Old 07-15-2019, 07:01 PM #1
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a jewel in the rough 4Runner4Leon is a jewel in the rough 4Runner4Leon is a jewel in the rough 4Runner4Leon is a jewel in the rough
Real Name: Leon
Am I missing the point of scangauge?
I bought a scangauge a few weeks ago, planning to eventually install it in the overhead console. I must admit that I had my doubts about its utility for my truck, but I decided to try it, given that everyone else seems to love theirs.
So after a few weeks of driving with the scangauge, I'm ready to send it back. Now, full disclosure, I'm a bit of an odd duck - I have a digital voltmeter and transmission temperature gauges already installed in the dash, so I have no need for these functions in the scangauge (besides the scangauge would not read the trans temps on my '97).
So that leaves the water temperature gauge as the only thing I find interesting to monitor - and even that is of little benefit, as I can look at the analog gauge in the dash. Without an alarm for high water temps (and I can't comprehend why scangauge doesn't include that function, like Ultragage does), I'm not sure how useful it is for me to have that gauge. I don't want to use the scangauge as a $100 water temp gauge.
Moreover, my Torque Pro app can do everything that a scangauge can do, except that Torque Pro is easier to use for scanning fault codes, monitoring various functions, all with a much better graphics interface.
So am I missing something about the scangauge that might make me change my mind?
'97 4Runner Limited 4WD E-Locker ~195k
'99+ Headlights, Floor Console, Dash Bezel, Heated Side Mirrors, Storage Compartment | '01 Homelink Sun Visors, Taillights, Sport Hood
OEDRO LED Bulbs | 265/75/16 Falken Wildpeak A/T3W | B&M 70264 Trans Cooler | GlowShift Digital Trans Temp Gauge
SPIKER Engineering High-Lift Hood Struts
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 08:07 PM #2
carp73's Avatar
carp73 carp73 is offline
Real Name: Jeremy
carp73 is on a distinguished road
MY GARAGE
carp73's Avatar
Real Name: Jeremy
MY GARAGE
I got one a few weeks ago and like it so far. I just installed the supercharger so it's nice to be able to monitor my timing advance. I also have it set to water temp which is good since it takes a lot of variance to make the analog one in the dash move, so I like to see if I'm up a few degrees pulling long hills or towing etc. I also like the fact that I can have an accurate speedometer since mine is off by 13%. And lastly, I monitor the average mpg's but I'm not sure how accurate that function is. So for my uses it's actually been pretty helpful
carp73 is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 08:27 PM #3
Brian.'s Avatar
Brian. Brian. is offline
Brian. will become famous soon enough Brian. will become famous soon enough
Brian.'s Avatar
Why did you choose the Scan-gauge over running Torque? They do the same thing, offer the same information. The way I'm reading Leon's post, that's the main question.... why pick a $$$ option rather than a $5 dongle and a phone you most likely already have in your pocket/hand.
Brian. is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 08:57 PM #4
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar will become famous soon enough LittleCaesar will become famous soon enough
No, if you can already read volts, ATF, and coolant temp. If you are running Android, then the Torque Pro app should display all and more. I personally like the Scangauge for its size in my 99 but that is just me.
Personally I want to see odd duck Leon return it and put the $$$ towards a set of those Hilux mirrors......
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 09:19 PM #5
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a jewel in the rough TonyB66 is a jewel in the rough TonyB66 is a jewel in the rough
TonyB66's Avatar
Leon, likely much of it has to do with those who have used them for 10 or 15 years, when there were few to no other like options back then. I have a couple cables that I keep routed in two different vehicles...
With today's choices, I can see how the SCII might not be so desirable for some. That said, I'd want a dedicated screen. I personally wouldn't want to tie-up my phone's screen for such, but that's just me. So, for some, that might entail the purchase of another screen device. I also like the size of the SCII, that it is small, not taking-up much real estate, possibly another screen suspended from an arm or bracket. I tend to prefer cleaner, more integrated-looking solutions. As with most things, preferences can play a role...
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 09:52 PM #6
Cree's Avatar
Cree Cree is offline
Cree is on a distinguished road
Cree's Avatar
Im already using my phone for nav and music, so I like the standalone. You done need it, return it.
00 Limited - Stuff!
13 Explorer Sport - No stuff, Just boost
Cree is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 11:57 PM #7
carp73's Avatar
Real Name: Jeremy
MY GARAGE
carp73's Avatar
Real Name: Jeremy
MY GARAGE
Mainly because the scan gauge is always plugged in and in front of me. I have the dongle and an app for my phone that I use for other things but it's not always hooked up and reading information as soon as I get in the car. Just me but it makes it easier. Not sure if it's really worth the expense but I like it
Old 07-16-2019, 01:44 AM #8
19963.4lsr5 will become famous soon enough 19963.4lsr5 will become famous soon enough
I have one in my Saturn S Series, I watch trip average mpg, real time MPG, ignition advance and either engine temp or LTFT depending on how I feel. Itís always there and always on and not hogging up my phone and burning battery time unless a want another cable to charge it.
Old 07-16-2019, 03:04 AM #9
sogoood's Avatar
sogoood sogoood is online now
sogoood will become famous soon enough
sogoood's Avatar
throwing up an offer but we can trade deal if u want my hilux surf pfm. lol
2002 Dorado Gold 4runner SR5 fully loaded/leather/JDM goodies
OME 882 fronts.LC 8 wrap rears/TRDOR wheels/1.25" Spidertrax/13WL TBU/JDM Hilux Surf Window Visors+LED Spoiler+Power Fold Mirrors/Hilux Surf Corners+Headlights D2S 5.0 x Panamera 2.0/Jaos Mud Flaps/Viper 5901/Blackvue dr750s 2ch/quarter tank of gas
Awaiting install of SCS Ray10 17x9" -38 Copper wrapped in 285/70, TrueNorthFab plate bumper and useless cool jdm parts
sogoood is online now   Reply With QuoteReply With Quote
Old 07-16-2019, 07:26 AM #10
thegipper's Avatar
thegipper thegipper is offline
thegipper will become famous soon enough thegipper will become famous soon enough
thegipper's Avatar
I have an ultra gauge in my 97 and I do like it. I went the ultra-gauge route because it did everything better and had more options than a scan-gauge.
I also have the torque app which is definitely the best but I wanted a dedicated device in my truck. It's nice to be able to monitor multiple things on one screen with a device that is always hooked up and automatically turns on. It's definitely not a "must" have item but I've been happy with mine.
The analog temp gauge is pretty useless on these trucks. Supposedly when the needle finally moves from the normal operating temperature mark, the coolant temp is already in the 220ish range. I have an alarm set on my ultra gauge to go off at I believe 203.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 09:15 AM #11
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
I'll admit that I never saw the point in one either, outside of having a 'dedicated' device. The Torque app does much more.
Now, Torque does have a plugin that will allow certain gauges to read over your homescreen or GPS app. You don't need to have the full app up. It's a bit hit or miss, but it works.
I have a cheap 7" tablet that I've been considering getting a dash mount for and just using that as my dedicated Torque dummy. I think the tablet was $30 at MicroCenter last year.
I will second that the temp gauge is useless. Story here:
This is why you need an ODB2 scanner
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 12:21 PM #12
phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light
The analog gauge is useless on almost every vehicle.
The 4Runner reads center of the range from ~165*F to ~220*F - useless for detailed monitoring of coolant temps (but good enough to show true overheating). Most other Japanese car gauges read that way too.
Leon, for you, either get an Ultragauge or stick with the Torque app. You don't generally need to monitor anything but trans temp (and even then, not for most daily driving) and you have a standalone gauge for that.
I use it for trans temp, water temp, air intake temp and trip MPG. The upside is that I never have to load an app and the screen is always there (freeing up the phone for music/podcasts/navigation).
'16 Honda Odyssey
Old 07-16-2019, 04:19 PM #13
Real Name: Leon
Real Name: Leon
Thanks for the responses, great food for thought.
I see the main benefits of the scangauge as being an integrated/dedicated "always on" unit, which definitely has its pros (not tying up the phone, easily mountable out of the way, etc).
The main drawbacks are a subjectively poor interface, difficult to set up new gauges, and no warning alarms.
If I were starting from scratch, and I had a 99+, I would probably keep the scangauge, and monitor voltage, trans temp, water temp, and maybe mph (although correct me if I'm wrong, it'll read out OBD mph, which is incorrect due to my tire size, while the Torque Pro can read out both the OBD and GPS mph). But I already have a voltmeter, trans temp, and outside ambient air temp gauges. So the only remaining thing I see as being important to me in the scangauge (not just for curiosity) is the water temp.
As you guys stated, the factory analog water temp gauge is useless, as is the warning light. But, the scangauge does not have an audible alarm for high reading! So unless you're expecting to see high temps and are staring at the scangauge (e.g. when towing uphill), there's a very good chance that you'll miss a high water temp situation (like when your fan belt breaks, etc).
For me, that seems like a dealbreaker. Both Ultragauge and Torque Pro have alarms for high or low readings, so I can't understand why scangauge did not include that feature, but they didn't.
The tradeoff seems to be a compact and dedicated scangauge that's easy to install cleanly (but without alarms) vs. an ultragauge or Torque Pro that are not as easily integrated but have the alarms. I'm leaning towards getting something with an alarm, but I need to make sure that I can get into the habit of always running Torque Pro on my phone, which would be an adjustment to my current routine. Maybe the Ultragauge is a good compromise from that standpoint - a dedicated "always on" unit, with alarms, with the option to fire up Torque Pro for additional data.
@AntleredRuin , what is the plugin you use to allow certain gauges to read over your homescreen or GPS app? I saw some widgets, but the reviews are very mixed, including having to completely reset your phone .
The Torque Pro of course has an unparalleled capacity for info displayed. Here's a comparison of the scangauge screen and the Torque Pro (pardon the temporary tape holding the scangauge):
Old 07-16-2019, 04:54 PM #14
TonyB66's Avatar
TonyB66's Avatar
I've long thought about getting UG, just for the alarms/notifications. Have it run in the background on my phone. Phone connected to the Pioneer double DIN, so visual alerts would be seen on that screen. 80 bucks... At some point.
Old 07-17-2019, 09:02 AM #15
Real Name: Daniel
Real Name: Daniel
It's called Torque Dashboard Plugin.
It's a bit finicky; you have to open it, then add whatever gauge, like the actual app. I think it sees when you have the full version purchased and unlocks more.
Here's an example pic of the plugin
If you're willing to spend $150ish on a Scangauge, why not get an Android radio headunit for about the same price? Just install the Torque app straight to your radio.
This one has great reviews.
https://www.amazon.com/ATOTO-Double-...ustomerReviews
dash , gauge , scangauge , temperature , water
Scangauge II $100, CT wnelax04sr5 For Sale: Non-T4R Items 3 10-30-2017 05:40 PM
FS: Scangauge II boostedka For Sale: Non-T4R Items 3 03-17-2016 01:08 PM
ScanGauge II as anyone used it? PCF4runner 3rd gen T4Rs 34 02-17-2016 03:27 AM
Wtb scangauge 2 drtyjerz47 Want to Buy/Trade 0 02-08-2014 09:15 PM
Correct point for jacking with OEM jack and correct jack stand point? satek 3rd gen T4Rs 7 10-24-2012 04:41 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
