Old 09-26-2022, 11:07 PM #31
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by texadelphia View Post
Is this right? How can the rotors be the same if they're 2 different diameters? So just the calipers and pads are different between the 199 and the 231 upgrades? Do the 231 calipers/pads contact the rotor further out on the diameter of the rotor? I thought the whole difference between the 2 upgrades was that one is a 199mm diameter rotor and the other is a 231mm diameter rotor.
EDIT: I just realized that 231mm and 199mm can't be the diameter of the rotor since that's like 8 and 9 inches respectively and the rotors are like 12" diameter. So does 199/231 refer to the pad width or something?
Yes. The Tundra brake upgrade useez the same wide rotor. This refers to the caliper brake pad opening.
Old 09-27-2022, 10:29 AM #32
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
199/231mm refer to the brake pad backing plate size not the rotor.
Old 08-16-2023, 12:18 PM #33
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
I went on NAPAonline and saw that both the Tundra and Sequoia share the same front calipers, FYI. I'll make sure that the Sequoia has 13WL & 13WE stamping as the Tundra.
I'm going to go to the pull n pay this weekend and grab a set of each.
This will be going on my daughter's '97 4runner as her braking performance, even with the EBC Greenstuff pads aren't ideal.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 08-19-2023, 09:52 AM #34
I learned something yesterday at the junkyard. A '01 Tundra and a '01 Sequoia do NOT share the same calipers. One is the WE, the other one is a WL. However, a '07 Sequoia does have the WE calipers.
FYI.
Old 08-19-2023, 10:08 AM #35
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
FYI.
Good to know. Thanks for sharing.
Old 08-19-2023, 06:31 PM #36
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
As a casual reader of a few TBU threads over the years, I'm more confused than ever.
I need to do something about my brakes. I have quite the wobble and popped the front wheels off at lunch and found one rotor is shedding massive amounts of rusted metal and each rotor has different wear/pad contact areas that differ by 1/2 an inch. These brakes came with the truck about 3 years ago.
I'm tempted to just grab a set of OEM rotors, pads, shims, and hardware and call it a day. I suck at bleeding brakes on my MTB and probably would fare no better trying to upgrade the calipers. On the other hand I could get an off the shelf Powerstop/other full kit and give it a shot. To me, doing the Right Thing would be to go full 2005 Tundra OEM....but I don't even have a driveway currently.....
Resources & OEM part number list for 199mm Tundra Brake Upgrade-000rotor-jpg  Resources & OEM part number list for 199mm Tundra Brake Upgrade-rotor2-jpg  Resources & OEM part number list for 199mm Tundra Brake Upgrade-rotor3-jpg
258K - Y2K/E - Clock still works
Old 08-28-2023, 09:07 AM #37
The TBU is rather straightforward, I thought. My 17yo daughter pulled it off easily, under my guidance. She is claiming to have better and more consistent braking now, which made me quite relieved to hear.
199mm , brake , calipers , oem , upgrade
Tundra Brake Upgrade - Wheel center cap part number round-up NoVA_T4R 3rd gen T4Rs 2 09-04-2017 03:54 PM
Need part number for Tundra 231mm brake upgrade DDeezenuts 3rd gen T4Rs 5 12-21-2015 03:36 PM
3rd gen 4runner- OEM rotor part # for 199mm brake upgrade? hawkcharmer 3rd gen T4Rs 3 05-05-2015 08:27 PM
Do I need brake pad shims for 199mm Tundra upgrade? PA Pat 3rd gen T4Rs 1 06-29-2011 02:27 AM
is the 199mm tundra brake upgrade be worth it? theizzardking 3rd gen T4Rs 25 04-27-2010 10:25 PM
