Old 07-26-2019, 11:51 AM #1
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend has a spectacular aura about 4runnerfiend has a spectacular aura about
Top end work MPG and power down
Just had two new heads done, Timing belt, water pump, all the idler pullys, fan bering, put Doug thorley headers on. My MPG went from 14-17 to 12 mpg.. only gone thru two tanks. and I feel like there is less power.
Shop says all the bearings being new and tight there is more drag on the motor. VS old bearings all worn out spin more free. (not buying it)
seem normal? maybe there is a break in period?
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
4runnerfiend is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 12:30 PM #2
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
Problems with vacuum hoses and/or O2 sensors can do that. My mileage went to ~10 with a bad A/FR sensor.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 02:57 PM #3
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Yeah.. that mechanic fed you a load of garbage to get you to go away. Tight bearings. LOL
I'll second the previous poster with O2s being one of the first things to check.
Vacuum routing too, agreed there. Especially since it was all torn apart.
Check for codes (even if the light isnt on)- Light could be burnt out.
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 07:43 PM #4
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
Possible the cams aren't aligned correctly?
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 07-29-2019, 12:53 PM #5
Either cams wrong or one bank timing belt off a tooth? Both are possibilities.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-29-2019, 01:03 PM #6
Thanks for the replies. I think it's ok, did 200 miles freeway and wheeling trip. got 15.2 MPG. for 33's and 4:10 I think that is normal. Power seems fine. Maybe a slight break in period/computer re-learning
Old 07-29-2019, 01:43 PM #7
nissanh nissanh is offline
Go and tell your mechanic that the bearings are worn/lose again and ask for a refund!! :-)
bearings , mpg , power , shop , tight
95 w/ a Passenger Power Window that won't work feusaf Classic T4Rs 9 11-06-2016 08:16 PM
Power Lock won't work? Kyle Reese 3rd gen T4Rs 5 02-10-2016 11:47 PM
Power Windows Don't Work Jonas111 Classic T4Rs 2 11-09-2014 12:16 AM
Power lock switches don't work Skurvy_Pirate 3rd gen T4Rs 4 08-08-2013 11:00 AM
my two aux power outlets dont work Opi 3rd gen T4Rs 2 12-27-2010 07:19 PM
