Old 12-02-2022, 12:22 AM #1
02_SE_Runner_DAD's Avatar
02_SE_Runner_DAD 02_SE_Runner_DAD is offline
02_SE_Runner_DAD is on a distinguished road
Bank 1 sensor
Hello all, looking for a cheaper than OEM bank 1 sensor(P0171) that is recommended. Part number would be great.
TIA
Fly High Son(NATE) 1995-2014
http://www.toyota-4runner.org/3rd-ge...od-thread.html
02_SE_Runner_DAD is offline   Reply With QuoteReply With Quote
Old 12-02-2022, 12:23 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
TIA
There is only 1 bank of oxygen sensors. Do you need sensor 1 (upstream) or sensor 2 (downstream)?
Old 12-02-2022, 12:26 PM #3
The O2 sensor is nothing to skimp on. I’m using the NTK sensor in my rig but the price is similar to the Denso brand.
Old 12-02-2022, 04:09 PM #4
The code is for the a/f sensor assuming it’s the upstream(before cat). Thank you.
Old 12-02-2022, 04:57 PM #5
Real Name: Patrick
Real Name: Patrick
Denso 234-9002 is the upstream oxygen sensor. I have not had good luck with ebay/amazon and oxygen sensors. I've received a couple convincing knock offs. Summit racing sells it though. https://www.summitracing.com/parts/d...AaAhHkEALw_wcB
Old 12-02-2022, 05:06 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
There isn't any cheaper option unless you get a used one from a pick and pull that's functional.
Rock Auto, auto parts stores are the only ledgit stores denso parts.
Sadly extremely easy to get counterfeit parts from those sources..
Old 03-22-2023, 12:34 PM #7
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
We would need to know if you have Fed (1cat) or Cali (2 Cat) emissions to advise you which part number you require.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 03-22-2023, 03:52 PM #8
Real Name: Patrick
Real Name: Patrick
All 01/02 are California emissions and the same exhaust.
Old 08-21-2023, 09:39 PM #9
dvachon dvachon is offline
dvachon is on a distinguished road
Good info to know. Didn't realize that with the 01 & 02's...
dvachon is offline   Reply With QuoteReply With Quote
Old 08-21-2023, 09:43 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes. The emmision rules changed in 2000 for model year 2001 so that's how Toyota did meet the change.
Old 08-21-2023, 09:57 PM #11
Gotcha, thanks. That makes it always easier for identifying CA vs Fed emissions vehicles when future searching for a new 3rd gen! Thanks man!
Old 08-22-2023, 01:29 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yup... Feds only one cat 1996-1999
CA 2 cats 1996-2000
all 3rd gens 2 cats 2001-2002..
Old 08-27-2023, 11:50 PM #13
zidaro's Avatar
zidaro zidaro is offline
zidaro is on a distinguished road
zidaro's Avatar
summit racing has what you need, and pricing is great with free ship at $100
Couple Yotas
Iluv4xToys!
zidaro is offline   Reply With QuoteReply With Quote
bank , great , number , part , recommended
H02 Sensor (Bank 1 Sensor 2) P0136 Code??? petepup Maintenance/Detailing 32 01-06-2023 06:49 PM
Air-Fuel Ratio (A/F) Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) vipblades 3rd gen T4Rs 33 10-25-2014 11:06 AM
2003 v8 4runner: Oyxgen Sensor Bank 1 Sensor 1 ALPHABARN 4th Gen T4Rs 0 06-19-2011 09:08 PM
EG034-07 06/28/2007 Engine Controls - Bank 1/Bank 2 O2 Sensor identification CBR_GUY_IA TSB 0 07-12-2009 09:31 PM
