stopped counting after 8k... I was that broke. I'm actually thankful because had I not been driving such a durable vehicle I would have been thumbing it or standing on the corner with a cardboard sign. Not kidding.
Old 07-15-2019, 11:52 PM #10
Yes, but once the dirty oil started to wear I was getting cold start smoking and assumed I was starting to get oil blow by on the valves. After a minute or two the smoke would clear mostly. She ran really good but the damaged had been done. It was only a matter of time and I couldn't sell it with a clear conscience.
Old 07-16-2019, 12:02 AM #11
There is some frame rust but not as bad as some others I've seen. The extra oil leak/spray was preserving most of the frame for me. I went to look at a salvage yard motor today. They wanted $400 and $75core charge but it has about the same miles as my current motor. I'd like to find one under 200k so I've been seeking out listings for parts trucks that are wrecks, salvage or broken frames. Even those however, asking prices are too high in my opinion. Most want between $800 and $1000 here in Ohio which to me is not equitable when compared to the overall vehicle value. I did find one that has the Elocker so I'm going to try and reach that seller tomorrow.
Anyway, I've got transportation so I think I'll keep shopping and see if I run across a deal that makes sense to me numbers wise before throwing in the towel. At my age this should not be such a struggle to let go!
Old 07-16-2019, 12:04 AM #12
How do you even go about getting a JDM engine? I would think that is the pricey option, no? Not being on the coast and all those benefits.
Old 07-16-2019, 10:19 AM #13
zoombyu86 zoombyu86 is offline
zoombyu86 is on a distinguished road
Im in ohio looking for something with a shot drivetrain...just sayin!
zoombyu86 is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 12:37 AM #14
Maybe. They have some shops that sells used Japanese engines. They ship it from Japan since I think they can only go up to 60K miles before they have to replace it. Purchased mine from one of these shops and it cost me around $1150+ just for the engine.
Look around the internet for used Japanese engines. I remember seeing some shops in Texas and somewhere in the mid west.
2002 4runner SR5
2005 Sequoia SR5
Old 07-18-2019, 07:27 AM #15
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Really wondering how long you went without changing that oil. Get a JDM engine.
control , engine , front , rear , unit
AC Struggling UURunner 4th Gen T4Rs 15 07-01-2019 08:49 PM
4Runner Struggling LA4RUNNERGUY 3rd gen T4Rs 8 07-13-2014 02:57 PM
Struggling with the size of the 4runner stevieboy 5th gen T4Rs 31 09-13-2013 08:44 PM
Struggling at startup eosandov 3rd gen T4Rs 0 10-11-2012 10:08 PM
t4r struggling to start skkiii_whhaattt 3rd gen T4Rs 3 08-27-2006 06:28 PM
