SRS light is flashing. Pulled the code, B0136/74: LH squib, airbag sensor assembly, wire harness.
Followed trouble shooting guide in FSM. Squib checked out and LH harness checked out, that leaves the main module.
Local dealer service dept. says the mdoules are VIN specific and have to be programmed to your specific vehicle, and that they wont program used ones, only a new one they sell you. They transferred me to their parts dept. and the guy says the part (89170-35090) is discontinued, none anywhere in the country according to their computer system.
safetystore.com said that they just re-set them so if my issue is due to a malfunction in the module, their service wont fix the issue, and they cant re-program them.
myairbags.com has one that says tests good but you need to take to a dealer to program to your specific VIN.
Searched that part number on here and only came up on two part-outs from 2014 & 2017.
I'm at a loss.
Suggestions, opinions? The "good, used" model is $20, so I guess I'll give it a shot, but if it doesnt work because it isnt programmed, I'll be back at square one.
TLDR; module is bad, new ones have to be programmed, dealer wont program used, only new; no new available.
-ReD
Firefighter/Licensed Paramedic
*SOLD* 2000 4Runner Limited 4x4
2020 Ford F-150 3.5L EB
Build Thread
