Old 07-26-2019, 09:12 PM #1
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Gas Gauge Needle Stuck
I did a search and didn't find much on this issue. On my 98 the gas gauge needle is stuck between 1/4 and 1/2 tank. It has been this way since I got the rig about a month ago. I just use the odometer to tell me when to fill up.
I realize it could be the sending unit in the tank but I'm wondering if there's a common issue with the gauge which would simply require pulling the gauge cluster and doing a little soldering.
I had an 01 F150 that had a common issue with the digital odometer that required pulling the cluster and adding the tiniest bit of solder to one spot where the solder would develop a crack on the circuit board. Pulling the cluster was all the work. The actual soldering took about 2 seconds.
Just wondering if there might be something similar in the 3rd gens before I pull the cluster.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 07-27-2019, 10:23 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Does the needle go to empty when you turn the vehicle off?
Old 07-27-2019, 10:26 AM #3
carp73's Avatar
carp73 carp73 is offline
Real Name: Jeremy
carp73 is on a distinguished road
carp73's Avatar
Real Name: Jeremy
Mine is not stuck but it definitely doesn't work correctly. When I first fill up it goes up to about 3/4 tank, then drops immediately (within 20 or so miles) to half and stays there for the majority of the tank until it drops down all the way as I'm getting closer to running out and the light comes on. I replaced my fuel pump recently and cleaned out the contacts in the sender and tried bending the arm a little so it would read full when I fill up, but it didn't make a difference. Sorry I have no solutions for you ha
carp73 is offline   Reply With QuoteReply With Quote
Old 07-27-2019, 01:29 PM #4
BoomerBob's Avatar
BoomerBob's Avatar
No sir. I just stays at the one position whether the key is on or not. Are you thinking it might be the fuel gauge in the cluster?
Old 07-27-2019, 08:18 PM #5
Real Name: Patrick
Real Name: Patrick
If it was the sender giving you a bad reading the needle would still move to empty when the vehicle is turned off. My bet would be the instrument cluster.
Old 07-28-2019, 08:58 AM #6
olhobbler olhobbler is offline
olhobbler is on a distinguished road
gas gauge
got a 99 perfect looking, don't know why I pulled it but its not 4wd so its just sittin in my garage. miles unknown
olhobbler is offline   Reply With QuoteReply With Quote
cluster , gauge , issue , pulling , solder
Gas gauge stuck at zero after dealer flashed ECM pendragon 4th Gen T4Rs 8 04-09-2017 07:52 AM
Fuel gauge needle trouble Hunter P 3rd gen T4Rs 8 08-23-2012 08:33 PM
Gauge Needle Removal? Antman 5th gen T4Rs 8 01-31-2012 10:05 AM
Stuck gas gauge (full) RedDragonATL 3rd gen T4Rs 19 01-13-2012 03:48 PM
1996 4runner RPM gauge needle going crazy tvbuster1 3rd gen T4Rs 2 01-05-2011 01:00 PM
