Old 07-17-2019, 02:24 PM #1
skillbill skillbill is offline
skillbill is on a distinguished road
Bushings
Started ordering parts for lift and lbj replacement along with new tie rods. While in there I want to replace all my bushing ( uca, lcr, sway bar and rack& pinion) what the best brand to go with? Toyota, whiteline etc?
skillbill is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 02:28 PM #2
motorwinger motorwinger is offline
motorwinger is on a distinguished road
Smile Bushings
I have a 01 Gen 3 and just had LCA Bushings, CV Boots and LBJ done on mine. I purchased Toyota OEM parts based upon my mechanics recommendation. The labor time for LCA bushings is 6 hours and do LBJ at the same time.
motorwinger is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 02:41 PM #3
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend will become famous soon enough
LBJ always do OEM
LCA if you do not do OEM Whiteline is supposed to be the best option.
Sway bar I think Energy susupension is the popular choice
Rack and Pinion Energy suspension is the best choice.
Not sure about UCA have not dug into that yet.
This is based on all my research on this forum.
I've had the whitelines install buy a quality Toyota shop and they said they are the best option if not going OEM.
1999 SR5: ELocker Retrofit, 99 talls-tundra Billy/LC 8 wraps-FJ Billys, Savage skids, TruckShopSD Sliders, Eimkeith PHC, ARB diff breather, F/R DuroBumps, 285 BFG KO2, Doug Thorley Headers
4runnerfiend is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 03:51 PM #4
Angrywelder Angrywelder is offline
Angrywelder is on a distinguished road
I did this to mine when I put the lift on. I ended up rebuilding the suspension all the way around. From using both factory and aftermarket bushings my opinion would be this. For lower control arm, lower ball joint, upper ball joint, upper control arm, I would use factory bushings. The rest of the bushings, steering rack bushings, sway bar bushings, rear control arm bushings, I would use aftermarket bushings. Also, I would change the end links for longer ones. You can use the stock 3rd gen front end links on the rear sway bar as they are about 1" longer. For the front sway bar use end links from a 85 front sway bar as they are 1" longer than stock 3rd gen. If your going to reboot the CV-Axles, I would do the extended boot mod also.
Angrywelder is offline   Reply With QuoteReply With Quote
bar , lcr , pinion , rack , sway
LCA bushings Gatafly 4th Gen T4Rs 18 07-28-2016 10:52 PM
95 4x4 upper & lower control arm bushings replacement HELP!!! and rear bushings??? mark808 Classic T4Rs 18 07-08-2013 01:11 AM
Bad bushings stlfan Engines / Suspension / Wheels / Tires / Audio / Accessories 1 06-17-2012 09:35 AM
Upper control arm bushings (do poly bushings exist?) jamess 3rd gen T4Rs 20 02-21-2011 04:07 PM
Bushings, Bushings, Bushings cordrayj1 3rd gen T4Rs 2 07-08-2010 02:50 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
