Old 10-30-2018, 08:52 AM #1
johnsoma73's Avatar
johnsoma73 johnsoma73 is offline
johnsoma73 is on a distinguished road
johnsoma73's Avatar
P0770 still throwing after new solenoids and new torque converter! Help!
Hi guys,
I have a 2001 SR5 Auto 4WD and I got the dreaded P0770 CEL code and already pulled the trans and out In the three new small silver solenoids and a new torque converter and the code is still firing.
Only two options left seem to be swap the valve body from a junkyard truck, or swap the whole transmission.
Any thoughts on what may work to fix and stall the code?
Also, does changing the fourth and fifth solenoid on the valve body help?
Or perhaps cleaning the valve body? If so, who could clean it for me? Special mechanic or any trans shop?
How hard is the valve body to pull and swap? It seems like a lot of springs fallout behind it when you pull it off the trans? Are they hard to put back in or super easy?
Thanks for the help!
Mike
2001 4Runner SR5, Tundra 13WL Brake Conversion, currently working on a full suspension upgrade..., Wish List: TRD Supercharger Kit and Sport Scoop Hood.
johnsoma73 is offline   Reply With QuoteReply With Quote
Old 10-30-2018, 09:31 AM #2
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
How many miles on that transmission? The 01/02 trannies are more prone to failure than the earlier models.
How is the transmission acting even with the code? Does it otherwise work fine or is it slipping and acting up?
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 10-30-2018, 11:08 AM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Mind generated a P0770 years ago, cleared it and it never returned, yet anyway.
Guessing you've already done all the FSM suggested items before replacing any parts? e.g. full fluid flush, connection cleaning, ect.
Just a quick search here yielded lots of articles, some interesting: P0770 code keeps firing...need help!
Luck.
Old 10-30-2018, 11:16 AM #4
johnsoma73's Avatar
johnsoma73's Avatar
It drives completely fine!
Doesn’t slip or overheat at all.
I changed the fluid and filter and did a flush after the new solenoids and new torque converter.
The damn code just won’t go away.
Should I change the whole valve body?
Get it cleaned?
Change the SLT or shift control solenoids?
Old 10-30-2018, 04:21 PM #5
MSRP. MSRP. is offline
MSRP. is on a distinguished road
If it drives fine?
Drive until it stops driving fine, and don't drive too far from home if you do not have roadside assistance.
Truck is too old to throw money at it just so you don't have to stare at a code..
MSRP. is offline   Reply With QuoteReply With Quote
Old 10-30-2018, 04:33 PM #6
absalom's Avatar
absalom absalom is offline
Real Name: Jordan
absalom has a spectacular aura about absalom has a spectacular aura about
absalom's Avatar
Real Name: Jordan
Is this true though? I've heard this occasionally, but see little to back it up. Obviously my sample size of 2x 01/02 trannies with 300+ miles is meaningless, but worth throwing out there.
absalom is offline   Reply With QuoteReply With Quote
Old 10-30-2018, 05:24 PM #7
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
If it drives completely fine, perhaps pull a junk yard valve body from a transmission and swap it out (might want to put your brand new solenoids on it though, it's easy).
The valve body is not hard to take out at all, it's just really messy. When you get all the bolts out, just bring it down straight and keep track of which springs where in what slots. Some will still be stuck up in the transmission, that's completely fine. I suggest getting some transmission lube and actually coat the tops of the springs to stick them back in the transmission so it's easier to put the valve body back in. Pay attention to torque specs though, you DO NOT WANT TO STRIP ANY BOLTS.
You will need a valve body from an 01-02 though, earlier years may not play as nice and will look different.
Here's a thread I used for the shift kit I installed with some photos: Transgo 340-hd2 install and reveiw
326WHP 347TQ
Old 10-30-2018, 08:38 PM #8
johnsoma73's Avatar
johnsoma73's Avatar
Thanks gamefreakgc!
That’s exactly what I was thinking of doing.
Getting a junkyard valve body and putting in my new solenoids.
When I put it into my truck, do the springs go in any particular way(I know correct order) but how do they go in? Just toss them in there with assembly line? Doesn’t matter the orientation?
Old 10-30-2018, 09:42 PM #9
Real Name: Jerod
Real Name: Jerod
Originally Posted by johnsoma73 View Post
Thanks gamefreakgc!
I can't remember which are which. You'll get a practice run with the junkyard transmission since you won't need them. Take a picture of the order they go in for reference for when you take apart your transmission.
326WHP 347TQ
Old 10-30-2018, 11:47 PM #10
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Thanks gamefreakgc!
You might find this useful?
A340 Series Repair Manual (RM216)
can someone please download this file and report back if it works?
ITP also did a valve body vid
https://youtu.be/vZFwSP2TbTY
I have a couple of extra valve bodies but they are out of a 99 and 97, otherwise I would just send one and ask for shipping. It’s not hard to take the valve body out. The service manual has the lengths of the bolts listing in diagrams.
Old 10-31-2018, 09:01 AM #11
thegipper's Avatar
thegipper's Avatar
I don't think its a night and day difference between the 96-00 tranny's and the 01/02 tranny's but the 01/02's have been more prone to planetary/sun gear failure based on the reports on this forum and others.
Lets just say it's not enough of difference where I wouldn't buy an 01/02 because I was worried my tranny was going to blow up at 150k miles but there does appear to be more failures than the earlier model 3G's.
2011 Camry SE V6
Old 10-31-2018, 10:35 AM #12
BigIron53's Avatar
BigIron53 BigIron53 is offline
Real Name: Van
BigIron53 is on a distinguished road
BigIron53's Avatar
Real Name: Van
Song remains the same
My 02 2WD 4Runner is in the shop right now having the P0770 shift solenoid E code troubleshot. I have recently swapped in a new motor (old one blew) added a SC, 7th kit, headers, and a 2.2” pulley. As a precaution I sent my valve body to IPT for an upgrade, guy at IPT found a lot of metal shavings in it and said to send the tranny. Long story short, new motor, re-built/upgraded tranny, torque converter and upgraded valve body installed. Now I’m getting the code, the shop is conferencing with IPT today to try to figure it out.
BigIron53 is offline   Reply With QuoteReply With Quote
Old 10-31-2018, 10:39 AM #13
absalom's Avatar
Real Name: Jordan
absalom's Avatar
Real Name: Jordan
Yup, that's the exact same weakness I see cited. But unlike LBJ failures, I've yet to see a single example. Certainly not suggesting they don't happen, just that I haven't seen them.
Old 10-31-2018, 10:58 AM #14
thegipper's Avatar
thegipper's Avatar
Off the top of my head, I believe Infamous had his tranny go out (01/02) and I believe it was due to planetary gear failure, or at least that's what they thought (Tim and Sean).
2011 Camry SE V6
Old 10-31-2018, 02:43 PM #15
BigIron53's Avatar
Real Name: Van
BigIron53's Avatar
Real Name: Van
Update
I just heard back from the techs who have been coordinating with IPT. Everything checks out just fine and they are thinking that the code is popping because of the size of the tires. I’m running 33” tires which throws off the speedometer. Since the tranny in my 02 only receives the same speed as the speedometer the computer is getting a miscompare and popping a code. Ever heard of it? Make sense?
Torque converter DIY? jman11788 3rd gen T4Rs 33 06-07-2022 10:58 AM
Torque Converter? 4Runner4TW 3rd gen T4Rs 17 05-22-2021 11:28 AM
Torque converter. I may need a new one. cbielat 5th gen T4Rs 23 02-24-2020 11:18 AM
New Torque Converter mochilln00 3rd gen T4Rs 12 12-22-2016 12:43 AM
Torque Converter? braves2 3rd gen T4Rs 1 03-14-2011 04:22 PM
