Originally Posted by Ron Helmuth
typically something else would be affected-you have any dash lights out or anything else acting up?
The Toyota 4Runner digital clock is tied to the dome-light fuse.
The factory shop manual diagnostic basically says:
- Check the dome lamp fuse ... if that's good ...
- Remove the center cluster and check the voltage at the clock harness connector ...
- If that's good ... buy a new $300 clock.
What I did was re-wire the Toyota digital clock circuit board!
Since I'm new to this forum, I felt I'd give back and write my first DIY on that topic (with 50 annotated pictures!).
Here is my Toyota 4Runner digital clock repair DIY:
Solved: 3rd generation Toyota 4Runner digital clock repair DIY
Please let me know what you think of it so I can improve my technique.
