Old 07-25-2019, 05:12 PM #1
TejasRunner01 TejasRunner01 is offline
TejasRunner01 will become famous soon enough TejasRunner01 will become famous soon enough
When traveling down hill..
Hey everyone,
I just wanted to get your opinion on the best way to save brakes when going down hill. I have a '97 automatic 4wd with the J shifter. Do you simply keep your automatic transmission in D and put the transfer case in 4low or do you only downshift the engine?
Thanks for your input!
TejasRunner01 is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 05:41 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Downhill on a highway or downhill rock crawling?
Old 07-25-2019, 06:17 PM #3
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
I love trick questions! The answer is don't try to save your brakes. Thats what they are there for.
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 06:42 PM #4
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
until they get too hot and don't work...
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 06:59 PM #5
This is the real question...
You can't shift into 4LO while moving anyway...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-26-2019, 01:06 AM #6
I am specifically asking regarding steep downhill descents whether that be a paved road or gravel. Not asking about rock crawling.
Also I realize you can't shift into 4low while moving. I'm specifically asking if you are about to go down a steep hill and you have time to stop and adjust your transfer case and automatic transmission gear, what is the best way to proceed.
Thanks for the input.
Old 07-26-2019, 02:25 AM #7
pokeyman pokeyman is offline
pokeyman is on a distinguished road
Use your brakes because they are cheaper to replace than your transmission
pokeyman is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 07:23 AM #8
St Runner's Avatar
St Runner's Avatar
I drive a 5speed so I use engine braking all the time but for an auto here are my rules of thumb.
Normal driving hilly not highway - take off overdrive
Steep and hilly paved- use second or even first on the auto if it is really steep and slow
Steep and wet or steep gravel- 4wd hi and second or first on the auto
When it gets really steep and slippery you want it in 4wd low so all 4 tires will help slow the car not just the rear end. That goes double when you are trying to back down a steep and slippery hill. Having said all that I would still rely on brakes first as they are cheap and easy to replace. I live on a very steep island and I smell burning brakes from the rental jeeps all the time so it is useful to use engine braking, but try to use it as a supplement to your regular braking
1997 SR5 4x4
2001 SR5 4x4
Old 07-26-2019, 07:47 AM #9
19963.4lsr5 19963.4lsr5 is online now
If your on main roads just lock out overdrive this A340 has decent compression braking for an automatic.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 07-26-2019, 09:44 AM #10
Thank you for all of your helpful posts. I feel much more educated and prepared now!
Old 07-26-2019, 03:01 PM #11
rickmum's Avatar
rickmum rickmum is offline
rickmum is on a distinguished road
rickmum's Avatar
2nd gear + OD OFF
1998 Desert Dune Limited w/ rear diff locker
300,000 kms
rickmum is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 05:28 PM #12
2ndhandyotaman's Avatar
2ndhandyotaman 2ndhandyotaman is offline
2ndhandyotaman will become famous soon enough
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
2ndhandyotaman is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 06:40 PM #13
Originally Posted by 2ndhandyotaman View Post
Back in the mid to late 90’s when I road raced motorcycles we use to say brakes just slow you down. Who wants that......
Old 01-27-2021, 02:34 PM #14
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
if you drive lots of hills, or towing I highly recomend the TBU. Not only will you have bigger pads, but thicker rotors that help get rid of the heat. Either eway, dont go with cheap pads, keep your rear brakes adjusted and working good.
otherwise I downshift when needed, overdrive off, I live in the hills, drive on lots of ice and snow, but this time of year im in 4wd all the time and that helps.
but like others have said, brakes are cheaper than transmissions.
automatic , hill , transfer , transmission , wanted
Traveling with a dog Johncmng Off Topic 11 11-08-2021 10:24 PM
Traveling With Two Dog Crates Munson 5th gen T4Rs 22 04-04-2021 08:28 PM
traveling Runner TrexRunnerGirl 3rd gen T4Rs 14 06-28-2018 08:37 AM
Toyota of Rock Hill (Rock Hill SC) Service Department = EPIC FAIL! superman3043 Dealers - Your Experience 4 04-11-2016 09:40 AM
Hill Holder/Hill Let-er-roller! KMX3060 4th Gen T4Rs 17 08-11-2005 12:56 PM
