Old 04-21-2020, 05:03 PM #16
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a jewel in the rough Bad Luck is a jewel in the rough Bad Luck is a jewel in the rough Bad Luck is a jewel in the rough
Real Name: Patrick
Originally Posted by DesertRoads View Post
There's a HUGE price difference between the 5100's and the 6112's. Obviously the 6112's come with springs and are set up more for the frequent off roader, where as the 5100 is geared more towards the occasional off roader and not as aggressive trails. Kind of an unfair comparison here.
You are correct that they are in different categories, but I wasn't comparing 5100's to 6112's. My point was that the extended and collapsed lengths for 4Runner 5100's and 6112's are the same as well as Tundra 5100 and 6112's so that the benjamin247 could see that there isn't a big difference in max lift heights between 4Runner and Tundra shocks.
Edit: I agree with you on intended use of each though
2000 Limited V6 Auto E-Locker
Old 04-21-2020, 05:10 PM #17
DesertRoads's Avatar
DesertRoads DesertRoads is offline
DesertRoads is on a distinguished road
Originally Posted by Bad Luck View Post
You are correct that they are in different categories, but I wasn't comparing 5100's to 6112's. My point was that the extended and collapsed lengths for 4Runner 5100's and 6112's are the same as well as Tundra 5100 and 6112's so that the OP could see that there isn't a big difference in max lift heights between 4Runner and Tundra shocks.
My apologies for the mis-interpretation.
2016 Subaru Outback Premium
2012 Toyota Tundra CrewMax
2001 Honda Accord EX, 5MT
1999 Toyota 4Runner Limited
DesertRoads is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 12:46 PM #18
KimIsAGuy KimIsAGuy is offline
KimIsAGuy is on a distinguished road
Update
Hey guys,
Just an update. I ended up going with the Tundra's 6112 and the FJ 5160 w/ OME 891. I ****ing love it. I have a little bit of a rake, but overall sitting at ~2.5in taller. It is a bit stiffer since I have no weight on the car yet, but still better than the original OEM setup I had (before it started giving out, I'm at 400k on the car). I haven't gotten the chance to take it off road yet because of this stupid virus situation... So... I guess I'll save up for 285/75/16r BFG KO2s or the Falken Wildpeak.
KimIsAGuy is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 11:38 AM #19
NOT SURE NOT SURE is offline
NOT SURE is on a distinguished road
I've been looking at this setup for mostly street driving, though streets in seattle are so poor it's like driving offroad a lot of the time. My question is; if I'm not planning to lift at all would the 6112 match well with 5100 in the rear or should you always pair with the 5160s? I've been looking at package deals and I see both pairings offered
NOT SURE is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 11:55 AM #20
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad is just really nice sleepydad is just really nice sleepydad is just really nice sleepydad is just really nice sleepydad is just really nice
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I just put 6112 up front with 5160 in the rear.
I would honestly say your probably not going to notice any difference between the 5100/5160 on the same coil spring.
I think if you get the package deal the 5160's will end up running you maybe 140-150 more than the 5100 setup? I think that is what I figured @ the time. so I just said what the heck lets try the reservoir ones.
but the 5100,5160 are spec'ed almost the same. I think the 5160's are like .05 less expanded length wise. small enough it does not matter.
BTW it's a great setup either way, very nice ride quality.
Old 06-17-2020, 08:17 AM #21
Thanks, it seemed to me they were the same just with the addition of the reservoir. One huge difference though, the 5160's are backordered from Bilstein for 16 weeks! I tried a lot of online merchants and they were all out of stock but I ended up going with AJ-USA since they had the best price. The 6112 are shipping immediately and I was wondering why "it is recommended that the driver side circlip is installed two positions higher than the passenger side circlip." Only the KDSS models are even on both sides
Old 06-17-2020, 08:40 AM #22
Real Name: Patrick
Real Name: Patrick
Lots of stuff on the driver side that isn't on the passenger side. Front differential, transfer case, front driveshaft, fuel tank, and driver. Setting the driver side higher compensates for the uneven distribution of weight. I'm not sure I would go 2 settings higher, but I have no direct experience with 6112's.
6112/5160 , bilstein , guys , time , worth
Bilstein TRD Pro suspension or Bilstein 6112/5160? MK_Ultra 5th gen T4Rs 7 05-20-2018 03:14 AM
FS: Bilstein 6112 / 5160 Susp. For 5th Gen (SF, CA) - $650 Xtremluck For Sale: Suspension/Wheels/Tires 3 12-08-2017 05:03 PM
Bilstein 6112/5160 vs Fox 2.0 - ??? fifthcircle 5th gen T4Rs 48 11-08-2017 09:24 PM
FS: Bilstein 6112/5160 RockyRider For Sale: Suspension/Wheels/Tires 7 12-31-2016 02:43 PM
