Old 07-17-2019, 08:22 AM #1
Serge627's Avatar
Serge627 Serge627 is offline
Serge627 is on a distinguished road
Serge627's Avatar
01-02 E Locker swap question about FRONT Diff
Hey guys,
I have an 02 3.4 and intend on swapping over a factory elocker. I found a good donor at a local yard that has a 98 factory locker. I have watched Timmys video and read plenty of threads on the swap. I plan to obtain the rear axle, harnesses, locker ecu out of the donor 4R.
My question is in reference to the front diff. My rig has stock 4.10's. The swap will have 4.30's, so I intended on getting the front diff to swap in as well. Issue seems that there is a difference in the 01-02 front diffs. Apparently the earlier models (pre 01) have vacuum lines running to their front diff, where the 01-02 are electronic.
So whats the correct way to do this? Do I need to regear my front with a gear swap or can I swap front Diffs??
Serge627 is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 09:05 AM #2
Taylor20's Avatar
Taylor20 Taylor20 is offline
Taylor20 will become famous soon enough Taylor20 will become famous soon enough
Taylor20's Avatar
I did this swap on my 02. For the front, swap the A.D.D. tubes. Put your 02 tube on the 98 diff. You will need an E-14 torx socket and patience. You do NOT want to strip out those bolt heads. Also orange FIPG from Toyota is recommended. Might as well replace the axle seals while your there, just takes an extra 10 minutes.
IF the 98 is non-ADD, then you will also need to make sure swap the 02's stub shaft into the 98 diff.
02 Sport
Toytec Boss/LJ - TRD Pro & 255's - TBU - 4:30's - Elocker
4xI - AED - Savage
Taylor20 is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 09:17 AM #3
Serge627's Avatar
Serge627's Avatar
Ok, thats helpful. I appreciate the info from someone who has dealt w that issue.
Old 07-17-2019, 10:47 AM #4
deves2 deves2 is offline
deves2 is on a distinguished road
all you have to change is the actuator, its only 4 bolts . easier than changing the axle tubes.
deves2 is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 11:42 AM #5
kgnagey's Avatar
kgnagey kgnagey is offline
kgnagey is on a distinguished road
kgnagey's Avatar
Subscribed. I'll be following this one for updates.
2018 4Runner ORP
2002 4Runner SE - Sold
kgnagey is offline   Reply With QuoteReply With Quote
01-02 , diff , front , locker , swap
rear diff swap to e-locker Thumper84 3rd gen T4Rs 7 05-20-2016 11:02 PM
Aussie locker in front diff Kraze 3rd gen T4Rs 23 01-18-2014 03:05 AM
Andy Mod 2.0 and Diff. Locker Question BigLogs 3rd gen T4Rs 2 02-13-2013 04:07 AM
E locker swap question imryannn 3rd gen T4Rs 9 02-21-2012 08:40 AM
