So this was a surprise issue this afternoon. It's hot and humid out today, but the streets are dry, and as far as I can tell, I didn't break traction before this issue happened. I took a sharp right from a stop, no chirping the tires or anything, and a few moments later (going straight) the VSC light started flashing and beeping like crazy. I was going about 20-25mph, and it only stopped when I slowed down to a crawl or pulled over and stopped. Once I started moving, the same problem would start again. I tried driving through the beeping assuming it was just a nuisance -- we were 1/2 mile from home, and at low speeds it was still driving normally -- but the system started automatically applying the brakes once I approached 30mph. It felt unsafe enough on the second time the brakes kicked in that I pulled over and shut the truck off. Started it back up right away and the problem seems to have resolved itself after that.
Anyone else ever experienced this problem? Any advice? (Aside from doing the AndyMod, not sure about whether or not I want to do that yet.)
I'm going to take it back out around the neighborhood in a bit and I'll see if the problem recurs. Wasn't a super big deal on residential streets on a Sunday, but I'd hate for it to kick in during a commute at highway speeds.
Thanks in advance folks.
