Today I reset map, changed air filter, treated fuel with sea foam injector cleaner, removed and cleaned MAF and throttle body. Throttle body was pretty dirty, so was air filter. Unfortunately I’m not noticing a change in acceleration. Hopefully I’ll at least see some improved MPG
Originally Posted by plcfcng
if it has a clogged exhaust a vacuum gauge will show you that. I don't have any numbers but im sure there is a Utube video some where to give u a idea how to do it. You maybe able to rent the Vac gauge at Orelley or AZ
I have access to vac, I’ll probably check exhaust sometime next week
