Old 07-16-2019, 11:56 AM #1
Hokie-Pokie VT's Avatar
Hokie-Pokie VT Hokie-Pokie VT is offline
Hokie-Pokie VT is on a distinguished road
Towing with a Manual - Clutch Replacement
Hello Ladies and Gents.
Looking to get a new clutch on the '00 SR5 5 Speed. We tow the family boat with this vehicle, roughly 3000lbs every other weekend or so. The vehicle was bought with a brand new clutch, but that was over 80k ago. No clue if the clutch that was put in was OEM or A/M.
If anyone else with a 5 spd out there can tell me, with the towing load on this vehicle would you recommend a Toyota or A/M clutch? I have no idea how beefy an OEM toyota clutch is (or how expensive), and I know that there are good A/M ones designed for towing.
Any advise or expertise would be greatly appreciated.
Thanks!
2002 4Runner SR5 4WD
Hokie-Pokie VT is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 09:30 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The OEM Clutches are very good. I have seen some of the A/M ones scatter in the old 80's toyota pickups as they were all standard until around 1987 ( I think)
If the clutch isn't slipping, I wouldn't change it. However, when you do. Be sure to make sure they flywheel isn't blued or any cracks on its surface. If it does, be sure to replace it as well. When I do clutches, I change the pressure plate, throw out bearing, pilot bearing and clutch. If getting really higher mileage, I will change the real engine main as well.
When I use marlin crawlers, I am sure other folks out there use other clutches or even use the OEM clutches as well. :-)
This is why I chose the Marlin Crawlers kits:
All kits feature new parts. Each Kit Includes:
Heavy Duty 1,200 ft-lb Pressure Plate (stock pressure plate is 900ft-lb)
33% higher load rating than stock
Heavy Duty Metallic Clutch Disc
Japanese Release Bearing
Pilot Bearing
Alignment Tool
The rest of the parts I get OEM. This is just what I do. Hope it helps. :-)
a/m , clutch , oem , towing , vehicle
How long has your manual clutch lasted? masphx 3rd gen T4Rs 26 08-16-2019 03:21 PM
Advice on replacing the clutch in 99' manual 4WD JoshKY 3rd gen T4Rs 1 01-01-2019 09:47 PM
Clutch pedal for manual swap? GlassHammer 3rd gen T4Rs 8 02-17-2017 02:46 PM
manual trans- RPMs up and down when clutch is in??? thorridder 3rd gen T4Rs 9 03-05-2012 09:59 AM
Manual Clutch Recomendations Twoods927 3rd gen T4Rs 12 01-20-2010 11:12 AM
