Old 07-21-2019, 07:41 PM #1
Kennysmoke Kennysmoke is offline
Kennysmoke is on a distinguished road
Can I rebuild AC system in steps?
I need to swap my AC compressor, condenser and drier after my compressor seized last year and snapped the drive belt. Unfortunately my Runner is my only running vehicle right now and my time to work on it is very limited due to full time work schedule. I was wondering if I could change out the condenser and drier in the evening one night this week and do the compressor on the weekend then get it it vac tested for leaks and filled? Or do I need to do all the work in one shot?
Kennysmoke is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 08:00 PM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is a jewel in the rough LittleCaesar is a jewel in the rough LittleCaesar is a jewel in the rough
Nope, you can replace components in it in steps up till it gets vacuumed down. Then it will be time to add refrigerant.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 08:10 PM #3
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a glorious beacon of light Charlievee is a glorious beacon of light Charlievee is a glorious beacon of light Charlievee is a glorious beacon of light Charlievee is a glorious beacon of light
Charlievee's Avatar
Best to get all the parts and crack the lines once.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 08:25 PM #4
BamaDrewski BamaDrewski is offline
BamaDrewski will become famous soon enough
I would suggest you get all the parts and do everything at once. It is not too terribly complicated. Once the system is open, the drier accumulates moisture (which you do not want. If you put on a new drier and then open the system again, it probably won't work as well....just my two cents....
BamaDrewski is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 08:40 PM #5
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a jewel in the rough Brian. is a jewel in the rough Brian. is a jewel in the rough
Brian.'s Avatar
If you're going to do it in steps, put the drier in LAST. There's a reason for the name, you want it to "work" within your closed system, not be used up in atmospheric air.
Brian. is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 09:33 PM #6
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is just really nice TheDurk is just really nice TheDurk is just really nice TheDurk is just really nice
TheDurk's Avatar
YMMV, but I have done two AC repairs lately where the systems stayed depressurized over the winter. One was sort of open to the atmosphere; it was a BMW 3 that hit a 'coon and the condenser line cracked. The other was an evaporator leak that was down to zero pressure by Christmas after a last charge in August.
When I finally got around to fixing them, I left them a good long time on the vacuum pump, and they came back to life good as new. New driers, obviously.
My Backyard Frame Swap
Old 07-21-2019, 10:04 PM #7
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad is a glorious beacon of light sleepydad is a glorious beacon of light sleepydad is a glorious beacon of light sleepydad is a glorious beacon of light sleepydad is a glorious beacon of light
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I think you got all the answer already.
I just did the entire thing this weekend. If your reasonably skilled and have everything on hand you can do the tear down and re-install in about 4-6 hours.
I pulled everything out and then started with the evap core and worked my way forward. The last thing I did was the drier.
I borrowed a vac setup from a friend and then pulled a vacuum right away, so the drier was only open for maybe 2-3 mins. after 30 mins on vac I closed the manifolds and let it sit overnight... checked it first thing and re-pulled with the pump just to make sure it had zero leaks.
getting it re-charged tomorrow morning on a machine.
I could have charged it but... I just want to know it's setup correctly. robots can do a better job than me.
as long as you pulled a vac each time you replaced a part of it, honestly I can't see why you can't do it piece by piece but... I think I would want to pull a vac on it after each part and then for sure drier last.
compressor , condenser , drier , time , work
CV joint rebuild or not to rebuild, that is the question!!! alia176 4th Gen T4Rs 7 07-19-2016 09:09 PM
Rebuild my current CV axles or buy used oem and rebuild them? mrwinkle13 4th Gen T4Rs 8 09-16-2015 03:20 PM
Tube Steps / Side Steps Sport Edition Tdub Classifieds - buy & sell (no commercial ads please) 4 06-08-2011 06:41 AM
2000 4runner - Iginition System Issues and Security System emtnscs New Members 0 10-12-2010 11:15 AM
WTT: 2009 Tube Steps for Urban Runner Tube Steps halohaloboy Classifieds - buy & sell (no commercial ads please) 3 05-16-2010 12:10 AM
