Old 07-17-2019, 07:03 PM #1
Septimius Septimius is offline
Real Name: Tim
Septimius is on a distinguished road
Real Name: Tim
Pricing help needed
Hey Folks,
Firstly forgive me if this is the wrong area to post this in and feel free to move it.
I am paring down the fleet and consolidating to a pickup truck that can easily tow the boat and the track car / motorcycles (not at the same time). As such I am going to be selling the 3rd gen (among other fun stuff) and need some help determining what a fair price would be. I don't want to think what I'm into it for, and I don't want to overestimate what it's worth and sit on it forever or underestimate and have someone flip it. Specs are as follows:
2001 SR5, Auto, 190k miles
The good:
Absolutely everything works (power windows, locks, sunroof, rear slide window, even antenna, AWD, 4WD HI and LOW, cruise control etc)
Never had any mechanical issues (knock on wood)
Previous owner did B&H trans cooler to avoid trans contamination issues
Weathertech liners front and back
Tow hitch receiver with 4pin wiring harness that works great
Work done within the last two years since I've had it (have all receipts):
Coolant flush and change
ATF flush and change
Brake fluid flush and change
New gear oil in both diffs and the transfer case
New 2nd catalytic converter and 02 sensor
New OEM cat back exhaust
Almost new (less than 5k on them) Kumho AT51 A/T tires 265/75 16
New battery
New Pioneer headunit with bluetooth music playback and wired with mic for phone calls
The meh:
Timing belt done at 118k (coming up soonish)
Some surface rust on underbody (started life as a NJ car then moved to WNY)
Few scratches and dents on the bodywork (couple on front bumper and one on hatch, see pics)
Couple scratches in the interior (passenger dash and passenger door, see pics)
Brakes work well but there's a grinding noise from the left front when turning left, think it's a backing plate scraping but haven't had a look
Previous owner replaced shocks 3 years ago but they're the cheapo NAPA ones, could probably use an OME kit or new OEM stuff
1 accident on carfax (minor)
The bad:
Rust on the front right middle edge of hood.
Throws CEL for EVAP leak. Quoted over $900 just in parts with no guarantee that it would be fixed. Doesn't affect the truck at all, but in order to pass NYS inspection it needs to be addressed or you need to reset CEL and drive it while keeping it over 3/4 of a tank (doesn't check for EVAP until below) until every monitor other than that sets (allowed to have one monitor not set and pass inspection as long as it's not throwing a code yet). Is currently inspected through October. Wouldn't be an issue for folks that live in a non inspection state (PA etc).
I may be forgetting some stuff and will update if I remember it. Added photos in the post below. Any thoughts on price / suggestions are much appreciated!
Thanks, Tim
Last edited by Septimius; 07-17-2019 at 07:51 PM. Reason: Updated and added photos
Septimius is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 07:18 PM #2
Real Name: Tim
Real Name: Tim
Pricing help needed
Old 07-17-2019, 09:08 PM #3
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
I live in Michigan so I can speak from the northernish climate and we have tons of salt as well. 190k miles in current condition I'm thinking 3500? Book it out for your zip but someone out here in that condition as long as frame is solid would have no problem paying 3500 bucks. It needs a little work but nothing major.
VernySanders is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 09:38 PM #4
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Looks good, and mileage isn’t a concern. I had a 2001 in Ohio and at 265,000 the frame had rusted to the point it became unsafe. So folks on this forum would want to see pics of the underside. But like yours, everything worked, down to the antenna. Flawless engine, too.
Also, mine had an evap CEL for 10 years. Never could fix it. Then one day a few years ago I was filling it with gas and fuel started spilling off the top of the tank while still not reaching the top of the filler neck. Apparently the seal between the filler neck and tank had deteriorated, possibly from years of over-filling. Maybe this threw my evap code? Just a thought.
thennen is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 10:55 PM #5
Real Name: Tim
Real Name: Tim
Thanks for the input! You think it's worth me buttoning up the brakes etc before listing it? Or does that not play a huge role in the price.
Old 07-18-2019, 10:04 AM #6
Real Name: Werner
Real Name: Werner
If its test driveable I'd let the buyer decide. If it was me I'd want to do them myself cause I domt trust people's worm but a different buyer may want you to take care of them. Always something you can throw in to close a deal
Old 07-18-2019, 10:10 AM #7
Real Name: Tim
Real Name: Tim
I’ll take a couple pics of the undercarriage when I get home today. It’s very solid, there was one spot on the 3rd crossmember that I didn’t like so I replaced the crossmember (bolts in) other than that it’s just surface rust. Suppose someone could take a wire wheel to it and paint or rust prop it if they wanted to.
I’ll take a look at the filler too, the shop was telling me it was the charcoal canister.
Old 07-18-2019, 12:36 PM #8
PHGen3 PHGen3 is offline
PHGen3 is on a distinguished road
It is amazing how these trucks typically hold up appearance wise. Yours looks pretty good. $3,500 doesn't sound too bad.
PHGen3 is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 12:42 PM #9
TheLincolnGreen TheLincolnGreen is offline
TheLincolnGreen will become famous soon enough
$3500 would be the low end in my area. $5000 is what I would expect to see one similar listed for.
TheLincolnGreen is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 07:25 PM #10
Real Name: Tim
Real Name: Tim
Pictures of the front and rear undercarriage plus the crossmember I replaced.
Old 07-18-2019, 08:49 PM #11
Hepar's Avatar
Hepar Hepar is offline
Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough
Hepar's Avatar
Sorry, but there's zero chance that is just surface rust.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
Hepar is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 08:56 PM #12
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
It's really too bad these rigs weren't treated with some kind of anti-rust undercoating before they ever left a dealer lot. Especially in snow country where they salt the roads.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 09:04 PM #13
Real Name: Tim
Real Name: Tim
I can pound on it with a hammer or stab it with a screwdriver and it’s not soft. Ergo sum it’s rust on the surface of the metal not rot throughout. Maybe surface rust has different definitions depending on where you are but compared to other vehicles around here that is surface rust. As in not rotting away and falling apart like cherokees or wranglers or xterras.
Old 07-18-2019, 09:24 PM #14
Real Name: Tim
Real Name: Tim
I would think they were, or at least Yota used better quality / thicker metals than competitors. There is a stark difference in between how Toyota vehicles have held up vs others (both domestic and foreign) of the same age in the rustbelt.
Old 07-18-2019, 10:06 PM #15
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
$3000 min as is, $4-6k if you fix a few things, treat the frame with something and have it fully detailed.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
change , flush , inspection , price , stuff
01 T4R pricing? hcrissman 3rd gen T4Rs 15 05-25-2016 12:39 AM
06+ Pricing jbmccul 4th Gen T4Rs 6 02-06-2011 09:23 AM
Pricing Mtbdude 3rd gen T4Rs 3 07-23-2010 12:27 PM
Little help with pricing? JohnsD90 3rd gen T4Rs 12 03-30-2010 07:24 PM
Pricing on SR5's silver4x419 4th Gen T4Rs 17 04-28-2004 05:12 PM
