Old 05-12-2020, 10:02 PM #16
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Originally Posted by Arv View Post
Thanks for the adj. the rear brake tip, yep read about that too. I did have them replaced a few years ago when my gear oil leaked so they shouldn't be frozen.
Some may find this excessive, but every 15k is how often I would adjust those rear drums. I found that the later 01-02 drum setup require less frequent adjusting.
Old 05-12-2020, 11:30 PM #17
Arv Arv is offline
Arv is on a distinguished road
Arv Arv is offline
Wow! that's dedication!
Not sure if applying the handbrake while the car is moving backwards trick really works (won't work if your rear brake mechanism is frozen/rusted stuck) but I do that all the time.
Arv is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 11:56 PM #18
T4R2014's Avatar
T4R2014's Avatar
I don't think that trick works. Never heard of anyone using it with success. Wanna hear dedication? The original owner of one my 4Runners gave me the records. Adjusted brakes at very oil change!
Old 05-16-2020, 03:15 PM #19
Arv Arv is offline
Arv Arv is offline
Kindly check out my post on brake pad choice between Akebono ProACT vs. Wagner ThermoQuiet
TBU Akebono vs. Wagner Thermoquiet - stopping power
Old 08-17-2020, 07:50 PM #20
psea17 psea17 is offline
psea17 will become famous soon enough
Will the tundra rotors (43512-0C011) work w/ the oem 4runner calipers?
just looking for a more robust rotor. also seems the PowerStop rotors get very mixed reviews.
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 07:52 PM #21
Arv Arv is offline
Arv Arv is offline
Nope. the Tundra rotors are thicker.
Old 05-09-2021, 07:28 PM #22
nodge87's Avatar
nodge87 nodge87 is offline
nodge87 is on a distinguished road
nodge87's Avatar
Originally Posted by qrohlf View Post
Getting close to a year on and I figured I'd check in. I've driven over I-70 multiple times, went Colorado to Mexico and back, and have experienced nothing less than flawless braking with zero wobble or fade.
Quite happy with how it turned out, and can recommend the 199mm upgrade.
This is all great info! Out of interest, which calipers did you go with in the end? Also, have you found any squealing out of the tundra brakes, like others have mentioned?
nodge87 is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 11:18 PM #23
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
just throwing in a mention: i went with Power Stop KC2324 Z23 and they are doing great. no complaints. i installed them a year and seven months ago (9,000 miles) and no issues after proper bedding.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 08:27 PM #24
osideplayer osideplayer is offline
osideplayer will become famous soon enough osideplayer will become famous soon enough
I just did this thanks!
I bought Toyota OEM pads and Rotors. I went with remanufactured calipers from Napa and Centric 950.44007 SS lines. They don't make the Eclipse model anymore, so not sure what the difference is. Everything works great. I am extremely pleased with the results.
osideplayer is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 12:20 PM #25
99 W/ Kids 99 W/ Kids is offline
99 W/ Kids is on a distinguished road
Must be wrong part numbers?
Background
Just like @CO_FlyFisher, and @atalarico, I was coming down Colorado's I-70 towards Boulder and my vibrating brakes convinced me it was time to take the plunge on the Tundra Brake Upgrade. I have stock 16" 6-spokes on my 2000 SR5 and didn't want to grind them down (required to upgrade to 231mm), so I did all the digging on an "as OEM as possible" 199mm Tundra Brake Upgrade.
While @BigFishAllDay has the definitive reference thread for the 231mm brake upgrade, the OEM part numbers and information on the 199mm brake upgrade is a little bit scattered and hard to find. Hopefully this summary of my research can serve as the definitive resource for folks gathering up the parts to do a 199mm brake upgrade.
Lots of credit goes to @farmerjon 's build thread here which is where I got most of the part numbers from (some have been superseded in Toyota's catalog by updated part numbers, reflected in this thread). Hope this round-up is useful for folks!
Parts
The basic parts that you will need for a 199mm brake upgrade that stays as OEM as possible are as follows. I've included rough prices that you'd expect to pay from an online dealer like Camelbak (I personally use Boulder Toyota's online parts dept since they're local and price-competitive if I order online).
- 1 x set of OEM Brake Pads - 04465-0C012 - $58.24
- 2 x OEM Brake Rotors - 43512-0C011 - $126.00 ($63 ea) - note that the rotors are the same for the 199mm upgrade and the 231mm upgrade
- 1 x OEM anti-squeal shim kit - 04945-04012 - $18.75
- Calipers (see below)
- DOT3 or DOT4 brake fluid
- Brake cleaner
Calipers
If you want new OEM 199mm Tundra Calipers, they're available as part numbers 477500C011 (left) and 47730-0C011 (right). That said, you'll pay around $300 per caliper, whereas quality remanufactured components with similar performance can be had for as little as $45/caliper.
You have a ton of choices for remanufactured calipers. I did a bunch of searching and reading, and these appear to be the three best options:
- If you want that TRD red powdercoat look, pick up a set of Power Stop S2632 calipers. Currently, these are available for $85.79 for a set of both left and right on Rock Auto.
- If you don't want the red, but you still want some kind of anti-rust coating besides bare cast iron (a good idea IMO), Cardone 19P2632 (left) and Cardone 19P2633 (right) calipers are probably your best bet. Current price is $44.79/caliper. People also really seem to like the NAPA Eclipse-branded black powdercoat remanufactured calipers, but they're twice the price, most likely made by the same company as the Cardone ones, and I don't think they're available in 199mm any more.
- The important thing if you're shopping around for remanufactured calipers is to plug in "2001 Tundra V8" as your vehicle and make sure you are purchasing 13WE casting calipers, NOT the 231mm "13WL" casting. The 13WL casting is for the 231mm upgrade.
Calipers, continued
If you choose to go with remanufactured calipers, there's a good chance they'll include a "core charge" that gets refunded when you send your old parts back to where you purchased them. On paper, this could cause a problem since you're buying Tundra parts and sending back 4Runner calipers. In practice, the general consensus in all these Tundra Brake Upgrade threads is that as long as you send back a Toyota caliper in the box and don't bring attention to the difference, nobody will hassle you.
Installation
Though info about parts for the 199mm upgrade is a little scattered, the install process is well-documented as it is basically the same as the 231mm upgrade EXCEPT you will not need to grind the dust shields or wheels.
Since the purpose of this thread is mainly to provide info about the 199mm upgrade OEM part numbers and remanufactured caliper alternative part numbers, you'll want to refer to one of these other excellent resources for info about installing your new parts and bleeding the brakes:
- Timmy the Toolman brake upgrade video
- Yotatech step-by-step writeup
- Pad and Rotor Replacement For Noobs
I have a 99 runner. I ordered the parts as you have them specified here but the caliper does not fit over the rotor. I am 100% sure i ordered the parts as you have them on here and I double checked them and I received that part number. . Has anyone responded that they had problems with these parts?
I ordered these parts...
Power Stop S2632 calipers from Rock Auto
They do NOT fit together
99 W/ Kids is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 01:20 PM #26
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I would suspect you have the wrong calipers in the box. Do you see any stampings or markings on the calipers?
Old 11-08-2021, 06:10 PM #27
nosam27 nosam27 is offline
nosam27 is on a distinguished road
Also, you've probably already done this, but if it is in fact the right calipers, make sure the rotor is seated against the hub completely. I just did this install and thought it wasn't going to work, but it was because the rotor wasn't seated properly. I even ran a couple lug nuts down (not tight enough) to seat it. Wiggled the rotor a bit and got it to sit flush on the hub and magic.
nosam27 is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 06:13 PM #28
Just did the 199mm TBS and everything seems to be working well. Also, got lucky and Rock Auto took my cores back without a fuss. Thanks, @qrohlf
Old 11-10-2021, 09:58 PM #29
Well, I humbly apologize, I thought I had the rotor seated but it was off just a hair. The tolerance is so close that it seemed to be the wrong caliper. After I seated it properly it fit right up.
Again, my apologies, these are absolutely the correct parts!
Thank you!
Old 09-26-2022, 11:33 AM #30
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Is this right? How can the rotors be the same if they're 2 different diameters? So just the calipers and pads are different between the 199 and the 231 upgrades? Do the 231 calipers/pads contact the rotor further out on the diameter of the rotor? I thought the whole difference between the 2 upgrades was that one is a 199mm diameter rotor and the other is a 231mm diameter rotor.
EDIT: I just realized that 231mm and 199mm can't be the diameter of the rotor since that's like 8 and 9 inches respectively and the rotors are like 12" diameter. So does 199/231 refer to the pad width or something?
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
199mm , brake , calipers , oem , upgrade
Tundra Brake Upgrade - Wheel center cap part number round-up NoVA_T4R 3rd gen T4Rs 2 09-04-2017 03:54 PM
Need part number for Tundra 231mm brake upgrade DDeezenuts 3rd gen T4Rs 5 12-21-2015 03:36 PM
3rd gen 4runner- OEM rotor part # for 199mm brake upgrade? hawkcharmer 3rd gen T4Rs 3 05-05-2015 08:27 PM
Do I need brake pad shims for 199mm Tundra upgrade? PA Pat 3rd gen T4Rs 1 06-29-2011 02:27 AM
is the 199mm tundra brake upgrade be worth it? theizzardking 3rd gen T4Rs 25 04-27-2010 10:25 PM
