Old 07-17-2019, 03:06 PM #1
jkmcrg jkmcrg is offline
jkmcrg is on a distinguished road
key slipped while starting - now it's dead!
Interesting thing happened after I took my friends out to lunch. We all got in the hot car, I put the key in, turned it to start it up, and just as the starter barely got a chance to start turn, the key slipped out of my hand and it sprung back to the off position.
Immediately, all electrical went dead in any key position. Battery is at 12.8v, tried to jump it with no change. With the key is in the ignition and the door is open you can hear it intermittently sort of starting to ding ding indicating open door, but it's just little chirps as it tries to play the sound.
1999 3rd gen T4R 2WD Limited
jkmcrg is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 03:40 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Certainly unusual. Have you checked the 'big' fuses in the engine bay? There are a couple/three high amperage ones that may be involved here or even some of the smaller ones.
Only other thought that comes to mind right now, is perhaps disconnect battery for a good 5 mins then re-attach and try starting. Otherwise...
This sounds like a job for 'The Durk', call him out.
Luck.
Old 07-17-2019, 03:42 PM #3
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
sounds like a dirty, or poor connection at the battery. remove and clean the cable ends. try again.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 05:57 PM #4
Thanks for the quick responses! Y'all were right! Key-flick was a complete red herring (even though this was the first time this has happened!!)
Turns out it was the problem of an aftermarket ground terminal - it was the style that you clamp a bare wire in, but the toyota ground is a crimped ring terminal, and they just stuck it on one of the clamp bolts. The entire aftermarket terminal was PAINTED except for where the bare wire goes. The car was grounded THROUGH PAINT for the entire 3 months I've owned it - how has this even been starting!!!
Old 07-17-2019, 07:04 PM #5
The Toyota terminals are expensive but worth it.
door , key , open , slipped , start
Transmission slipped today, replaced it last year...should i panic? theriddler 3rd gen T4Rs 32 07-17-2018 01:23 AM
Timing belt slipped 5 notches... What to do? Maui Cruiser Classic T4Rs 11 05-21-2015 04:58 PM
Slipped thru my fingers Synister 3rd gen T4Rs 2 02-09-2010 06:15 PM
AC slows down when starting from a dead stop boardboyjes Problems & Warranty Issues 0 01-17-2010 12:59 AM
