Old 07-17-2019, 01:24 PM #1
psea17 psea17 is offline
psea17 will become famous soon enough
Interchangable Spares
Need a little guidance.
I have a travel trailer. It has exactly the same size tires/rims 265/75R16 as my '98 4runner. It has black procomp rims. Unfortunately, while they have the same lug pattern 6 bolt 5.5, they don't fit on my truck. The lugs have a different thread pattern and there just isn't enough room to screw them on.
The truck still has the stock 16" rims. What do I need to purchase so that I can use my truck's tires on the travel trailer?
ps- is anyone able to store a 265/75/16 under the truck in the spare tire location? Did you need to do anything to accommodate?
Thanks in advance!
Interchangable Spares-img_20190717_101645-jpg  Interchangable Spares-img_20190717_101615-jpg
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 05:15 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
My michelin atx lt2s (265/75/16) won't fit inflated, perhaps deflated, never tried that.
Luck.
Old 07-17-2019, 05:57 PM #3
HiLife HiLife is offline
The stock 5 star rim with a deflated tire fits in my stock location underneath. Dont know bad if it rubs the pan bar though as I havent dropped the tire to check.
Old 07-17-2019, 07:53 PM #4
ThySenteth's Avatar
ThySenteth ThySenteth is offline
ThySenteth is on a distinguished road
ThySenteth's Avatar
While it may share bolt pattern, the hub bore may be different, and that's what's not allowing the trailer rim to mount to the 4runner. Looks like maybe the trailer rim has a smaller hub bore.
If it does fit (hard to tell in that picture) and the studs on the 4runner just aren't long enough, you may be able to buy longer studs to press in..
ThySenteth is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 08:23 PM #5
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
The stock 4Runner wheel uses a mag style lug nut, so you would have to find out the lug diameter, length and thread pitch of the trailer’s hub to be able to find the proper lug nut that would allow you to mount the stock wheel to the trailer. I’m sure the trailer manufacturer has a hotline you could call to confirm if the info isn’t readily available online.
Procomps use a weird extended shank lug nut. Post #8 here shows what they use, just for reference.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 12:45 AM #6
sandracer33 sandracer33 is offline
Real Name: Lee
sandracer33 is on a distinguished road
Real Name: Lee
Are you trying to use the stock wheels on the trailer, or the Pro-Comps on the truck? I have the same 16 X 8 Pro-Comp LaPaz wheels on my 4Runner. You just need the correct lug nuts. They are 12 X1.5. They fit fine with Tundra brakes & 285/75-16 BFG. As far as I know there is only one center bore size they offer. If it's the stock wheels on the trailer, if you know the thread size and pitch of the studs, a good tire shop should be able to find you lugs that will work.
Interchangable Spares-4runner-wheels-jpg
"Mongo only pawn in game of life..."
sandracer33 is offline   Reply With QuoteReply With Quote
Old 07-19-2019, 11:01 AM #7
Both. I want the tires to be interchangable.
Manual Transmission
pattern , rims , trailer , travel , truck
FJ Rims & BFG Mud Terrains 255/75/17 (5 + 2 spares) Bumbo For Sale: Suspension/Wheels/Tires 2 11-29-2018 12:44 PM
Two spares, Oregon Vinsil For Sale: Suspension/Wheels/Tires 0 07-12-2018 12:50 PM
FS: 3rd gen 5star wheels for spares $50 VA sb253 For Sale: Suspension/Wheels/Tires 8 07-07-2015 03:58 AM
