Old 07-16-2019, 09:18 PM #1
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
homemade ECG needle bearing puller, hey it worked
I figured while I had the front reverse clam out I would put in a ECG bushing. for some reason I failed to order the removal tool so because I'm way to impatient to wait for shipping I decided to make my own and as a bonus this time it worked.
I used the longest M12 1.25 I had laying around and welded a M12 nut to a scrap of steel and ground it down until it just slips into the right place under the needle bearing lip.
I also had to thread the entire bolt because of course nobody local (aka home depot) does not have fully threaded M12 1.25 bolts. I had a die on hand and it was that was fun. of course I could have used a different non metric size and just purchased some threaded rod. however that would not be Toyota like. you must suffer in the USA with crappy non metric! said a voice from the clouds.
I'm also wondering if anybody knows the parts # for these special E14 bolts? I can't seem to find them on the parts diagram.
I think there are 4 short ones and 2 long ones (about 100mm I think) see pict.
Old 07-17-2019, 12:21 PM #2
Should be:
BOLT (FOR DIFFERENTIAL CLUTCH CASE SETTING)
90107-12001 *12-1.25PX85-30 2 $5.42
90109-12029 *12-1.25PX20-14.5 4 $1.74
First one is 85mm long (flange to end of bolt), 2 per vehicle, other is 20mm long, 4 per vehicle.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-17-2019, 02:14 PM #3
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by phattyduck View Post
Should be:
yea it's weird the parts diagrams seem wrong for these bolts
it shows them all as 41435A on the diagrams and also gives them all the same part number 90109-12029
and when I do a validation it tells me "This part does not fit the vehicle you selected:"
Thanks I figured somebody had run into that before and just knew.
Cheers
Old 07-17-2019, 02:26 PM #4
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
can you tell me what ECG stands for? i tried to search on google and all i could find was 'ECGS'. which i also have no idea what that stands for. assuming they are the same thing?
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 03:03 PM #5
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
yes
TOYOTA CLAMSHELL BUSHINGS - 96-02 4runner
this is the bushing that replaces needle bearings and also the tool they sell. sorry yes I should have been more careful about my acronym.
Old 07-17-2019, 03:08 PM #6
MN4runnerman's Avatar
MN4runnerman MN4runnerman is offline
Real Name: Samuel
MN4runnerman will become famous soon enough
Real Name: Samuel
Discount steel in Minneapolis surprisingly has full length threaded bolts in a lot of sizes. I mean too late now tho lol
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
MN4runnerman is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 03:13 PM #7
ncjeyota ncjeyota is offline
ncjeyota is on a distinguished road
ECG should be ECGS which is EAST Coast Gear Supply
ncjeyota is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 04:11 PM #8
awesome, thanks you two. i am not new to cars/wrenching in general, but i am very new to the 4wd world. looking to learn as much as i can!
IG: mesooohoppy
bolts , ecg , m12 , metric , parts
Rear axle bearing puller tool fixxor 3rd gen T4Rs 15 12-29-2018 07:48 PM
Evap codes, needle bearing/wheel bearing and tires Johns06yota 4th Gen T4Rs 15 08-05-2018 11:10 AM
Needle Bearing and CV Axle kremlon 3rd gen T4Rs 11 04-27-2017 09:26 PM
Rear Bearing Puller Tool coinball 3rd gen T4Rs 12 11-28-2016 09:39 PM
