Old 07-16-2019, 08:52 AM #1
Mudeprived Mudeprived is offline
Mudeprived is on a distinguished road
Preparations for no-start
So my lady borrowed my truck for a lengthy trip to her sister's and came back a few days later. I took the truck to work the next morning and seemed like battery lost a bit of it's charge when I attempted to start it to go home. It made this loud fast clicking. My lady brought her car over and it started on the first jump. First thing I checked was lights that i may have left on but evverything was off. I drove it around town and checked battery when it was parked for a few hours. It read 12.7 volts. This morning it was at 12.3 volts and started right up.
She is leaving again for a week and taking the car so I am alone with the truck. I would like to be prepared on what to check or fix if it happens while she is gone since there is no other mode of transportation and I live a bit of a distance from town.
So what could have caused this random low battery no start?
Battery is an Interstate and has been flawless since I bought the truck in Jan of 2016. Not exactly sure how old it is but I can look it up in the maintenance docs.
It might just be the battery though but open for other possible issues.
Thanks
1999 Limited 182k miles
1999 Limited
265/75/16 AT51's
Bilstein 4600
Mudeprived is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 09:14 AM #2
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
Voltage should be 12.7-12.9 per the FSM. Summer heat kills batteries, take it to Autozone or another parts store to get it tested for free.
'99 T4R SR5 V6 4WD Imperial Jade Mica | B&M Trans Cooler | KYB Gas-a-Justs | URD O2 Sim | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 09:47 AM #3
jgue467's Avatar
jgue467 jgue467 is online now
jgue467 will become famous soon enough
jgue467's Avatar
Just get a new battery
Originally Posted by Mudeprived View Post
So my lady borrowed my truck ...
It made this loud fast clicking. ...This morning it was at 12.3 volts and started right up.
...bought the truck in Jan of 2016.
It might just be the battery though but open for other possible issues...
At at least 3.5 years old, more than likely the batt needs to be replaced.
Why not zip down to wallymart or your favorite place to buy a batt and have it stress tested? Takes all of 2 mins.
Not sure how hot it is in your area but in central texas no battery survives a 4th summer....
Luck and enjoy the Runner.
2001 Limited 4WD - 317K - SunfireRed\Thunder Cloud; - 265/75/16 Michelins - Fat Pat's 1.5" BL
StopTech slotted rotors - Magnefine trans filter - In series trans cooler, Original: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and on and on. WooHoo!!
jgue467 is online now   Reply With QuoteReply With Quote
Old 07-16-2019, 11:03 AM #4
What is involved in a stress test? Any way to duplicate the test at home? I got a multimeter.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Old 07-16-2019, 11:51 AM #5
Brian.'s Avatar
Brian. Brian. is offline
Brian. will become famous soon enough Brian. will become famous soon enough
Brian.'s Avatar
The more common term is "load test", and you can DIY duplicate it by watching voltage while attempting to start (with as much electrical load on as possible, so radio, seat heaters, fans on high, rear defroster, etc...) If it drops below 10vdc, it's done.
No reason to DIY it though, every auto-parts store will do it for free. Same test will check the alternator, which could be the reason the battery is having issues and if not identified, could cause your replacement battery to die and early death too.
FWIW, I've seen batteries that show 12.7vdc with no load and struggle with 6vdc with a small load. Some were older, a couple were within a few months old and one was new right out of the box (that was a PITA to troubleshoot, easy to assume a new battery is good and neglect testing it).
Brian. is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 12:22 AM #6
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton is on a distinguished road
pluton's Avatar
Real Name: Keith
Invisible corrosion on the terminals and connectors at the battery does this. Clean both with wire brush. Auto parts stores sell a handy tool for this usually under $4. Maybe insert some of those anti-corrosion felt thingys underneath the clamps while you are at it.
pluton is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 05:47 AM #7
Did that not long ago when I made new terminals.
Looking like you guys might be right about the battery and heat. It starts in the morning but not when I leave work and it has been near 90 outside the past few days. I had a chance to go through the maintenance documents and turns out the battery was installed in 2010 so it is pretty darn old!
Time for a bunch of research on which battery to go with.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Old 07-17-2019, 07:24 AM #8
Brian.'s Avatar
Brian.'s Avatar
There's a major battery mfg right there in PA... East Penn ~ East Penn Manufacturing | World-class battery manufacturing facilities
It's been a long time since I've looked myself, but I seem to remember that they were consistently recommended. I wouldn't do anything costly like Lithium unless you plan on changing your alternator as well, they require different charging parameters.
battery , bit , checked , town , truck
2018 TRD OR install aftermarket Push to Start & Remote Start? Aggie2015 5th gen T4Rs 0 09-06-2018 04:30 PM
Remote Desert Travel Preparations eric_rosenwald General Discussions 31 06-03-2014 08:24 PM
RFID Keyless Entry, Push Button Start and Remote Start BFLAN 5th gen T4Rs 41 04-17-2012 09:36 PM
2000 4runner wont start without clutch start cancle jmcgahran 3rd gen T4Rs 3 08-29-2011 12:27 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
