Old 07-15-2019, 11:44 PM #1
toyotaspeed90 toyotaspeed90 is offline
toyotaspeed90 is on a distinguished road
Just saying Hi... new to us, 97 Manual 3.4, 4x4
Definitely not new to Toyotas... this is probably north of #40, or more... who knows.
Current stable is...
2017 Prius V4 (dont laugh - 40mpg is about the worst we get, been north of 85mpg)
1988 FJ62 (currently under the knife in the garage for roof rot repair)
2001 Lexus LX470/100 series
And the 1997 T4R.
2nd 4Runner I've had, had a first gen AT 4cy about 15 years ago....
Some other notable/odd/"rare" Toyotas I've had...
1970 FJ40 frame off rustomod with a Megasquirt m/TBI 350
2004 Lexus IS300 sporr design manual/lsd
1988 Corolla Alltrac wagon (AE95)
1993 3x locked FZJ80
About 11 first gen MR2s and many engine variations (4age, 4agze, 7age, 5sfe)
Picked up a 97, manual, 3.4, 4x4 with 315k miles a couple weeks ago.
$2k, came with most parts to do a timing belt. Unfortunately it needed tires and a SERIOUS interior cleaning.
Completed most of the interior cleaning and the timing belt service (with pulleys, pump, tensioner, belts, radiator hoses), and got new tires on it.
Simple plans are... air lift bags in the rear (put them in the LX and really like them, even with the factory hydro suspension), 4ch amp with new components front and rear, LED headlights, then any other maintenance items that pop up.
Been reading about Tundra/LC suspension, so thinking/researching that. Mostly it will be a field truck for my wife and just a good enjoyable manual trans vehicle.
Will have to post photos after I resize image sizes, I guess....
toyotaspeed90 is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 12:27 AM #2
Should also add... zero, and I mean zero, rust on this thing.
The FJ40 was rusty, required new floor panels be put in and the tub was swiss cheese still. The 62 has rusty parts and a rusty roof (otherwise very clean). The FZJ80 had very mild rust on bolts. Hell, even the IS300 had some rust on bolt heads.
At 315k miles its the cleanest high mileage vehicle I've ever seen. Surface rust on the exhaust is the most I've seen.
Old 07-16-2019, 12:53 AM #3
Pictures attached
Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190703_202614_compress87-jpg  Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190703_202554_compress74-jpg  Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190703_202540_compress31-jpg  Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190704_122510_compress45-jpg  Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190705_154707_compress74-jpg  Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190705_163203_compress85-jpg  Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190706_191145_compress61-jpg  Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190715_192941_compress41-jpg
Old 07-16-2019, 01:01 AM #4
eddielasvegas eddielasvegas is offline
Real Name: Eddie
eddielasvegas has a spectacular aura about eddielasvegas has a spectacular aura about
Real Name: Eddie
Hello and Congrats toyotaspeed90.
Very nice T4R you have there and most excellent color.
Eddie
2001 T4R SR5 - 180k miles and counting.
eddielasvegas is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 11:32 PM #5
Will throw some photos up soon.
LED headlights - check
4ch amp (Hifonocs) - check
Front and rear 6.5" MB Quart components - check
Newly evacuated and charged A/C with new button- check
Installed USB charger - check
On order - Tundra Bilstein 5100s for the front
NOS (well, ~100 miles) 2008 T4R rear shocks and all 4 springs
Waiting to go in - all ball joints and inner/outer TREs
Old 08-07-2019, 11:58 PM #6
For installing timing belts this is a trick I used/came up with well over a decade ago that I've used on MR2 timing belts. Helps keep the belt in place without jumping teeth nor allowing the cam gears to move independently.
Not tight, but taught in the clamps. Worked like a charm.
Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190709_211029_compress30-jpg  Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190709_211035_compress47-jpg
Old 08-08-2019, 12:03 AM #7
For the components-
The front stock tweeters were still perfect and the MBs wouldn't fit, so just wired those to the MB crossover. The crossover was mounted into the stock recessed housing with some minor cutting.
Rears didn't fit in the housing, so I cut and installed them into the panel. Not my first choice. but is what it is.
Amp is simply under the seat.
Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190724_133535_compress59-jpg  Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190724_133539_compress69-jpg  Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190724_203134_compress89-jpg
Old 08-08-2019, 12:21 AM #8
For the components-
Images shouldn't be sideways. They show normal on my phone both pre and post editing to reduce size.
Old 08-08-2019, 12:25 AM #9
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about
Real Name: Ryan
Quite a fleet you have/have had. Looks like a solid buy assuming you don’t run into anything out of the ordinary.
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
1999 BMW Z3M Roadster
2020 Super White ORP
Ryance39 is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 01:20 PM #10
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
Who on earth put a 5s-fe into a first gen mr2? The horror.
APhelps is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 08:08 PM #11
Those who have more first gen MR2 experience than most.
Same day at autox I drove my 87 hardtop with an ae101 gze, ae102 c52 trans, running on MS (faster by a second than the 88 SC with a rebuild and 10psi pulley), a race seat and great tires.... I also drove my 86 sunroof with the 5sfe/s54 swap, full interior, taller suspension, didnt have the swaybars the 87 had and was on 300+ tread street tires... was also the first time driving that vehicle with the swap... a time difference of 0.3 seconds.
Not quite the throttle response of that GZE, but very similar power, cheaper parts, way more miles, and way more reliable.
That 86 went through 3 engines in 3 months. I was sick of trying to source tired 4ages that nobody wanted to give up. The swap cost about $700 total including engine, trans, axles, wiring, mounts, exhaust/header, plus maintenance parts for the motor.
Old 08-12-2019, 05:04 PM #12
I guess reading, research and comprehension (or lack thereof in this case) did me wrong.
The 2008 rear shock sent to me are XREAS. Thought, shortly, how i could make them work- then ordered Bilsteins for the rear.
Those, along with the diff drop kit (just in case) arrive today.
If the FJ62 sells today then the T4R will head in soon to go under the suspension knife.
Will post photos....
Not even sure if I ordered the fronts as 4runner or Tundra... guess I'll find out here soon.
Old 08-13-2019, 05:29 PM #13
5 Speed Dave's Avatar
5 Speed Dave 5 Speed Dave is offline
Real Name: Dave Warren
5 Speed Dave will become famous soon enough
Congrats on the NICE find!
That sure is one nice clean 4Runner you found, Toyotaspeed90! Way to go!
Those 5 speeds are out there if ya look really hard. Looks like you know your way around the garage.
An interesting stable you've had for sure.
I always thought it would be cool if cars could talk to us and tell their stories
(but not while we are driving....)
5 Speed Dave is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 05:45 PM #14
SantaCruzRunner's Avatar
SantaCruzRunner SantaCruzRunner is offline
Real Name: Drew
SantaCruzRunner is on a distinguished road
Real Name: Drew
Nice looking rig. I just picked up my third 3rd gen, a 2000 SR5 4x4 5 speed.
SantaCruzRunner is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 02:50 PM #15
Well that didn't take long.....
Just saying Hi... new to us, 97 Manual 3.4, 4x4-20190818_113639_compress84-jpg
gen , lexus , manual , rear , suspension
FS: 1995 Toyota 4Runner OEM Manual and Haynes Manual 20 shipped 3RDGENGuy For Sale: T4R Items 2 10-28-2015 02:13 AM
People with manual swaps, auto or manual t4r kolelt 3rd gen T4Rs 16 08-19-2015 02:12 PM
Chilton Manual vs. Haynes Manual Genesis98 Classic T4Rs 11 02-05-2008 11:41 AM
Hello and manual, etc. Road Warrior 4th Gen T4Rs 2 07-02-2007 02:23 PM
'97 manual hulk311 4th Gen T4Rs 1 02-27-2007 07:09 PM
