Old 07-26-2019, 06:18 PM #1
snydmax's Avatar
snydmax snydmax is offline
snydmax is on a distinguished road
snydmax's Avatar
Power antenna conversion... new question?
First, I know there are countless threads on the power antenna woes and conversion options, so please bear with me!
Looking into this for myself, I found a product that claims to convert the power antenna to a stubby 6-3/4 stationary whip and utilizes the motorized antenna base. Has anybody tried one of these who can speak to whether they work or are worth $60?
https://www.amazon.com/AntennaMastsR.../dp/B07B8XSTG6
Power antenna conversion... new question?-screen-shot-2019-07-26-5-16-50-pm-jpg
T4R noob... '98 4WD Limited, 158k, Factory E-locker
snydmax is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 07:10 PM #2
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough
BoomerBob's Avatar
Yes; they work but the reception isn't as good as I think it should be. I think it should come with a taller whip/flexible antenna. It's on the 01 T4R I'm rebuilding right now.
Had the same problem with the 98 T4R and I didn't want to spend the money so I just pulled the antenna, clipped the plastic gear thing, then reinstalled it. The antenna motor runs for about 7 seconds when I turn off the car and probably when I start the car but with the radio on I don't hear it. Radio reception is as good as stock usually is which is pretty good.
I read about someone simply clipping off the plastic geared line then gently crimping each spot in the stock antenna where it expands so he can put it down to wash the rig. It's on my list of things to try.
As for this one with the adapter; I think I'll try a longer antenna since I already spent the money.
2001 2wd - Daily Driver
1998 2wd - Tail Wagger Wagon
BoomerBob is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 10:11 PM #3
snydmax's Avatar
snydmax's Avatar
Feedback appreciated... we were manually raising/lowering the factory mast until it got eaten by the car wash, doh! was optimistic for an easy fix... Too bad you cant buy just the adapter for a decent price, I did read that the manufacturer redesigned the 6-3/4 antenna in January (2019) so its possible that there is an updated whip with the new listing, but who knows.
Let us know if a different whip works out... ought to be able to install just about anything with the right thread adapter I would think
Old 07-27-2019, 12:28 AM #4
BoomerBob's Avatar
BoomerBob's Avatar
I couldn't help but notice the adapter itself is probably a $2 part; cheaper if made in China. Just some rolled tin with a keeper on top like the stock setup. Someone is making too much money on these at $60. I don't mind paying for quality but I don't like overpaying. Legit price with taller antenna should be in the $25 range. Just my humble opinion.
Old 07-27-2019, 02:01 AM #5
bu11etz bu11etz is offline
bu11etz is on a distinguished road
I had that kit from amazon. Ended up returning it as the adaptor never got the antenna tight. Finally its just kept spinning. Also the reception was horrible. Id pass on this setup.
bu11etz is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 02:32 PM #6
TheAntennaSource's Avatar
TheAntennaSource TheAntennaSource is offline
TheAntennaSource is on a distinguished road
Thought I would chime in on this as it is our product in question.
Product spinning when tightened: Our conversion sleeve that inserts into the power antenna tube where the old mast was, will spin when the antenna is tightened onto it. It is designed this way as the insert is a floating part in the antenna tube. This spinning does not pose an issue, the important part is that the sleeve is held into the antenna tube so it does not come out.
Reception: Our 6 3/4" antenna may not be the best choice for all locations. Due to the much shorter size it will not have the range the factory 31"+ antennas have, so it will not be the greatest option in more distant and rural locations. It is a very durable antenna and is close to being indestructible. We do have an array of different antenna lengths of multiple different materials, we can pair our conversion kit with whatever option of your choice but the 6 3/4" is the default. The closest reception option to the factory power antenna mast is the 31" Spring Steel. If you want to pair the kit with a different length or currently have our product and would like to opt for a different antenna size just give me a call, we are located here up in Wisconsin.
Hope this information helps.
Zach
920-686-0644
TheAntennaSource is offline   Reply With QuoteReply With Quote
6-3/4 , antenna , conversion , power , stationary
Replacing head unit: 3 antenna input question & power antenna replacement question Rancho5 3rd gen T4Rs 14 08-24-2018 06:51 PM
Power antenna question Amazee-Dayzee 3rd gen T4Rs 30 09-15-2013 08:31 AM
Power Antenna question T4R_Finally 3rd gen T4Rs 3 06-18-2012 10:25 PM
Power Antenna Question! bosmob Classic T4Rs 7 04-06-2011 11:29 PM
Power antenna question laureena23 General Discussions 0 05-19-2008 08:15 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
