Old 07-18-2019, 03:05 PM #1
mc813's Avatar
mc813 mc813 is offline
mc813 is on a distinguished road
mc813's Avatar
Brake pedal goes to floor + dragging?
Hey guys, trying to figure out where to start when I get home later. 3 days ago I noticed something seemed to be dragging on my '00 4Runner; there was a slight change in the normal noise the car makes at highway speeds, it slowed quicker when letting off the gas, and the brake pedal became mushy/went to the floor.
I pulled off of the highway, put the car in park, walked around and inspected each wheel to see if one was red hot (there wasn't one I could ID as being hotter than the others since it was ~100 degrees out) then got back in, engaged the parking brake once or twice thinking maybe something was sticking, and continued on my way.
Since then (for the past 2 days) everything worked fine until a few hours ago. I felt the same dragging sensation, detected the sound/pitch change while change, and the brake pedal would go to the floor like I'd boiled my brake fluid.
I pulled over again and put the back of my hand up to each wheel, and maybe the passenger front was hotter than the others, but not substantially so.
Since I'm at work I only have had time to go down and pump the brake pedal until it's firm with the car off, then hold the brake pedal and turn the car on and feel the brake pressure subside (I believe someone said this was a test for the brake booster?). The pedal stays firm while the car is off, which makes me think it isn't the master cylinder since it's not losing pressure. Brake fluid is at the max line, no visible leaks.
I plan to jack the car up and rotate the wheels to see if I can ID where the drag is coming from, but am interested in hearing any other advice on what to check? I never use the parking brake, and have read about the rear drums needing adjusting occasionally, and am wondering if that could be a probable cause given the issues I'm having?
FYI I pulled the parking brake up and it was fairly firm around ~10 clicks up, but if I really wanted to I was able to get a few more clicks before the parking brake stopped. If it matters, I did this while stationary.
2019 TRD OR | Front Runner rack | Shrockworks sliders
Gone
2015 Trail
2000 SR5
mc813 is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 04:21 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Sounds like one of your front brake calipers are sticking. Easiest way to tell is with a temp gun after they stick again. Hottest one wins! Booster and master sound like they are properly functioning as well.
Old 07-18-2019, 04:26 PM #3
mc813's Avatar
mc813's Avatar
Just drove it home to swap out cars since I didn't want to drive it while the pedal was going to the floor. Tested out the parking brake and it will not stop the 4Runner even when yanked all the way up. Going to check the bellcrank (I think that's what it's called) and see about adjusting rear brakes when I get home later.
Gone
2015 Trail
2000 SR5
Old 07-18-2019, 05:33 PM #4
Real Name: Patrick
Real Name: Patrick
If both bell cranks are moving try using the parking brake a dozen or so times without your foot on the brakes then retest to see if it holds.
brake , car , floor , parking , pedal
Brake pedal to the floor hallj22 3rd gen T4Rs 25 05-22-2017 04:38 PM
Brake pedal to the floor - still need help Paramedic 3rd gen T4Rs 6 02-04-2017 04:32 PM
Brake Pedal goes to the Floor achha64 3rd gen T4Rs 2 11-28-2014 10:19 AM
Brake pedal goes all the way to floor, etc. ThePizzaGuy 3rd gen T4Rs 7 01-18-2013 09:31 PM
does your brake pedal go to the floor? gonzo 4th Gen T4Rs 34 08-03-2006 01:26 PM
